홈/ 질문/Q 96802
AHN GISEOG
AHN GISEOGLv.0
등록일: 2012-12-042012-12-04T11:02:19+09:00 2012-12-04T11:02:19+09:00카테고리: AutoCAD & CADian
리습 좀 살려 주십시요.
다시 한번 올려봅니다.
고수분들께 부탁 드립니다.
이전 캐드에서는 실행되던 것인데
캐드2012에서 에러 나는 다음 2개 파일의 리습 좀 살려 주십시요.
<1번 Tole.DCL 파일>
Tolerances : dialog {
 label = “Tolerances Value” ;
    :paragraph{
        :text_part{
        key = “dim_v”;
        value = “”;
    :boxed_column{
        :popup_list {
        fixed_width = true;
        label = “Upper Value    :”;
        edit_width = 10;
        key   = “ptl”;
       :popup_list {
       fixed_width = true;
       label = “Lower Value    :”;
       edit_width = 10;
       key   = “mtl”;
   ok_cancel;
<2번 Tole.lsp 파일>
(defun dialog_dim(/ dcl_id up_list low_list)
  (setvar “cmdecho” 0)
  (if (= up nil)  (setq up “1”))
  (if (= low nil) (setq low “1”))
  (setq dcl_id (load_dialog “tole.dcl”))
  (if (not (new_dialog “Tolerances” dcl_id))
    (exit))
  (set_tile “dim_v” (strcat “선택된 치수값 : “(rtos dim_value)))
  (setq up_list (list ” ” ” 0″ “+0.01” “+0.02” “+0.03” “+0.04” “+0.05” “+0.06” “+0.07”
        “+0.08” “+0.09” “+0.1 ” “+0.11” “+0.12” “+0.13” “+0.14” “+0.15”
        “+0.001” “+0.002” “+0.003” “+0.004” “+0.005” “+0.006”))
  (setq low_list(list ” ” ” 0″ “-0.01” “-0.02” “-0.03” “-0.04” “-0.05” “-0.06” “-0.07”
        “-0.08” “-0.09” “-0.1 ” “-0.11” “-0.12” “-0.13” “-0.14” “-0.15”
        “-0.001” “-0.002” “-0.003” “-0.004” “-0.005” “-0.006”))
  (start_list “ptl”)
  (mapcar ‘add_list up_list)  (end_list)
  (start_list “mtl”)
  (mapcar ‘add_list low_list) (end_list)
  (set_tile “ptl”  up)
  (set_tile “mtl” low)
  (action_tile “ptl”  “(p_tol)”)
  (action_tile “mtl”  “(m_tol)”)
  (start_dialog)
  (done_dialog)
  (unload_dialog dcl_id)
  );The end;
(defun p_tol(/ temp)
  (setq temp $value
         ptl (nth (atoi temp) up_list)
  up temp)
(defun m_tol(/ temp)
  (setq temp $value
         mtl (nth (atoi temp) low_list)
  low temp)
(defun c:ter(/ sel ea obj i j new old ptol mtol)
  (if (= ptl nil) (setq ptl ” 0″))
  (if (= mtl nil) (setq mtl ” 0″))
  (setq j 1)
  (while j
    (ssget “:s”)
    (setq sel(ssget “p” ‘((0 . “DIMENSION”))))
    (if (/= sel nil) (setq j nil))
  (setq ea (sslength sel))
  (setq i 0)
  (repeat ea
    (setq obj (entget (ssname sel i)))
    (setq dim_value (cdr (assoc 42 obj)))
    (setq k 1)
    (while k
      (dialog_dim)
      (if (or (/= ptl “”)(/= mtl “”))
 (setq k nil)
      );while end
    (setq old (assoc 1 obj))
    (setq ptol(abs(atof ptl))
   mtol(abs(atof mtl))
    (if (= ptol mtol)
      (if (= ptol 0)
 (setq new(cons 1 “”))
 (setq new(cons 1 (strcat “\A1;<>{\H0.7x;\S ^%%p” (rtos ptol)”;}”)))
 );end if
      (setq new (cons 1 (strcat “\A1;<>{\H0.7x;\S” ptl “^” mtl “;}”)))
      );end if
    (setq obj (subst new old obj))
    (entmod obj)
    (setq i(1+ i))
  • 22 조회
