홈/ 질문/Q 25390
등록일: 2008-06-132008-06-13T13:13:46+09:00 2008-06-13T13:13:46+09:00카테고리: AutoCAD & CADian
리습검토부탁드립니다.–에러도없는데 실행이 안됩니다.
;;lisp_init에 관한 지정
(defun lisp_init ()
;/* System_Variable_Save */
(setq PI 3.14159265358979323846)
(setq cu_osm (getvar “osmode”) ;/* Current Osnap */
cu_oco (getvar “cecolor”) ;/* Current Color */
cu_oli (getvar “celtype”) ;/* Current LineType */
cu_ola (getvar “clayer”) ;/* Current Layer */
cu_oor (getvar “orthomode”) ;/* Current orthomode */
cu_osa (getvar “snapang”) ;/* Current Snap Angle */
cu_ohl (getvar “highlight”) ;/* Current highlight */
cu_osb (getvar “snapbase”) ;/* Current Snap Base */
cu_obi (getvar “blipmode”) ;/* Current blipmode */
cu_pic (getvar “pickbox”) ;/* Current pickbox */
cu_ape (getvar “aperture”) ;/* Current aperture */
cu_pwid (getvar “plinewid”) ;/* Current Pline Width */
cu_sunit (getvar “snapunit”)
cu_dle (getvar “dimdle”)
cu_dli (getvar “dimdli”)
cu_exe (getvar “dimexe”)
cu_exo (getvar “dimexo”)
cu_post (getvar “dimpost”)
cu_scale (getvar “dimscale”)
cu_se1 (getvar “dimse1”)
cu_se2 (getvar “dimse2”)
cu_tad (getvar “dimtad”)
cu_tih (getvar “dimtih”)
cu_tix (getvar “dimtix”)
cu_tofl (getvar “dimtofl”)
cu_toh (getvar “dimtoh”)
cu_tol (getvar “dimtol”)
cu_tsz (getvar “dimtsz”)
cu_txt (getvar “dimtxt”)
(setvar “cmdecho” 0)
(setvar “blipmode” 0)
(setvar “osmode” 0)
(setvar “snapunit” ‘(1 1))
(command “undo” “Group”) (princ ” n”)
; Internal error handler defined locally
(defun curr_err (s) ;;; If an error (such as CTRL-C) occurs while this command is active…
; (if (/= s “Function cancelled”) (if (= s “quit / exit abort”) (princ) (print (strcat “n>> Error: ” s))))
(setvar “osmode” cu_osm)
(setvar “cecolor” cu_oco)
(setvar “celtype” cu_oli)
(setvar “clayer” cu_ola)
(setvar “orthomode” cu_oor)
(setvar “snapang” cu_osa)
(setvar “highlight” cu_ohl)
(setvar “snapbase” cu_osb)
(setvar “blipmode” cu_obi)
(setvar “pickbox” cu_pic)
(setvar “aperture” cu_ape)
(setvar “plinewid” cu_pwid)
(setvar “snapunit” cu_sunit)
;(setvar “dimblk1” cu_dblk1)
;(setvar “dimblk2” cu_dblk2)
(setvar “dimdle” cu_dle)
(setvar “dimdli” cu_dli)
(setvar “dimexe” cu_exe)
(setvar “dimexo” cu_exo)
(setvar “dimpost” cu_post)
(setvar “dimscale” cu_scale)
(setvar “dimse1” cu_se1)
(setvar “dimse2” cu_se2)
(setvar “dimtad” cu_tad)
(setvar “dimtih” cu_tih)
(setvar “dimtix” cu_tix)
(setvar “dimtofl” cu_tofl)
(setvar “dimtoh” cu_toh)
(setvar “dimtol” cu_tol)
(setvar “dimtsz” cu_tsz)
(setvar “dimtxt” cu_txt)
(setq *error* ErrSav)
(command “undo” “_en”)
; Set our new error handler
(setq ErrSav *error* *error* curr_err)
;;;;lisp_reco에 관한 지정
(defun lisp_reco ()
