홈/ 질문/Q 100489
등록일: 2014-02-262014-02-26T11:32:17+09:00 2014-02-26T11:32:17+09:00카테고리: AutoCAD & CADian
리습 수정 부탁 합니다.
예전에 사용하던 심도 평균거리를 삽입했던 리습인데
앞에 설치년도를 입력하여 사용하니 제원형식이 달라서
리습이 안되네요
잘아시는분 수정 부탁드립니다.
상하수 제원입력하는 쉬운 방법 있으면 글좀 부탁 드립니다.
(defun c:SD (/  old_osmode old_layer  lw_data  e_total
      lw_entity lw_data    lw_su      lw_list  new_xy1
      new_xy2 sd_data    ds_susu    su_su  sd_entity
      sd_xy10 sd_xy11    sd_na      sel_text  p_sd
      TXT
  (setvar “CMDECHO” 0)
  (setq old_osmode (getvar “osmode”))
  (setq old_layer (getvar “clayer”))
  (setq view_ctr (getvar “VIEWCTR”))
  (setq view_size (getvar “VIEWSIZE”))
  (defun t_nil (a c b d)
    (apply (eval (read (strcat “‘” a)))  (MAPCAR ‘(LAMbDA (X) ((eval b) c X)) d))
  (while (not (t_nil “or” (cdr (assoc 0  (if (setq a-b (car (entsel “n길이를 구할 object 를 선택하세요.”)))
    (setq a (entget a-b)) nil ))) = ‘(“LWPOLYLINE” “LINE” “POLYLINE” “ARC” “CIRCLE” “SPLINE” “ELLIPSE”) ))
  ); of while
  (command “lengthen” A-B “”)
  (setq th (getvar “dimscale”))
  (setq ang 0)
  (setq sf 1)
  (setq txt (RTOS (/ (GETVAR “PERIMETER”) 1.0) 2 1))
  (princ “선형을 선택하시오.n”)
  (setq lw_data (ssget))
  (setq sel_text (car (entsel “Text 선택 :”)))
  (command “change” sel_text “” “p” “c” “2” “”)
  (setq sd_ha 0
 sd_su_su 0
  (if lw_data
    (progn
      (setq e_total (sslength lw_data))
      (if (= e_total 1)
 (progn
   (setq lw_entity (entget (ssname lw_data 0))
  lw_su   0
   (setq lw_list (nth lw_su lw_entity))
   (while lw_list
     (if (= (car lw_list) 10)
       (progn
  (setq v_pt (cdr lw_list))
  (command “zoom” “c” (cdr lw_list) “10”)
  (setq new_xy1 (polar (cdr lw_list) 2.37365 1.5))
;;;;;;;;;;;;<—–공차변경
  (setq new_xy2 (polar (cdr lw_list) 5.48033 1.5))
;;;;;;;;;;;;<—–공차변경
  (setq lw_x (rtos (car (cdr lw_list)) 2 3)
        lw_y (rtos (cadr (cdr lw_list)) 2 3)
  (setq sd_data (ssget “c”
         new_xy1
         new_xy2
         ‘((0 . “TEXT”) (8 . “SB900”))
;;;;;;;;<—–Text-레이어변경
  (if sd_data
    (progn
      (setq sd_susu (sslength sd_data)
     sd_su   0
      (repeat sd_susu
        (setq sd_entity (entget (ssname sd_data sd_su)))
        (setq sd_xy10 (cdr (assoc 10 sd_entity)))
        (setq 10_x (rtos (car sd_xy10) 2 3)
       10_y (rtos (cadr sd_xy10) 2 3)
        (setq sd_xy11 (cdr (assoc 11 sd_entity)))
        (setq 11_x (rtos (car sd_xy11) 2 3)
       11_y (rtos (cadr sd_xy11) 2 3)
        (setq
   sd_na (distof
    (substr (cdr (assoc 1 sd_entity)) 2)
        (if (or (and (= lw_x 10_x) (= lw_y 10_y))
         (and (= lw_x 11_x) (= lw_y 11_y))
   (setq sd_ha    (+ sd_ha sd_na)
         sd_su_su (+ sd_su_su 1)
        (setq sd_su (+ sd_su 1))
      )   ;repeat
     (setq lw_su (+ lw_su 1))
   )    ;while
;;;   (setq
;;;     p_sd (strcat “평균 심도 : ” (rtos (/ sd_ha sd_su_su) 2 2))
;;;   (alert p_sd)
   (setq p_sd “”)
   (setq p_sd (rtos (/ sd_ha sd_su_su) 2 1))
   (if (/= p_sd “”)
     (progn
       (mod_text p_sd sel_text)
       (princ “n 평균심도:”)
       (princ p_sd)
   (command “zoom” “c” view_ctr view_size)
 )    ;progn
 (alert “중복선택 다시 선택”)
    (alert “선형 無 <확인요망>.”)
  (setvar “clayer” old_layer)
  (setvar “osmode” old_osmode)
(defun mod_text (aveSimdo jewon)
  (if (not (eq jewon nil))
    (progn
      (setq jewon_str (cdr (assoc 1 (entget jewon))))
      (setq strLst (strtokenizer jewon_str “/”))
      (if (/= (length strLst) 4)
        (princ “n 제원형식이 다릅니다.”)
 (progn
   (setq str0 (nth 0 strLst))
   (setq str1 (nth 1 strLst))
   (setq str2 (nth 2 strLst))
   (setq str3 (nth 3 strLst))
   (setq str4 (nth 4 strLst))
  ; (setq str5 (nth 5 strLst))
   (setq strNewSimdo (strcat “D” aveSimdo))
   (setq strnewlenth (strcat “L” txt))
          (setq new_jewon (strcat   “/”   str0   “/”
      str1   “/”   strnewlenth     “/”   strNewSimdo
         ; (setq new_jewon (strcat str0   “/”   str1   “/”
 ;     str2   “/”   str3   “/”
   (setq new_ent (cons 1 new_jewon))
   (entmod (subst new_ent
    (entget jewon)
;;string tokenizer 함수
(defun strtokenizer
       (string token / rep_no i st ed rep_no one_char word)
  (setq rep_no (strlen string))
  (setq i  0
 st 0
 ed 1
  (setq wordList ‘())
  (repeat rep_no
    (setq i (+ i 1))
    (setq one_char (substr string i 1))
    (if (= one_char token)
      (progn
 (setq ed (- i (+ st 1)))
 (setq word (substr string (+ st 1) ed))
 (if (not (or (= word nil) (= word “”)))
   (progn
     (setq wordList (append wordList (list word)))
 (setq st i)
    (if (= i rep_no)
      (progn
 (setq word (substr string (+ st 1)))
   (progn
  wordList
  • 42 조회
    • 도구막대 이동시 미리보기가 안됩니다.
