홈/ 질문/Q 93935
등록일: 2011-12-302011-12-30T13:43:52+09:00 2011-12-30T13:43:52+09:00카테고리: AutoCAD & CADian
공차 리습입니다. 2008에 올릴려니 구동이 안되네요 고수님들 관심 부탁드립니다.
(defun err1 (s1)
   (if (/= s1 “Function cancelled”)
       (princ (strcat “nError:” s1))
   (setvar “cmdecho” echo)
   (setq *error* olderr)
(defun c:tor ()
  (graphscr)
  (setq olderr *error* *error* err1)
  (setq echo (getvar “cmdecho”))
  (setvar “cmdecho” 0)
  (menucmd “p0=m_tolerance”)(menucmd “p0=*”)
  (initget 1 “Shaft Hole STand Key SRSha SRHol”)
  (prompt “nSelect option…”)(terpri)
  (setq to_cmd (getkword “nShaft/Hole/Standard/Key-shaft(KS)/Key-hole(KH)/Snapring-shaft(SRS)/Snapring-hole(SRH):”))
  (cond ((= to_cmd “Shaft”)
         (progn
            (if (= to_dia nil)(setq to_dia 10))(setq qto_dia to_dia)
            (setq to_dia (getdist (strcat “nInput diameter<” (rtos to_dia 2 2) “>:”)))
            (if (= to_dia nil)(setq to_dia qto_dia))
            (if (= to_num nil)(setq to_num “g6”))(setq qto_num to_num)
            (setq dd 5)
            (while dd
               (setq to_num (getstring (strcat “nInput Tolerance<” to_num “>:”)))
               (if (= to_num “”)(setq to_num qto_num))
               (setq to_num   (strcase to_num t))
               (if (or (= to_num “b9”)(= to_num “c9”)(= to_num “d8”)(= to_num “d9”)
                       (= to_num “e7”)(= to_num “e8”)(= to_num “e9”)(= to_num “f6”)
                       (= to_num “f7”)(= to_num “f8”)(= to_num “g4”)(= to_num “g5”)
                       (= to_num “g6”)(= to_num “h4”)(= to_num “h5”)(= to_num “h6”)
                       (= to_num “h7”)(= to_num “h8”)(= to_num “h9”)(= to_num “js4”)
                       (= to_num “js5”)(= to_num “js6”)(= to_num “js7”)(= to_num “k4”)
                       (= to_num “k5”)(= to_num “k6”)(= to_num “m4”)(= to_num “m5”)
                       (= to_num “m6”)(= to_num “n6”)(= to_num “p6”)(= to_num “r6”)
                       (= to_num “s6”)(= to_num “t6”)(= to_num “u6”)(= to_num “x6”) )
                   (setq dd nil)
                   (princ (strcat “nInvalide. <” to_num “>not found. Try again!!”))
            );; while dd end
            (setq tn       to_num
                  tn-a     (substr tn 1 1)
                  to_file  (open “z:/acad/data/to-shaft.dat” “r”)
                  to_file1 (read-line to_file)
                  to_dmin  (atof (substr to_file1 1 3))
                  to_dmax  (atof (substr to_file1 5 3)) )
            (while (or (<= to_dia to_dmin)(> to_dia to_dmax))
                   (setq to_file1 (read-line to_file)
            (cond ((= tn “b9”)(setq aa 9 bb 3  cc 97 dd 3))((= tn “c9”)(setq aa 13 bb 3 cc 101 dd 3))
                  ((= tn “d8”)(setq aa 17  bb 3 cc 105 dd 3))((= tn “d9”)(setq aa 17  bb 3 cc 109 dd 3))
                  ((= tn “e7”)(setq aa 21  bb 3 cc 113 dd 3))((= tn “e8”)(setq aa 21  bb 3 cc 117 dd 3))
                  ((= tn “e9”)(setq aa 21  bb 3 cc 121 dd 3))((= tn “f6”)(setq aa 25  bb 2 cc 125 dd 3))
                  ((= tn “f7”)(setq aa 25  bb 2 cc 129 dd 3))((= tn “f8”)(setq aa 25  bb 2 cc 133 dd 3))
                  ((= tn “g4”)(setq aa 28  bb 2 cc 137 dd 2))((= tn “g5”)(setq aa 28  bb 2 cc 140 dd 2))
                  ((= tn “g6”)(setq aa 28  bb 2 cc 143 dd 2))((= tn “h4”)(setq aa 31  bb 2 cc 146 dd 2))
                  ((= tn “h5”)(setq aa 31  bb 2 cc 149 dd 2))((= tn “h6”)(setq aa 31  bb 2 cc 152 dd 2))
                  ((= tn “h7”)(setq aa 31  bb 2 cc 155 dd 2))((= tn “h8”)(setq aa 31  bb 2 cc 158 dd 2))
