홈/ 질문/Q 113277
등록일: 2021-08-132021-08-13T13:26:01+09:00 2021-08-13T13:26:01+09:00카테고리: AutoCAD & CADian
도면 작성 리습인데 다른 캐드 버전에서는 사용이 안됩니다.
2019 AUTO CAD 에서는 잘 실행이 되는데 2020 AUTO CAD에서는 오류가 발생합니다.
리습 한번 봐주시면 감사하겠습니다.
(defun c:nm40_200 ()
 (getvar “cmdecho”)
 (setvar “cmdecho” 0)
 ;Turn OFF all layers
 (command “_layer” “off” “*” “y” “”)
 ;Delete unnecessary layers
 (command “_laydel” “Name” “80” “” “Yes” “”)
 ;Alignment die details
 ;Set layers color
 ;Set layer objects to layer 0
 (command “_layer” “on” “100” “”)
 (command “_chprop” “w” “-13490,2410” “-4510,11390” “” “Color” “40” “Layer” “SHEET5” “”)
 (command “_chprop” “w” “4510,2410” “13490,11390” “” “Color” “40” “Layer” “SHEET5” “”)
 (command “erase” “w” “-4490,2410” “4490,11390” “”)
 ;Die pad details
 (command “_layer” “on” “60” “”)
 (command “_layer” “on” “70” “”)
 (command “_chprop” “w” “-4490,2410” “4490,11390” “” “Color” “7” “Layer” “SHEET3” “”)
 ;Delete empty layers
 (command “_laydel” “Name” “100” “” “Yes” “”)
 (command “_laydel” “Name” “60” “” “Yes” “”)
 (command “_laydel” “Name” “70” “” “Yes” “”)
 ;Turn ON layer “SHEET5”
 (command “_layer” “on” “SHEET5” “”)
 (command “_layer” “on” “Template” “”)
 ;Scale objects to fit template
 (setq tdie (+ die 20))
 (setq adsfactor1 (/ 1600 tdie))
 (setq adsfactor2 (/ 1600 die))
 (command “_scale” “w” “-13490,2410” “-4510,11390” “” “-9000,6900” adsfactor1)
 (command “_scale” “w” “4510,2410” “13490,11390” “” “9000,6900” adsfactor1)
 ;Move to template locations
 (command “_move” “w” “-13490,2410” “-4510,11390” “” “-9000,6900” “-2600,1600”)
 (command “_move” “w” “4510,2410” “13490,11390” “” “9000,6900” “2600,1600”)
 ;Turn ON layer “SHEET3”
 (command “_layer” “on” “SHEET3” “”)
 ;Scale die pad reference object to fit template
 (command “_scale” “w” “-4490,2410” “4490,11390” “” “0,6900” adsfactor2)
 ;Move die pad reference to template locations
 (command “_move” “w” “-4490,2410” “4490,11390” “” “0,6900” “2600,1600”)
 ;Delete templates
 (command “_laydel” “Name” “Template” “” “Yes” “”)
 (command “zoom” “extents”)
 (command “_layer” “on” “*” “”)
 (getvar “cmdecho”)
 (setvar “cmdecho” 1)
  • 33 조회
