홈/ 질문/Q 104331
등록일: 2015-06-152015-06-15T10:14:13+09:00 2015-06-15T10:14:13+09:00카테고리: AutoCAD & CADian
리습 소수점 4자리까지 계산 하도록 하고 싶습니다 ㅠㅠ
;  Number plus(98CHO_I)
;  ->두 수의 합 구하기
(defun c:+(/ choi d_ts w_os ht ss grpt pt1 n k tot en tv rtv an)
   (setq choi (getvar “orthomode”)  d_ts (getvar “textsize”)
            w_os (getvar “osmode”) )
   (setvar “orthomode” 0) (setvar “osmode” 0)
   (setq ht d_ts)
   (prompt “nText Height<“) (prin1 ht) (prompt “>: “)
   (setq ht (getdist))
   (if (= ht nil) (setq ht d_ts))
   (prompt “nSelect number->”)
   (setq ss (ssget))
   (setq grpt (grread T))
   (setq pt1 (cadr grpt))
   (setq n (sslength ss))
   (setq k 0 tot 0)
   (while (<= 1 n)
        (setq en (ssname ss k))
        (setq tv (cdr (assoc 1 (entget en))))
        (setq rtv (atof tv))
        (setq tot (+ tot rtv))
        (setq n (- n 1))
        (setq k (+ k 1))
   (setq tot (rtos (* tot 10000) 2 0))
   (setq an (strlen tot))
   (setq tot (strcat (substr tot 1 (- an 4)) “.” (substr tot (- an 3) 2)   ))
   (prompt “n합 계 : “) (prin1 tot)
   (command “text” “j” “r” pt1 ht “0” tot)
   (prompt “nEnter text point->”)
   (command “move” “l” “” pt1 pause)
   (setvar “orthomode” choi) (setvar “osmode” w_os)
   (prin1)
위에가  더하기 리습
; Number by(0010cho_i)
; ->두 수의 곱 구하기(소수네째자리)
(defun c:*(/ choi d_ts w_os ht ss1 en1 ent1 tv1 ss2 en2 ent2 tv2 grpt pt1 rst1
                      tot1 rtv1 rtv2 en an)
   (setq ht d_ts)
   (setq ht (getdist))
   (prompt “nSelect first number->”)
   (setq ss1 (entsel) en1 (car ss1))   (redraw en1 3)
   (setq ent1 (assoc 1 (entget (car ss1))))
   (setq tv1 (cdr ent1))
   (prompt “nSelect second number->”)
   (setq ss2 (entsel) en2 (car ss2))   (redraw en2 3)
   (setq ent2 (assoc 1 (entget (car ss2))))
   (setq tv2 (cdr ent2))
   (setq grpt (grread T) pt1 (cadr grpt))
   (setq  rst1 0)
   (setq rtv1 (atof tv1)  rtv2 (atof tv2))
   (setq rst1 (* rtv1 rtv2));곱하기
   (setq tot1 (abs rst1))
   (setq tot1 (rtos tot1 2 7))
   (if (= (wcmatch tot1 “*.*”) nil)
       (setq tot1 (strcat tot1 “.00”)))
   (setq an (strlen tot1))
   (if (= (substr tot1 (- an 1) 1) “.”)
       (setq tot1 (strcat tot1 “0”)) )
   (if (< rst1 0)
       (setq tot1 (strcat “-” tot1)))
   (prompt “n결 과 : “) (prin1 rst1)
   (command “text” “j” “r” pt1 ht “0” tot1)
   (redraw en1 4) (redraw en2 4)
   (prin1)
이것이 곱하기 리습인데 ㅠㅠ
소수점 4자리이상으로 계산되게 하는 방법좀 가르쳐주세요
  • 58 조회