                  ((= tn “h9”)(setq aa 31   bb 2 cc 161 dd 3))((= tn “js4”)(setq aa 33  bb 2 cc 33 dd 2))
                  ((= tn “js5”)(setq aa 37  bb 4 cc 37 dd 4))((= tn “js6”)(setq aa 42  bb 4 cc 42 dd 4))
                  ((= tn “js7”)(setq aa 47  bb 4 cc 47 dd 4))((= tn “k4”)(setq aa 52   bb 2 cc 165 dd 2))
                  ((= tn “k5”)(setq aa 55  bb 2 cc 165 dd 2))((= tn “k6”)(setq aa 58  bb 2 cc 165 dd 2))
                  ((= tn “m4”)(setq aa 61  bb 2 cc 168 dd 2))((= tn “m5”)(setq aa 64  bb 2 cc 168 dd 2))
                  ((= tn “m6”)(setq aa 67  bb 2 cc 168 dd 2))((= tn “n6”)(setq aa 70  bb 2 cc 171 dd 3))
                  ((= tn “p6”)(setq aa 73  bb 3 cc 174 dd 2))((= tn “r6”)(setq aa 77  bb 3 cc 177 dd 3))
                  ((= tn “s6”)(setq aa 81  bb 3 cc 181 dd 3))((= tn “t6”)(setq aa 85  bb 3 cc 185 dd 3))
                  ((= tn “u6”)(setq aa 89  bb 3 cc 189 dd 3))((= tn “x6”)(setq aa 93  bb 2 cc 193 dd 2)) );;;
            (setq up_tor (/ (atof (substr to_file1 aa bb)) 1000)
                  dn_tor (/ (atof (substr to_file1 cc dd)) 1000) )
            (cond ((or (= tn-a “b”)(= tn-a “c”)(= tn-a “d”)(= tn-a “e”)
                       (= tn-a “f”)(= tn-a “g”))(setq up_sym “-” dn_sym “-“))
                  ((= tn-a “h”)(setq up_sym ”  ” dn_sym “-“))
                  ((= tn-a “j”)(setq up_sym “+” dn_sym “-“))
                  ((or (= tn-a “k”)(= tn-a “m”)(= tn-a “n”)
                       (= tn-a “p”)(= tn-a “r”)(= tn-a “s”)(= tn-a “t”)
                       (= tn-a “u”)(= tn-a “x”))(setq up_sym “+” dn_sym “+”))
            (if (= tn-a “j”)(setq dd 4)(setq up_dd 3 dn_dd 3))
            (if (= up_tor 0)(setq up_dd 0))
            (if (= dn_tor 0)(setq dn_dd 0))
            (setq up_txt (strcat up_sym (rtos up_tor 2 up_dd))
                  dn_txt (strcat dn_sym (rtos dn_tor 2 dn_dd)) ) (initget 1)
            (setq to_pnt (getpoint “nText position:”))          (initget 1)
            (setq an (getangle “nAngle:” to_pnt))
            (command “text” to_pnt (* (getvar “dimscale”) 1.5) (rtd an) dn_txt)
            (setq to_pnt (polar to_pnt (ang 90) (* (getvar “dimscale”) 1.8)))
            (command “text” to_pnt (* (getvar “dimscale”) 1.5) (rtd an) up_txt)
        ));; <progn end>
        ((= to_cmd “Hole”)
         (progn
            (if (= to_num1 nil)(setq to_num1 “H7”))(setq qto_num1 to_num1)
            (setq dd 5)
            (while dd
               (setq to_num1 (getstring (strcat “nInput Tolerance<” to_num1 “>:”)))
               (if (= to_num1 “”)(setq to_num1 qto_num1))
               (setq to_num1   (strcase to_num1))
               (if (or (= to_num1 “B10”)(= to_num1 “C9”)(= to_num1 “C10”)(= to_num1 “D8”)
                       (= to_num1 “D9”)(= to_num1 “D10”)(= to_num1 “E7”)(= to_num1 “E8”)
                       (= to_num1 “E9”)(= to_num1 “F6”)(= to_num1 “F7”)(= to_num1 “F8”)
                       (= to_num1 “G6”)(= to_num1 “G7”)(= to_num1 “H5”)(= to_num1 “H6”)
                       (= to_num1 “H7”)(= to_num1 “H8”)(= to_num1 “H9”)(= to_num1 “H10”)
                       (= to_num1 “JS5”)(= to_num1 “JS6”)(= to_num1 “JS7”)(= to_num1 “K5”)
                       (= to_num1 “K6”)(= to_num1 “K7”)(= to_num1 “M5”)(= to_num1 “M6”)
                       (= to_num1 “M7”)(= to_num1 “N6”)(= to_num1 “N7”)(= to_num1 “P6”)
                       (= to_num1 “P7”)(= to_num1 “R7”)(= to_num1 “S7”)(= to_num1 “T7”)
                       (= to_num1 “U7”)(= to_num1 “X7”)  )
                   (setq dd nil)
                   (princ (strcat “nInvalide. <” to_num1 “>not found. Try again!!”))
