홈/ 질문/Q 112444
등록일: 2020-06-242020-06-24T13:05:32+09:00 2020-06-24T13:05:32+09:00카테고리: AutoCAD & CADian
리습 및 명령러 드림이 작동되지 않아요
캐드를 실행후 작업을 한뒤 저장하고 다시 실행을 하면
첨부파일 처럼 저렇게 명령어,리습,드림이 먹히지 않습니다.
하지만 캐드를 따로 실행하여 복붙하면 평소처럼 잘 돌아가지만,
그 파일을 저장후 다시 실행하면 다시 반복이네요
해결방법좀 한수 가르쳐 주세요
이미지 첨부를 하려 했으나 되지 않는 관계로 텍스트로 올리겠습니다.
Opening an AutoCAD 2004 format file.
Regenerating model.
Initializing VBA System…
Loading VBA startup file…
Initializing….
….Done.
Runtime Extension ‘C:Program FilesAutodesk Map 2004AcVba.arx’ is already
loaded.
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command: ; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on exception
*Cancel*
Command: properties
Command: _MAPWSPACE
Workspace <On>/oFf :_O
Workspace is visible.
Command:
Command:
Command: _ai_selall Unknown command “AI_SELALL”.  Press F1 for help.
Command:
Command:
Command: cxx
Unknown command “CXX”.  Press F1 for help.
Command: xf
Unknown command “XF”.  Press F1 for help.
Command: Specify opposite corner:
Command:
Command:
  • 121 조회
