홈/ 질문/Q 24537
등록일: 2007-03-282007-03-28T08:29:48+09:00 2007-03-28T08:29:48+09:00카테고리: AutoCAD & CADian
리습 수정좀 부탁드려요(도넛을 화살표로)
(DEFUN C:Nu ()
(setvar “orthomode” 0)
(SETQ W3 (getvar “DIMSCALE”)
w4 (* 5 w3)
w5 (* 2 w3)
w6 (* 8 w3)
r2 (* 1 w3)
fd2 (* 4.2 w3)
r1 0
H1 (* 4 W3))
(while (/= (setq po1 (getpoint “nPick Donut point: “)) nil)
(setq po2 (getpoint po1 “nTo point: “))
(setq t1 (rtos w4 2 0)
t_2 (strcat “T” T1))
;(command “text” “s” T_2 “50,50” “0” “”)
(setq p_a po2
rad_ang (angle p_a po1)
po2 (polar po2 rad_ang w4))
(command
“layer” “M” “DIM” “C” “1” “” “”
“donut” r1 r2 po1 “”
“pline” po1 “w” “0” “0” po2
(setq p1 (getvar “lastpoint”))
(while (setq po2 (getpoint “nTo point: ” po2))
(setq p_a po2
rad_ang (angle p_a p1)
(command po2)
);while end
(command “”)
(COMMAND “change” “l” “” “p” “c” “1” “”)
(if (= nu_old nil)(setq nu_old (strcat “1”)))
(setq p1 p_a
rad_ang (angle p1 p_a)
P3 (polar p1 rad_ang w4))
(setq nu (getstring (strcat “Number String <" nu_old ">:”)))
(if (or (= nu “”)(= nu ” “))(setq nu nu_old))
(setq nu2 (strcat nu))
(setq nu_old nu)
(command
“circle” p1 p3
“text” “j” “m” p1 H1 0 nu2)
(command “.change” “l” “” “p” “c” “3” “”)
);while end
(prin1)
);defun end
도넛으로 나오는 부분을 화살표로 바꾸고 싶은데 도움좀 부탁드립니다.
  • 26 조회
