홈/ 질문/Q 172663
cad견적적적
cad견적적적Lv.0
등록일: 2022-10-062022-10-06T14:01:33+09:00 2022-10-06T14:01:33+09:00카테고리: AutoCAD & CADian
길이 합산 리습인데.. 동일한길이 객체는 각각 객체 수를 산정 하는게 아니라 하나로 인식합니다..각각 객체수 계산되게 수정좀 부탁드립니다. ㅠㅠ
(defun c:FF (/ ss sslist i index linelist linenumlist ent old10 old11 dist lnum count temp total total1 subtotal txt pt)
;—->total1 추가함
(princ “\\n Eltity Length Sum”)
(setvar “cmdecho” 0)
(setq ss (ssget (list (cons 0 “LINE,CIRCLE,ARC,POLYLINE,LWPOLYLINE,ELLIPSE,SPLINE”))))
(if ss
(progn
(setq index 0)
(setq linelist nil)
(setq linenumlist nil)
(repeat (sslength ss)
(setq ent (ssname ss index))
(command-s “lengthen” ent “” “” “”)
(setq dist (GETVAR “PERIMETER”))
(if (apply ‘or (mapcar ‘(lambda (x) (equal dist x 1)) linelist))
(progn
(setq temp 0)
(setq lnum nil)
(foreach x linelist
(if (equal dist x 1)
(setq lnum temp)
(setq temp (1+ temp))
(setq count 0)
(setq temp nil)
(foreach x linenumlist
(if (= count lnum)
(setq temp (append temp (list (+ x 1))))
(setq temp (append temp (list x)))
(setq count (1+ count))
(setq linenumlist temp)
(progn
(setq linelist (append linelist (list dist)))
(setq linenumlist (append linenumlist (list 1)))
(setq index (1+ index))
(setq txt “”)
(setq count 0)
(setq total 0)
(setq subtotal 0)
(repeat (length linelist)
(if (= count 0)
(if (> (nth count linenumlist) 1)
;;;;(setq txt (strcat “\\nL = ” (rtos (/ (nth count linelist) 1.0) 2 3) “*” (rtos (nth count linenumlist) 2 0) “개”))
;;;;(setq txt (strcat “\\nL = ” (rtos (/ (nth count linelist) 1.0) 2 3)))
(setq txt (strcat “\\nL = ” (rtos (/ (nth count linelist) 1000.0) 2 3) “*” (rtos (nth count linenumlist) 2 0) “개”))
(setq txt (strcat “\\nL = ” (rtos (/ (nth count linelist) 1000.0) 2 3)))
;;;;(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1.0) 2 3) “*” (rtos (nth count linenumlist) 2 0) “개”))
;;;;(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1.0) 2 3)))
(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1000.0) 2 3) “*” (rtos (nth count linenumlist) 2 0) “개”))
(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1000.0) 2 3)))
(setq subtotal (* (/ (nth count linelist) 1) (nth count linenumlist)))
(setq total (+ subtotal total))
(setq total1 (/ total 1000));————->추가함
;;;;(setq txt (strcat txt ” = ” (rtos total 2 3) “m”))
(setq txt (strcat txt ” = ” (rtos total1 2 3) “m”));——->total에서 total1 변경함
(setq txt (strcat txt ” : 객체수 ” (rtos (length linelist) 2 +0) ” 개”))
(princ txt)
(if (not (setq tth (getreal (strcat “\\n현재 TextSize : <” (rtos(getvar “textsize”) 2 1) “> 입니다. 원하는 Text 크기를 입력하세요 : “))))
(setq tth (getvar “textsize”))
(setvar “textsize” tth)
(setq pt (getpoint “\\n 텍스트 삽입점 : “))
(if pt (command “text” pt “” “” txt))
  • 111 조회
