홈/ 질문/Q 88858
등록일: 2010-09-102010-09-10T22:18:00+09:00 2010-09-10T22:18:00+09:00카테고리: AutoCAD & CADian
->>수정ok to:우정2
(defun c:xx (/ #ap #ad #as #a #b #sn #sz #c #index #d #e)
   (vl-load-com)
   (setq #ap(vlax-get-acad-object))
   (setq #ad(vla-get-activedocument #ap))
   (setq #as
      (if(> (vla-get-activespace #ad) 0)
         (vla-get-modelspace #ad)
         (vla-get-paperspace #ad)
      );;if
   );;setq
   (setq #a(ssget ‘((0 . “line”))))
   (setq #b(sslength #a) #index -1)
   (setq #sn(getint “≫≫≫Start number<1>:”))
   (if (not #sn)(setq #sn 1))
   (setq #sn(1- #sn))
   (if(not(setq #sz (getreal (strcat “글자크기 <” (rtos(getvar “textsize”)) “>:”))))
     (setq #sz(getvar “textsize”))
     (setvar “textsize” #sz)
   );;if
   (repeat #b
     (setq #c(cons(vlax-ename->vla-object (ssname #a (setq #index (1+ #index))))#c))
   );;repeat
   (foreach #x #c
     (if (vl-catch-all-error-p(setq #d(vl-catch-all-apply ‘vlax-curve-getdistatparam (list #x (vlax-curve-getendparam #x)))))
       (progn
         (vlax-release-object #x)
         (exit)
       );;progn
       (progn
         (vla-addtext #as (itoa(setq #sn(1+ #sn)))(vla-get-startpoint #x)#sz)
         (vla-addtext #as (itoa(setq #sn(1+ #sn)))(vla-get-endpoint #x)#sz)
         (setq #e(cons(list (itoa(1- #sn)) “-” (itoa #sn)(chr 32)(chr 9)(rtos #d)(chr 10))#e))
       );;progn
     );;if
   );;foreach
   (if #e(vla-addmtext #as (vlax-3d-point(getpoint “Pick point:”))(* #sz 20)(apply ‘strcat(mapcar ‘(lambda (x)(apply ‘strcat x))(reverse #e)))))
);;defun
  • 26 조회