            );; while dd end
            (setq tn       to_num1
                  to_file  (open “z:/acad/data/to-hole.dat” “r”)
            (cond ((= tn “B10”)(setq aa 9 bb 4 cc 149 dd 3))((= tn “C9”)(setq aa 14 bb 3 cc 153 dd 3))
                  ((= tn “C10”)(setq aa 18 bb 3 cc 153 dd 3))((= tn “D8”)(setq aa 22 bb 3 cc 157 dd 3))
                  ((= tn “D9”)(setq aa 26 bb 3 cc 157 dd 3))((= tn “D10”)(setq aa30 bb 3 cc 157 dd 3))
                  ((= tn “E7”)(setq aa 34 bb 3 cc 161 dd 3))((= tn “E8”)(setq aa 38 bb 3 cc 161 dd 3))
                  ((= tn “E9”)(setq aa 42 bb 3 cc 161 dd 3))((= tn “F6”)(setq aa 46 bb 3 cc 165 dd 2))
                  ((= tn “F7”)(setq aa 50 bb 3 cc 165 dd 2))((= tn “F8”)(setq aa 54 bb 3 cc 165 dd 2))
                  ((= tn “G6”)(setq aa 58 bb 2 cc 168 dd 2))((= tn “G7”)(setq aa 61 bb 3 cc 168 dd 2))
                  ((= tn “H5”)(setq aa 64 bb 2 cc 171 dd 2))((= tn “H6”)(setq aa 67 bb 2 cc 171 dd 2))
                  ((= tn “H7”)(setq aa 70 bb 2 cc 171 dd 2))((= tn “H8”)(setq aa 73 bb 2 cc 171 dd 2))
                  ((= tn “H9”)(setq aa 76 bb 3 cc 171 dd 2))((= tn “H10”)(setq aa 80 bb 3 cc 80 dd 3))
                  ((= tn “JS5”)(setq aa 84 bb 4 cc 84 dd 4))((= tn “JS6”)(setq aa 89 bb 4 cc 89 dd 4))
                  ((= tn “JS7”)(setq aa 94 bb 4 cc 94 dd 4))((= tn “K5”)(setq aa  99 bb 2 cc 173 dd 2))
                  ((= tn “K6”)(setq aa 102 bb 2 cc 176 dd 2))((= tn “K7”)(setq aa 105 bb 2 cc 179 dd 2))
                  ((= tn “M5”)(setq aa 108 bb 2 cc 182 dd 2))((= tn “M6”)(setq aa 111 bb 2 cc 185 dd 2))
                  ((= tn “M7”)(setq aa 114 bb 2 cc 188 dd 2))((= tn “N6”)(setq aa 117 bb 2 cc 191 dd 2))
                  ((= tn “N7”)(setq aa 120 bb 2 cc 194 dd 2))((= tn “P6”)(setq aa 123 bb 2 cc 197 dd 2))
                  ((= tn “P7”)(setq aa 126 bb 2 cc 200 dd 2))((= tn “R7”)(setq aa 129 bb 3 cc 203 dd 2))
                  ((= tn “S7”)(setq aa 133 bb 2 cc 207 dd 3))((= tn “T7”)(setq aa 137 bb 3 cc 211 dd 3))
                  ((= tn “U7”)(setq aa 141 bb 3 cc 215 dd 3))((= tn “X7”)(setq aa 145 bb 2 cc 219 dd 2)) );;;
            (setq up_tor (/(atof (substr to_file1 aa bb)) 1000)
            (cond ((or (= tn-a “B”)(= tn-a “C”)(= tn-a “D”)(= tn-a “E”)
                       (= tn-a “F”)(= tn-a “G”))(setq up_sym “+” dn_sym “+”))
                  ((= tn-a “H”)(setq up_sym “+” dn_sym ”  “))
                  ((= tn-a “J”)(setq up_sym “+” dn_sym “-“))
                  ((= tn-a “K”)(setq up_sym “+” dn_sym “-“))
                  ((or (= tn-a “M”)(= tn-a “N”)(= tn-a “P”)(= tn-a “R”)
                       (= tn-a “S”)(= tn-a “T”)(= tn-a “U”)(= tn-a “X”))
            (if (= up_tor 0)(setq up_dd 0 up_sym ”  “))
            (if (= dn_tor 0)(setq dn_dd 0 dn_sym ”  “))
        ));; <progn end>
  ((= to_cmd “STand”)
   (progn
      (if (= stup_tor nil)(setq stup_tor “0.02”))(setq qstup_tor stup_tor)
      (if (= stdn_tor nil)(setq stdn_tor “0.01”))(setq qstdn_tor stdn_tor)
      (initget 1 “A B C D E”)
      (setq to_type (getkword “nTolerance type?(A/B/C/D/E):”))
      (cond ((= to_type “A”)(setq up_sym “+” dn_sym “+”))
            ((= to_type “B”)(setq up_sym “+” dn_sym ”  ” stdn_tor “0”))
