홈/ 질문/Q 105219
등록일: 2015-10-142015-10-14T09:11:55+09:00 2015-10-14T09:11:55+09:00카테고리: AutoCAD & CADian
면적리습 소수점 3자리까지 나오게 수정부탁드립니다.
고캐드에서 면적리습 검색하다 찾은 리습인데요
소수점 1자리만 나오더라구요.  소수점 3자리까지 나오게하려면 어찌해야하는지 알려주세요
4사5입이 무슨말인지 모르겠어요 @.@
;  Quick Area 3                                                           ;
;  -> pline, 또는 내부를 선택하여 면적 표기 (소숫점 3자리구하기 – 4사5입) ;
(defun c:AR(/ choi d_ts w_os grpt pt1 ent1 en1 ar1 ar2 ar3 ar4 ar5 an arm ht)
   (prompt “…면적구하기”)
   (setq choi (getvar “orthomode”)  d_ts (getvar “textsize”)
            w_os (getvar “osmode”) )
   (setvar “orthomode” 0)
   (setq ht d_ts)
   (prompt “nText Height<“) (prin1 ht) (prompt “>: “)
   (setq ht (getdist))
   (if (= ht nil) (setq ht d_ts))
   (setq ent1 (entsel  “nPline 선택<internal point>->”))
   (if (/= ent1 nil)(progn
       (setq en1 (car ent1)) (redraw en1 3)
       (setq grpt (grread T))
       (setq pt1 (cadr grpt))
       (command “area” “e” ent1)
;-boundary start
   (if (= ent1 nil)(progn
       (prompt “nSelect internal point->”)
       (command “boundary” pause “”)
       (setq en1 (entlast))(redraw en1 3)
       (command “area” “e” “l”)
       (setq pt1 (getvar “lastpoint”))
   ));-boundary end
   (setq ar1 (/ (getvar “area”) 10))
   (setq ar2 (rtos ar1 2 0))
   (setq an (strlen ar2))
   (setq arm (substr ar2 (- an 1) 1))
   (setq arm (atof arm))
   (setq ar3 (atoi ar2))
   (if (>= arm 5)(progn
       (setq ar3 (+ ar3 100))
   (setq ar3 (rtos ar3 2 0))
   (setq ar4 (strcat (substr ar3 1 (- an 5)) “.” (substr ar3 (- an 4) 1)   ))
   (if (= (substr ar4 1 1) “.”) (setq ar4 (strcat “0” ar4)))
   (setq ar5 (strcat (substr ar2 1 (- an 5)) “.” (substr ar2 (- an 4) 5)   ))
   (if (= (substr ar5 1 1) “.”) (setq ar5 (strcat “0” ar5)))
   (command “text” “j” “r” pt1 ht “0” ar4)
   (prompt “nEnter text point->”)
   (command “move” “l” “” pt1 pause)
   (redraw en1 4)
   (prompt “nArea : “)(prin1 ar5) (prompt ”  or  “)(prin1 ar4)(terpri)
   (setvar “orthomode” choi) (setvar “osmode” w_os)
   (prin1)
  • 162 조회
