홈/ 질문/Q 110748
등록일: 2018-12-202018-12-20T15:54:10+09:00 2018-12-20T15:54:10+09:00카테고리: AutoCAD & CADian
리습 잘못된게 있는건가요?..
레이어선 정리하는 리습인데…
마지막 lal만 실행이 안되네요..ㅠㅠ
뭐가 잘못된건지 모르겠어요.
님들 가르쳐주세요.ㅠㅠ
(defun c:AF (/ acDoc acLay)
  (vl-load-com)
  (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq acLay (vla-get-name (vla-get-activelayer acDoc)))
  (vla-startundomark acDoc)
  (vlax-for lay (vla-get-layers acDoc)
   (if (not (= acLay (vla-get-name lay)))
    (vla-put-LayerOn lay :vlax-false)
  )(vla-endundomark acDoc)(princ)
(defun c:ff (/ acDoc ss layerList)
  (vl-load-com)
  (and
   (setq ss (ssget))
   (setq layerList
    (mapcar ‘vla-get-layer
     (mapcar ‘vlax-ename->vla-object
      (vl-remove-if ‘listp (mapcar ‘cadr (ssnamex ss)))
    (if (member (vla-get-name lay) layerList)
 (defun c:lol (/ acDoc ss layerList)
  (vl-load-com)
  (and
   (setq ss (ssget))
   (setq layerList
    (if (not (member (vla-get-name lay) layerList))
 (defun c:lal ()
   (vla-put-LayerOn lay :vlax-true)
 )(princ)
  • 35 조회
