홈/ 질문/Q 99063
탱탱LV탱구
탱탱LV탱구Lv.0
등록일: 2013-08-092013-08-09T12:40:17+09:00 2013-08-09T12:40:17+09:00카테고리: AutoCAD & CADian
구름기호 리습 사용시 osnap이 다꺼지네요.
다른 분들 글 올리신거 참고해서 해보려고 했는데 잘 모르겠습니다ㅠㅠ
도와 주세요
클라우드 한번 쓰고 나면 osnap이 매번 꺼져서 새로 체크하고 하고 있습니다.
기존 osnap 설정 해놨던거로 그대로 살아나거나
아니면 내가 쓰는 osnap 항목들은 다시 on off 할 수 있는 명령으로 하고 싶습니다.
주로 끝점 중간점 중심점 사분점 교차점 직교 만 쓰고 있습니다.
;=====================================================CLOUD=================================
;;;  PL2Cloud.lsp by Charles Alan Butler
;;;         Copyright 2005
;;;  by Precision Drafting & Design All Rights Reserved.
;;;  Contact at ab2draft@TampaBay.rr.com
;;;   Version 1.0 Beta  May 1,2004
;;;   Version 1.1 Beta  May 5,2004
;;;      Added options to size the arc
;;;   Version 1.2 Beta  May 19,2004
;;;      Added option for cloud style
;;;   Version 1.3 Beta  June 15,2004
;;;      Revised to use Dialog Box Interface
;;;   Version 1.4 Beta  June 23,2004
;;;      Dialog Box Revisions
;;;   Version 1.5 Beta  September 16,2004
;;;      Incorperated the Dialog File Creator Routine
;;;      Disabled the Chord Length DimScale feature
;;;   Version 2.0 October 22,2004
;;;      Support for arcs polylines and will also process a picked
;;;      spline, circle or ellipse
;;;   Version 2.0 October 27,2004
;;;      Pline width bug, preset width set to 0 for user draw.
;;;   Version 2.1 February 23,2005
;;;      Added multiple pick of new cloud, bug fix – remember chord length
;;;   Version 2.2 February 24,2005
;;;      Added support for rotated UCS
;;;   Version 2.3 October 27,2005
;;;      Added Layer Selection for cloud
;;;   Version 2.4 April 04,2006
;;;      Added Help & option to use pline layer, plus clean up of code
;;;   Version 2.5 September 25,2006
;;;      Bug Fix, CW pline caused when followed by a CCW
;;; DESCRIPTION
;;; User picks or Draws a LW polyline and the routine draws a revision
;;; cloud along it, User option to delete the original polyline
;;; No UCS supported, Only World
;;;  Files Required to be in the ACAD search path
;;;     pl2cloud.dcl  ; note- created by this lisp
;;;     rc_normal.sld ; slides are found in the zip file
;;;     rc_shadow.sld
;;;     rc_length.sld
;;;  Limitations
;;;  No error checking when object pline is too small
;;; Command Line Usage
;;; Command: PL2Cloud
;;;          Dialog Box is displayed unless there is a problem
;;;          Then the command line version is as follows
;;;          Enter method to get polyline. [Pick / Draw / Options / Shadow] <Pick>:
;;;          Keep the original polyline [Yes No] <No>:y
;;;          Pick Polyline to cloud:
;;;  Options: Command Line Version
;;;    Pick – allows user to pick an existing poly line
;;;    Draw – allows user to draw a new polyline
;;;    Shadow – toggles the shadow effect on/off
;;;    Options – Change Arc Angle, makes arcs fatter or thinner
;;;              Change the chord length of the arcs
;;;     Enter a new Chord length or negative number to divide into DimScale
;;;     Enter the actual chord length desired or
;;;     enter a negative number and that number will be divided into
;;;      the current dimscale to derive the chord length
;;;  This software is provided “as is” without express or implied      ;
;;;  warranty.  All implied warranties of fitness for any particular   ;
;;;  purpose and of merchantability are hereby disclaimed.             ;
;;;  You are hereby granted permission to use, copy and modify this    ;
;;;  software without charge, provided you do so exclusively for       ;
;;;  your own use or for use by others in your organization in the     ;
;;;  performance of their normal duties, and provided further that     ;
;;;  the above copyright notice appears in all copies and both that    ;
;;;  copyright notice and the limited warranty and restricted rights   ;
;;;  notice appear in all supporting documentation.                    ;
(prompt “Loading PL2Cloud….”)
(defun c:cl2 (/         dscale    plw       dist      spcs
                   usercmd   useros    *error*   a270      a90
                   userbm    oer       oldplw    ent       entlst
                   oldent    method    keeppl    useds     arcang
                   chord     cloud_style         draw_style Plreverse
                   keeppl    cur_lay   PlineLay  cur_lay_old
  (defun *error* (msg)
    (if
      (not
        (member
          msg
          ‘(“console break” “Function cancelled” “quit / exit abort” “”)
       (princ (strcat “nError: ” msg))
    ) ; if
    (setvar “Plinewid” oldplw)
    (setvar “blipmode” userbm) ;reset blipmode
    (setvar “CMDECHO” usercmd)
    (setvar “osmode” useros)
    (setq pl2cloudglobal (put_saved_vars)
          userbm  nil
          oldplw  nil
          usercmd nil
          useros  nil
  ) ;end error function
  • 28 조회
