홈/ 질문/Q 98916
등록일: 2013-07-232013-07-23T17:02:02+09:00 2013-07-23T17:02:02+09:00카테고리: AutoCAD & CADian
리습문 좀 봐주세요~
안녕하세요. 위 그림과 같이
각각의 선의 시작점 또는 끝점 버텍스들을 다른 선의 시작점 또느 끝점으로 버텍스를 이동하는
리습문을 만들고 있는데요.
아래의 빨간색 구문이 계속 무한반복이 됩니다.
어떤 문제가 있을까요??
(defun c:pl_paste ()
  (setq i 0)
  (setq sel (ssget (list (cons 0 “lwpolyline”))))
  (while (< i (sslength sel))
 (setq a 0)
 (setq selname (ssname sel i))
 (setq s_handle (cdr (assoc 5 (entget selname))))
 (setq s_xy (vlax-curve-getstartpoint selname))
 (setq e_xy (vlax-curve-getendpoint selname))
 (object_search s_Xy 5)
 (setq First_sel (ssget “cp” pt_list (list (cons 0 “lwpolyline”))))
 (if (= First_sel nil)
   (progn
  (object_search e_xy 5)
  (setq Second_sel (ssget “cp” pt_list (list (cons 0 “lwpolyline”))))
  (if (> (sslength Second_sel) 1)
    (progn
   (setq x_list (vl-sort pt_list (function (lambda (n1 n2)(< (car n1)(car n2))))))
   (setq y_list (vl-sort pt_list (function (lambda (n1 n2)(< (cadr n1)(cadr n2))))))
   (setq min_x (car (nth 0 x_list)))
   (setq max_x (car (nth 3 x_list)))
   (setq min_y (cadr (nth 0 y_list)))
   (setq max_y (cadr (nth 3 y_list)))
   (while (< a (sslength Second_sel))
     (setq second_selname (ssname Second_sel a))
     (setq e_handle (cdr (assoc 5 (entget second_selname))))
     (if (= s_handle e_handle)
    (progn
      (setq a (+ a 1))
    (progn
      (setq start_xy (vlax-curve-getstartpoint second_selname))
      (setq end_xy (vlax-curve-getendpoint second_selname))
      (if (and (and (< (car start_xy) max_x)(> (car start_xy) min_x)) (and (< (cadr start_xy) max_y)(> (cadr start_xy) min_y)))
     (progn
       (if (/= start_xy e_xy)
      (progn
        (command “_pedit” second_selname “e” “m” e_xy “x” “”)
      (progn)
     (progn
       (if (/= end_xy e_xy)
      (progn
        (setq end_param (vlax-curve-getendparam second_selname))
        (command “_pedit” second_selname “e”)
        (repeat end_param (command “n”))
        (command “m” e_Xy “x” “”)
      (progn)
    (progn)
  (setq i (+ i 1))
   (progn
  (if (> (sslength first_sel) 1)
    (progn
   (while (< a (sslength First_sel))
     (setq First_selname (ssname First_sel a))
     (setq e_handle (cdr (assoc 5 (entget First_selname))))
    (progn
      (setq a (+ a 1))
    (progn
      (setq start_xy (vlax-curve-getstartpoint First_selname))
      (setq end_xy (vlax-curve-getendpoint First_selname))
     (progn
       (if (/= start_xy s_xy)
      (progn
        (command “_pedit” First_selname “e” “m” s_xy “x” “”)
      (progn)
     (progn
       (if (/= end_xy s_xy)
      (progn
        (setq end_param (vlax-curve-getendparam First_selname))
        (command “_pedit” First_selname “e”)
        (repeat (fix end_param) (command “n”))
        (command “m” s_Xy “x” “”)
      (progn)
    (progn)
  (setq i (+ i 1))
 (princ (strcat “rProccesing…….” (itoa i) “/” (itoa (sslength sel))))(princ)
  • 20 조회
    등록일: 2013-05-212013-05-21T16:57:02+09:00 2013-05-21T16:57:02+09:00카테고리: AutoCAD & CADian
    리습문 좀 봐주세요~
    1.
    2.
    (defun c:test ()
    (setvar “cmdecho” 0)
    (setq se (Ssget (list (cons 8 “district1”))))
    (setq Dname (ssname se 0))
    (Setq ed_param (vlax-curve-getEndParam Dname))
    (setq B 0)
    (while (< B ed_param)
    (setq se_pa (vlax-curve-getPointAtParam Dname B))
    (Setq pt_list (append pt_list(list se_pa)))
    (Setq B (+ B 1))
    (setq sel_point (ssget “_cp” pt_list (list (cons 8 “point”)(cons 0 “Point”))))
    안녕하세요.
    위 그림과 같이 노란색 구역의 버텍스 좌표값 리스트를 추출하여
    구역 내에 있는 포인트만 선택 세트를 생성 하는 리습문을 작성 하였습니다.
    2번째 그림을 참고하시면 파랑색 포인트는 구역 내에 있는 포인트 이고, 빨간색 포인트는 구역 외에 있는 포인트 입니다.
    리습문을 실행 한 결과 노란색 구역 외에 있는 빨간색 포인트도 선택세트에 추가가 되어 있습니다.
    어떤 문제가 있는지 궁금합니다.
    • 0 조회
      등록일: 2011-08-082011-08-08T11:19:48+09:00 2011-08-08T11:19:48+09:00카테고리: AutoCAD & CADian
      리습문 좀 봐주세요..^^
      안녕하세요~ 리습을 이제 막 공부하기 시작했습니다.
      아래 리습문을 작성해보았습니다.
      리습 내용은 해당레이어의 속정정보와 좌표값들을 불러와서 list에 담는 리습문인데요
      질문이 있어서요..
      list에 담은 값들을 표출시켜보았는데 마지막 값만 표출이 되더라구요
      첫번째 값들 부터 마직막 값 까지 모두 표출시킬수는 없을까요??
      ex)1번째 값
            2번째 값
           n번째 값
      이런식으로 값을 표출 시킬수는 없는지..
      궁금해서 질문 올립니다~
      (defun c:link_test ()
       (setq i 0)
         (setq n 0)
         (setq sel (ssget (list (cons 0 “LWPOLYLINE”))))
         (setq sel_name(ssname sel n))
         (while (/= sel_name nil)
        (setq vtx_geo(vlax-curve-getpointatparam sel_name i))
        (if (/= vtx_geo nil)
          (progn
         (setq link_info (ade_odgetfield sel_name “Default_LINK” “LINK_ID” 0))
         (setq vtx(vlax-curve-getpointatparam sel_name i))
         (setq vtx_1(car vtx_geo))
         (setq vtx_2(cadr vtx_geo))
         (setq lst (list link_info i vtx_1 vtx_2))
         (setq i (+ i 1))
          (progn
         (setq n (+ n 1))
         (setq i 0)
        (princ lst)(princ)
      • 0 조회
