길이 합계 리습인데
산출중 Text, Write 선택없이 그냥 바로 Text로 산출될수 있게 수정부탁합니다.
;;선택된 Line의 길이을 모두 더하는 명령(000822cho_i)
(defun c:lp(/ ss en n n1 k tot dis dis1 spt ept stype p2 pt r sosu
ename r old_elist old_f new_f new_elist )
(prompt “nCommand: Line Plus…”)
(prompt “n더하고자하는 line을 선택-> “)
(setq ss (ssget))
(setq n1 (sslength ss))
(setq n n1 k 0)
(setq tot 0 dis 0 dis1 0)
(while (<= 1 n)
(setq en (ssname ss k))
(setq stype (cdr (assoc 0 (entget en))))
(if (= stype “LINE”)(progn
(setq spt (cdr (assoc 10 (entget en))))
(setq ept (cdr (assoc 11 (entget en))))
(setq dis1 (distance spt ept))
(setq dis (/ dis1 1))
(terpri)(if (= stype “LWPOLYLINE”)(progn
(command “area” “e” en)
(setq dis1 (getvar “perimeter”))
))(terpri)
(setq tot (+ tot dis))
(setq n (- n 1))
(setq k (+ k 1))
(prompt “총”)(prin1 n1)(prompt “개의 라인…”)(prompt ” = “)(prin1 tot)
(if (> tot 0)
(progn
(initget “Text Write”)
(setq p2 (getkword ” [Text/Write] :”))
(setq sosu 2)
(cond
((= P2 “Text”)
(setq ename (car (entsel))) ;텍스트 객체가져오기
(setq r (rtos tot 2 sosu)) ;텍스트값
(setq r (SSJR r))
(setq old_elist (entget ename))
(setq old_f (assoc 1 old_elist)) ;현재 텍스트 값
(setq new_f (cons 1 r)) ;바꿀 텍스트값
(setq new_elist (subst new_f old_f old_elist)) ;텍스트값 교체
(entmod new_elist) ;바꾼 텍스트값 재생성
((= P2 “Write”)
(setq pt (getpoint “nPick point of text:”))
(setq r (SSJR r))
(command “TEXT” pt “” 0 r)
(T
(defun SSJR( txt / dot txt1 txt2)
(if (> sosu 0)
(progn
(if (>= (atof txt) 1)
(progn
(setq dot (strlen (rtos (atoi txt) 2 0)))
(setq txt (atof txt))
(repeat sosu (setq txt (* txt 10)))
(setq txt (rtos txt 2 0))
(setq txt1 (substr txt 1 dot) txt2 (substr txt (+ dot 1)))
(setq txt (strcat txt1″.”txt2))
(progn
(setq dot 2)
(setq txt (+ 1 (atof txt)))
(setq txt2 (substr txt dot))
(setq txt (strcat “0.”txt2))
(setq txt (rtos (atof txt) 2 0))
(setq p2 (getkword ” [Text/Write] :”)) => (setq p2 “Text”)
