(defun $delta_a (%_c %_a)
(sqrt (- (expt %_c 2) (expt %_a 2)))
(defun #ssadd (#ent1 / #ssent)
(setq #ssent (ssadd))
(ssadd #ent1 #ssent)
(while #ent1
(setq #ent1 (entnext #ent1))
#ssent
(defun c:ti ()
(setvar “cmdecho” 0)
(setq $old_textstyle (getvar “TEXTSTYLE”))
(if (= nil (tblsearch “style” “굴림체”))
(COMMAND “STYLE” “굴림체” “굴림체” “0” “0.85” “0” “n” “n”)
(if (= nil (tblsearch “style” “돋움”))
(COMMAND “STYLE” “돋움” “돋움” “0” “0.85” “0” “n” “n”)
(if (= nil (tblsearch “block” “time”))
(progn
(command “donut” 26.8 27.2 “0,0” “”)
(setq $time_en1 (entlast))
(command “donut” 38.8 39.2 “0,0” “”)
(command “line” ‘(0 13.5) “@6<90” “”)
(command “array” (entlast) “” “p” ‘(0 0) “24” “360” “y”)
(command “line” ‘(0 13.5) “@2<90” “”)
(command “rotate” (entlast) “” ‘(0 0) “3.75”)
(setq $ent_1 (entlast))
(command “array” (entlast) “” “p” ‘(0 0) “3” “7.5” “y”)
(command “array” (entlast) (entnext $ent_1) $ent_1 “” “p” ‘(0 0) “24” “360” “y”)
(setq ii 1
ai (- 7.5)
(repeat 24
(command “text” “j” “m” ‘(0 17.5) “2.5” “0” (rtos ii 2 0))
(command “rotate” (entlast) “” ‘(0 0) ai)
(setq ii (1+ ii)
ai (- ai 15)
(command “block” “time” ‘(0 0) (#ssadd $time_en1) “”)
(if (= nil (tblsearch “block” “date”))
(progn
(command “line” (list (- ($delta_a 13.5 4)) 4) (list ($delta_a 13.5 4) 4) “”)
(setq $date_en1 (entlast))
(command “line” (list (- ($delta_a 13.5 4)) (- 4)) (list ($delta_a 13.5 4) (- 4)) “”)
(command “pline” ‘(0 6) “w” “2.2” “2.2” “@2.75<90” “w” “4.65” “0” “@2.75<90” “”)
(setvar “TEXTSTYLE” “돋움”)
; (command “text” “j” “m” ‘(0 8) “3.1” “0” “출 도”)
(command “text” “j” “Fit” ‘(-7 6.2) ‘(7 6.2) “3.1” “출 도”)
(command “text” “j” “M” ‘(0 -7.5) “2.5” “0” “(주) E & EC”) ;;==>”(주) E & EC”는 업체명이므로 변경 가능
; (command “text” “j” “Fit” ‘(-10 -7.7) ‘(10 -7.7) “2.5” “원신기계공업(주)”)
(command “block” “date” “0,0” (#ssadd $date_en1) “”)
(C:L0)
(setq #insp (getpoint “nInsert Point : “))
(setq #cd (rtos (getvar “cdate”) 2 8)
#cdate (strcat (substr #cd 1 4) “.” (substr #cd 5 2) “.”
(substr #cd 7 2))
#tih (atoi (substr #cd 10 2))
#tim (atoi (substr #cd 12 2))
#_ang (+ (* 15 (1- #tih)) (* 3.75 (/ #tim 15.0)))
(command “text” “J” “M” #insp 4 “0” #cdate)
(command “insert” “time.dwg” #insp 1 1 #_ang)
(command “insert” “date.dwg” #insp 1 1 0)
(setvar “TEXTSTYLE” $old_textstyle)
(defun c:L0 ()
(command “layer” “m” “0” “”)
날짜 글자 크기 수정하는 구간이 궁금합니다.
리습을 처음접하던시절 만든건데 반갑네요~~출도리습 원작자 입니다.
요지는 시간이 돌아간다는거지요..
