홈/ 질문/Q 89848
등록일: 2010-11-252010-11-25T14:25:09+09:00 2010-11-25T14:25:09+09:00카테고리: AutoCAD & CADian
면적구하기리습인데..오류가 있는것 같아서…수정좀 부탁드립니다.(_._)
(defun C:VT( / TEX Q AR PT1 )
  (graphscr)
  (setvar “cmdecho” 0)
   (setq number 0)
(while (setq dum (bpoly (getpoint “n Select pick point … : “)))
          (command “AREA” “object” dum)
            (setq nu (getvar “AREA”))
            (if ( = number nil)
                (setq number 0)
            (setq number  ( + number nu) )
            (princ (strcat “area ==>”(rtos number 2 2)))
            (setq tt (entsel “n>>Select change Text : “)
                   tt1 (car tt)
                  ; ett (substr (cdr (assoc 1 (entget tt1))) 1 6)
          ;  (setq AR (strcat ett ” ” (rtos (* number 1) 2 2)) )
            (setq AR (rtos (* number 1) 2 2))
            (command “CHANGE” TT “” “” “” “” “” “” AR)
   (setq number 0)
   (setvar “cmdecho” 1)
 (command “erase” “L” “”)
(defun c:zz()
 (setq pz0 (getpoint “npick base of arrowhead “))
 (setq pz1 (getpoint “npick tip of arrowhead “))
 (command “insert” “2z” pz0 “” “” “”)
 (command “explode” “l”)
 (command “insert” “2z2” pz1 “” “” “”)
  • 31 조회