(defun dtr (a) (* 3.14159265358979323846 (/ a 180.0)))
(defun rtd (a) (/ (* a 180.0) 3.14159265358979323846))
;;———————————————————————-;;본문 시작
(defun c:cle ( / edges ext1 ent m ename elist esp eep
n bname blist bsp bep int lts)
(graphscr)
(print “CLE – Center Line Extend”)
(lisp_init)
(setvar “osmode” 0)
(setq edges T)
(setq lts (getvar “ltscale”))
(if (not clm_ext) (setq clm_ext (* lts 8.0)))
(setq ext1 (getreal (strcat (msgtable 411 ;|”n>> Extension length “|;) “<" (rtos clm_ext) "> : “)))
(if (not ext1) (setq ext1 clm_ext))
(setq clm_ext ext1)
(if (< clm_ext 0.0)
(progn
(princ (msgtable 392 ;|”n>> Error : Extension length must be positive number.”|;))
(exit)
(while edges
(princ (msgtable 642 ;|”n>> Press Enter or space bar, then command is cancelled.”|;))
(princ (msgtable 692 ;|”n>> Select boundary edge(s)…”|;))
(setq edges (ssget))
(if edges
(progn
(setq ent T)
(while ent
(princ (msgtable 749 ;|”n>> Select object to extend : “|;))
(setq ent (ssget))
(if ent
(progn
(setq m 0)
(repeat (sslength ent)
(setq ename (ssname ent m))
(setq elist (entget ename))
(if (= (cdr (assoc 0 elist)) “LINE”)
(progn
(setq esp (cdr (assoc 10 elist)))
(setq eep (cdr (assoc 11 elist)))
(setq n 0)
(repeat (sslength edges)
(setq bname (ssname edges n))
(setq blist (entget bname))
(if (= (cdr (assoc 0 blist)) “LINE”)
(progn
(setq bsp (cdr (assoc 10 blist)))
(setq bep (cdr (assoc 11 blist)))
(setq int (inters esp eep bsp bep nil))
(if int
(cex_line esp eep clm_ext elist int)
) ; end if – edge
(setq n (1+ n))
) ; end repeat – edges
) ; end if
(setq m (1+ m))
) ; end repeat – ent
) ; end progn
) ; end if – ent
) ; end while – ent
) ; end if – edges
) ; end while – edges
(redraw)
(lisp_reco)
(PRINC)
) ; end cex ()
(defun cex_line ( sp ep ext ent int / dist1 dist2 np)
(if (< (distance int sp) (distance int ep))
(progn
(setq dist1 (distance ep sp))
(setq dist2 (+ (distance ep int) ext))
(if (< dist1 dist2)
(progn
(if (< (distance ep sp) (distance ep int))
(setq ang (angle sp int))
(setq ang (angle int sp))
(setq np (polar int ang ext))
(setq ent (subst (cons 10 np) (assoc 10 ent) ent))
(progn
(setq dist1 (distance sp ep))
(setq dist2 (+ (distance sp int) ext))
(if (< dist1 dist2)
(progn
(if (< (distance sp ep) (distance sp int))
(setq ang (angle ep int))
(setq ang (angle int ep))
(setq ent (subst (cons 11 np) (assoc 11 ent) ent))
) ; end if
(entmod ent)
) ; end cex_line ()
(princ ” CLE loaded.”)
에러도 없고 아무이상없는데 실행이 안되네요
필요한 변수가 하나더 있어야 하는지 알수가 없네요
내용은 기준선 하나를 선택하고 기준선보다 더 연장시킬길이를
입력하면 그 기준선앞으로 입력한길이만큼 라인을 더 뽑아주는건데..
꼭 필요한데…안되네요..ㅠ.ㅠ
검토좀 부탁드립니다. 벌써 일주일째 이거같고 끙끙되네요…ㅠ.ㅠ
  • 23 조회
    • 선배님들 덕트 엘보 작성 리습좀 봐주세요
