홈/ 질문/Q 112057
등록일: 2019-12-282019-12-28T11:59:03+09:00 2019-12-28T11:59:03+09:00카테고리: AutoCAD & CADian
강연선 정착부 배치 VBA
직선을 가지는 강연선 배치 VBA입니다.
(이미지 추가가 여의치 않아서 블로그 링크시켰습니다)
https://blog.naver.com/kimdhj77
Sub te1()
    Dim Pnt1, Pnt2, Pnt3 As Variant ‘3points
    Pnt1 = ThisDrawing.Utility.GetPoint(, “1st Point”)
    Pnt2 = ThisDrawing.Utility.GetPoint(, “2nd Point”)
    Pnt3 = ThisDrawing.Utility.GetPoint(, “3rd Point”)
    Dim a, b, c As Double
    a = Pnt3(0) – Pnt1(0)
    b = Pnt2(0) – Pnt1(0)
    c = Pnt1(1) – Pnt3(1)
    Dim x, fx, fxd As Double
    Dim i As Integer
    x = c
    For i = 0 To 10
        fx = (x – b) ^ 2 – (x – a) ^ 2 + (b * c / x – c) ^ 2
        fxd = -2 * b * c / (x * x * x) + 2 * c / (x * x) + 2 * a – 2 * b
        x = x – fx / fxd
    Next i
    Pnt2(1) = -b * c / x + c + Pnt3(1)
    Dim circlePnt(2) As Double
    Dim circleR As Double
    circlePnt(0) = Pnt3(0)
    circlePnt(1) = x / c * a – b * c / x + c – b * x / c + Pnt3(1)
    circleR = Abs(circlePnt(1) – Pnt3(1))
    Dim lineObj As AcadLine
    Set lineObj = ThisDrawing.ModelSpace.AddLine(Pnt1, Pnt2)
    Dim strA, endA As Double
    If circlePnt(1) > Pnt1(1) Then
        strA = Atn(x / c) + 3.14159265358979
        endA = 3.14159265358979 * 1.5
    Else
        strA = 3.14159265358979 * 0.5
        endA = Atn(x / c) – 3.14159265358979
    End If
    Dim arcObj As AcadArc
    Set arcObj = ThisDrawing.ModelSpace.AddArc(circlePnt, circleR, strA, endA)
End Sub
  • 38 조회
