홈/ 질문/Q 100324
등록일: 2014-02-122014-02-12T09:22:01+09:00 2014-02-12T09:22:01+09:00카테고리: AutoCAD & CADian
면적 리습수정 부탁드려요~
면적구하는 리습을 가지고 있는데요
여기서 평은 안나오고 면적만 나오게 하고 싶은데 어떻게 고쳐야 하는지 몰르겠어요~
(defun c:aaa ( / doc space ss index obj mi mx minpt maxpt inspt area txtobj )
 (setvar “cmdecho” 0)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (cond
    ((= (vla-get-activespace doc) 1) (setq space (vla-get-modelspace doc)))
    ((= (vla-get-activespace doc) 0) (setq space (vla-get-paperspace doc)))
  (if (setq ss (ssget (list (cons 0 “CIRCLE,ARC,*POLYLINE,LINE,ELLIPSE,SPLINE”))))
    (if (or (setq ts (getreal (strcat “n텍스트 높이 입력 <” (vl-princ-to-string (getvar “textsize”)) “>:”))) (setq ts (getvar “textsize”)))
      (progn
  (setvar “textsize” ts)
 (setq index 0)
 (repeat (sslength ss)
   (setq obj (vlax-ename->vla-object (ssname ss index)))
   (vla-getboundingbox obj ‘mi ‘mx)
   (setq minpt (vlax-safearray->list mi) maxpt (vlax-safearray->list mx))
   (setq inspt (polar minpt (angle minpt maxpt) (/ (distance minpt maxpt) 2)))
   (setq inspt (list (car inspt) (+ (cadr inspt) (* ts 2))))
   (setq area (vla-get-area obj) len (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)))
   (mapcar ‘(lambda (a b)
       (setq p (vlax-3d-point inspt))
       (setq txtobj (vla-addtext space (strcat a b) p ts))
       (vla-put-alignment txtobj 4)
       (vla-put-textalignmentpoint txtobj p)
       (setq inspt (polar inspt (/ (* 270 pi) 180) (* ts 2)))
              ‘( ”  ” ”  ” )   (list (rtos (/ area 3305796.) 2 2) (rtos (/ area 1000000.) 2 3)); (rtos len 2 2))
   (setq index (1+ index))
 (command “chprop” (ssget “x” ‘((0 . “TEXT”) (1 . “평*”))) “” “”) ; “” “c” “7” “”)
(vl-load-com)
(prompt “n[ AAA ]”)
  • 26 조회
    2. 고탁 Lv.2
      2014-02-12T16:09:47+09:00답변 등록 답변 등록 일시 2014-02-12 4:09 pm
      한번 사용해보세요
      2014-02-21T14:45:47+09:00답변 등록 답변 등록 일시 2014-02-21 2:45 pm
      감사합니다^^