            ((= to_type “C”)(setq up_sym ”  ” dn_sym “-” stup_tor “0”))
            ((= to_type “D”)(setq up_sym “-” dn_sym “-“))
            ((= to_type “E”)(setq up_sym “+” dn_sym “-“))  );;
      (if (or(= to_type “A”)(= to_type “B”)(= to_type “D”)(= to_type “E”))
          (setq stup_tor (getstring (strcat “nUpper tolerance<” up_sym stup_tor “>:”)))  );;
      (if (or(= to_type “A”)(= to_type “C”)(= to_type “D”)(= to_type “E”))
          (setq stdn_tor (getstring (strcat “nDowner tolerance<” dn_sym stdn_tor “>:”)))  );;
      (if (= stup_tor “”)(setq stup_tor qstup_tor))
      (if (= stdn_tor “”)(setq stdn_tor qstdn_tor))
      (setq up_txt (strcat up_sym stup_tor)
            dn_txt (strcat dn_sym stdn_tor) )        (initget 1)
   ));; <progn end>
  ((or (= to_cmd “SRSha”)(= to_cmd “SRHol”))
   (progn
      (initget 1 “Dia Wid”)
      (setq to_type (getkword “nDiameter/Width:”))
      (setq loop 5)
      (while loop
        (setq to_dia (getdist (strcat “nInput diameter<” (rtos to_dia 2 0) “>:”)))
        (cond ((= to_cmd “SRSha”)(setq ser_file “z:/acad/data/snapsha.dat”))
              ((= to_cmd “SRHol”)(setq ser_file “z:/acad/data/snaphol.dat”)) )
        (setq to_file  (open ser_file “r”)
              to_dmax  (substr to_file1 1 3) )
        (setq dd 5)
        (while dd
           (if (/= to_dia (atof to_dmax))
               (progn
                  (if (= to_dmax “END”)
                      (progn
                         (princ (strcat “nsnap-ring dia.(” (rtos to_dia 2 2)
                                        “)not found. Try agin!!”))
                         (setq dd nil)
               );;progn
               (setq dd nil)
           );; ==>if end
        );;    ==> while dd end
        (if (= to_dia (atof to_dmax))(setq loop nil))
     );; ==> while loop end <==
      (setq d1_tor (substr to_file1 16 4)
            m_tor  (substr to_file1 22 4)  )
             (progn
                (cond ((= to_type “Dia”)(setq up_txt ”  0″ dn_txt (strcat “-” d1_tor)))
                      ((= to_type “Wid”)(setq up_txt (strcat “+” m_tor) dn_txt ”  0″))
            ((= to_cmd “SRHol”)
             (progn
                (cond ((= to_type “Dia”)(setq up_txt (strcat “+” d1_tor) dn_tor ”  0″))
      )                                             (initget 1)
  ));; <progn end>
  ((= to_cmd “Key”)
   (progn
      (if (= key_tor nil)(setq key_tor “A”))
      (initget 1 “A B C D”)
      (prompt “nA:b1(Hole,N9)/B:b2(Shaft:js9)/C:b1,b2(P9)/D:t1,t2”)(terpri)
      (setq key_tor (getkword (strcat “nKey tolerance(A~D)<” key_tor “>:”)))
      (setq to_file  (open “z:/acad/data/key.dat” “r”)
      (cond ((= key_tor “A”)(setq up_txt (substr to_file1 30 6)
                                  dn_txt (substr to_file1 52 6))  )
            ((= key_tor “B”)(setq up_txt ” “
                                  dn_txt (strcat “%%P” (substr to_file1 59 6)))  )
            ((= key_tor “C”)(setq up_txt (substr to_file1 23 6)
                                  dn_txt (substr to_file1 45 6))  )
            ((= key_tor “D”)(setq up_txt (substr to_file1 66 4)
                                  dn_txt ”  0″))
      )                                             (initget 1)
  ));; <progn end>
  );; <cond end>
); defun end
  • 38 조회
