홈/ 질문/Q 108747
등록일: 2017-08-092017-08-09T09:47:32+09:00 2017-08-09T09:47:32+09:00카테고리: AutoCAD & CADian
도움 요청드립니다.
안녕하세요.
오랫동안 잘 사용해온 리습인데..
사용하다보니 글씨가 너무 작아서 잘 안보이네요..;;;
리습을 뚫어져라 봤는데.. 텍스트 크기 조정(?)을 어떻게 해야할지 몰라 이렇게 도움 요청드립니다.
리습은 TotalADD(TADD)고 인터넷에서 쉽게 구할수 있는 리습입니다.
 TotalADD Total Addition v. 1.0    ;;
 By: Andrea Andreetti  2009-10-20  ;;
(princ
  “nTotalADDition v.1.0 activated!   -run ”TADD” to start or ”TADD-r” to end.”
(defun c:taaa (/                     itemarea              itemperimeter         itemlinelength
               itemarclength         itemsplinelength      itemregionperimeter   itemcircumference
               itemsplineperimeter   itemplineperimeter    itemplinelength       itemtracelength
               itemarclength         itemellipselength a b c d p1 p2 itemlength tarea tperim tlength
  (vl-load-com)
  (defun *oo_object_modification* (objreactor objectsmodified)
    (setq selected_objects (vla-get-pickfirstselectionset
                             (vla-get-activedocument (vlax-get-acad-object))
    (setq itemarea 0
          itemperimeter 0
          itemlinelength 0
          itemarclength 0
          itemsplinelength 0
          itemregionperimeter 0
          itemcircumference 0
          itemsplineperimeter 0
          itemplineperimeter 0
          itemplinelength 0
          itemtracelength 0
          itemarclength 0
          itemellipselength 0
    ;AREA
    (vlax-for n selected_objects
      (if (vlax-property-available-p n ‘area)
        (if (eq (vla-get-objectname n) “AcDbRegion”)
          (setq itemarea (+ itemarea (vla-get-area n)))
          (if (vlax-curve-isclosed n)
      ;;CIRCLE
      (if (vlax-property-available-p n ‘circumference)
        (setq itemcircumference (+ itemcircumference (vla-get-circumference n)))
      ;;SPLINE
      (if (eq (vla-get-objectname n) “AcDbSpline”)
          (setq itemsplineperimeter (+ itemsplineperimeter
                                       (vlax-curve-getdistatparam n (vlax-curve-getendparam n))
          (setq itemsplinelength (+ itemsplinelength
      ;;REGION
        (setq itemregionperimeter (+ itemregionperimeter (vla-get-perimeter n)))
      ;;PLINE
      (if (or (eq (vla-get-objectname n) “AcDb2dPolyline”)
              (eq (vla-get-objectname n) “AcDbPolyline”)
          (setq itemplineperimeter (+ itemplineperimeter
          (setq itemplinelength (+ itemplinelength
      ;;LINE
      (if (eq (vla-get-objectname n) “AcDbLine”)
        (setq itemlinelength (+ itemlinelength (vla-get-length n)))
      ;;ARC
      (if (eq (vla-get-objectname n) “AcDbArc”)
        (setq itemarclength (+ itemarclength (vla-get-arclength n)))
      (if (eq (vla-get-objectname n) “AcDbEllipse”)
        (setq itemellipselength (+ itemellipselength
      ;;TRACE
      (if (eq (vla-get-objectname n) “AcDbTrace”)
        (progn (setq plist (vlax-safearray->list
                             (vlax-variant-value (vla-get-coordinates n))
               (setq a (list (nth 0 plist) (nth 1 plist) (nth 2 plist)))
               (setq b (list (nth 3 plist) (nth 4 plist) (nth 5 plist)))
               (setq c (list (nth 6 plist) (nth 7 plist) (nth 8 plist)))
               (setq d (list (nth 9 plist) (nth 10 plist) (nth 11 plist)))
               (setq p1 (polar a (angle a b) (/ (distance a b) 2.0)))
               (setq p2 (polar c (angle c d) (/ (distance c d) 2.0)))
               (setq itemtracelength (+ itemtracelength (distance p1 p2)))
    ;;_end vlax-for
    (setq itemperimeter (+ itemcircumference
                           itemsplineperimeter
                           itemregionperimeter
                           itemplineperimeter
    (setq itemlength (+ itemplinelength itemsplinelength itemlinelength itemtracelength itemarclength itemellipselength)
    (setq tarea (rtos itemarea 2 8))
    (setq tperim (rtos itemperimeter 2 8))
    (setq tlength (rtos itemlength 2 8))
    (acet-ui-status (strcat “Toatl Area:  ” tarea “n” “Total Perimeter:  ” tperim “n”
                            “Total Length:  ” tlength)
  ;;OBJECT SELECTION
  (if oo_object_modification
    (progn (vlr-remove oo_object_modification)
           (setq oo_object_modification nil)
         (vlr-miscellaneous-reactor
           nil
           ‘((:vlr-pickfirstmodified . *oo_object_modification*))
  ;;Command ended
  (if oo_object_modification_action
    (progn (vlr-remove oo_object_modification_action)
           (setq oo_object_modification_action nil)
         (vlr-command-reactor nil
                              ‘((:vlr-commandended . *oo_object_modification*)
 ;(:vlr-commandcancelled . *oo_object_modification_CANCEL*))
(defun c:TADD-r ()
첨부와 같이 박스의 크기와 텍스트를 어떻게 크게 할 수 있을까요?
답변 부탁드립니다.
감사합니다.
  • 32 조회
