홈/ 질문/Q 110108
등록일: 2018-07-232018-07-23T13:30:27+09:00 2018-07-23T13:30:27+09:00카테고리: AutoCAD & CADian
명령어 초기화 하는법 없나요?
도구-사용자화-매개변수 편집 들어가서 명령어좀 편하게 바꿧는데 그게 꼬였는지 명령어가 잘 안먹히고 있습니다. 예를들면 RO명령어를 입력하면 로테이트가 안되고 ROUND FILLET이 입력이 되더라구요..
명령어는 간단하게 2개정도 바꿨는데 여러개가 꼬인것 같습니다. 이거 리셋하는법 없을까요?
  • 184 조회
      2018-07-23T16:53:30+09:00답변 등록 답변 등록 일시 2018-07-23 4:53 pm
      ;  Program Parameters File For Autodesk AutoCAD 2014
      ;  External Command and Command Alias Definitions
      ;  Copyright 2013 Autodesk, Inc.  All rights reserved.
      ;  Use of this software is subject to the terms of the Autodesk license
      ;  agreement provided at the time of installation or download, or which
      ;  otherwise accompanies this software in either electronic or hard copy form.
      ;  Each time you open a new or existing drawing, AutoCAD searches
      ;  the support path and reads the first acad.pgp file that it finds.
      ;  — External Commands —
      ;  While AutoCAD is running, you can invoke other programs or utilities
      ;  such Windows system commands, utilities, and applications.
      ;  You define external commands by specifying a command name to be used
      ;  from the AutoCAD command prompt and an executable command string
      ;  that is passed to the operating system.
      ;  — Command Aliases —
      ;  The Command Aliases section of this file provides default settings for
      ;  AutoCAD command shortcuts.  Note: It is not recommended that  you directly
      ;  modify this section of the PGP file., as any changes you make to this section of the
      ;  file will not migrate successfully if you upgrade your AutoCAD to a
      ;  newer version.  Instead, make changes to the new
      ;  User Defined Command Aliases
      ;  section towards the end of this file.
      ;  — User Defined Command Aliases —
      ;  You can abbreviate frequently used AutoCAD commands by defining
      ;  aliases for them in the User Defined Command Aliases section of acad.pgp.
      ;  You can create a command alias for any AutoCAD command,
      ;  device driver command, or external command.
      ;  Recommendation: back up this file before editing it.  To ensure that
      ;  any changes you make to PGP settings can successfully be migrated
      ;  when you upgrade to the next version of AutoCAD, it is suggested that
      ;  you make any changes to the default settings in the User Defined Command
      ;  Aliases section at the end of this file.
      ;  External command format:
      ;  <Command name>,[<Shell request>],<Bit flag>,[*]<Prompt>,
      ;  The bits of the bit flag have the following meanings:
      ;  Bit 1: if set, don’t wait for the application to finish
      ;  Bit 2: if set, run the application minimized
      ;  Bit 4: if set, run the application “hidden”
      ;  Bit 8: if set, put the argument string in quotes
      ;  Fill the “bit flag” field with the sum of the desired bits.
      ;  Bits 2 and 4 are mutually exclusive; if both are specified, only
      ;  the 2 bit is used. The most useful values are likely to be 0
      ;  (start the application and wait for it to finish), 1 (start the
      ;  application and don’t wait), 3 (minimize and don’t wait), and 5
      ;  (hide and don’t wait). Values of 2 and 4 should normally be avoided,
      ;  as they make AutoCAD unavailable until the application has completed.
      ;  Bit 8 allows commands like DEL to work properly with filenames that
      ;  have spaces such as “long filename.dwg”.  Note that this will interfere
      ;  with passing space delimited lists of file names to these same commands.
      ;  If you prefer multiplefile support to using long file names, turn off
      ;  the “8” bit in those commands.
      ;  Examples of external commands for command windows
      DEL,       DEL,            8,File to delete: ,
      DIR,       DIR,            8,File specification: ,
      SH,        ,               1,*OS Command: ,
      SHELL,     ,               1,*OS Command: ,
      START,     START,          1,*Application to start: ,
      TYPE,      TYPE,           8,File to list: ,
      ; Examples of external commands for Windows
      ; See also the (STARTAPP) AutoLISP function for an alternative method.
      EXPLORER,  START EXPLORER, 1,,
      NOTEPAD,   START NOTEPAD,  1,*File to edit: ,
      PBRUSH,    START PBRUSH,   1,,
      ; Command alias format:
      ;   <Alias>,*<Full command name>
      ;  The following are guidelines for creating new command aliases.
      ;  1. An alias should reduce a command by at least two characters.
      ;      Commands with a control key equivalent, status bar button,
      ;      or function key do not require a command alias.
      ;      Examples: Control N, O, P, and S for New, Open, Print, Save.
      ;  2. Try the first character of the command, then try the first two,
      ;      then the first three.
      ;  3. Once an alias is defined, add suffixes for related aliases:
      ;      Examples: R for Redraw, RA for Redrawall, L for Line, LT for
      ;      Linetype.
      ;  4. Use a hyphen to differentiate between command line and dialog
      ;      box commands.
      ;      Example: B for Block, -B for -Block.
      ; Exceptions to the rules include AA for Area, T for Mtext, X for Explode.
      ;  — Sample aliases for AutoCAD commands —
      ;  These examples include most frequently used commands.  NOTE: It is recommended
      ;  that you not make any changes to this section of the PGP file to ensure the
      ;  proper migration of your customizations when you upgrade to the next version of
      ;  AutoCAD.  The aliases listed in this section are repeated in the User Custom
      ;  Settings section at the end of this file, which can safely be edited while
      ;  ensuring your changes will successfully migrate.
      3A,        *3DARRAY
      3DMIRROR,  *MIRROR3D
      3DNavigate,*3DWALK
      3DO,       *3DORBIT
      3DP,    *3DPRINT
      3DPLOT,    *3DPRINT
      3DW,       *3DWALK
      3F,        *3DFACE
      3M,        *3DMOVE
      3P,        *3DPOLY
      3R,        *3DROTATE
      3S,        *3DSCALE
      A,         *ARC
      AC,        *BACTION
      ADC,       *ADCENTER
      AECTOACAD, *-ExportToAutoCAD
      AA,        *AREA
      AL,        *ALIGN
      3AL,       *3DALIGN
      AP,        *APPLOAD
      APLAY,     *ALLPLAY
      AR,        *ARRAY
      -AR,       *-ARRAY
      ARR,       *ACTRECORD
      ARM,       *ACTUSERMESSAGE
      -ARM,      *-ACTUSERMESSAGE
      ARU,       *ACTUSERINPUT
      ARS,       *ACTSTOP
      -ARS,       *-ACTSTOP
      ATI,       *ATTIPEDIT
      ATT,       *ATTDEF
      -ATT,      *-ATTDEF
      ATE,       *ATTEDIT
      -ATE,      *-ATTEDIT
      ATTE,      *-ATTEDIT
      B,         *BLOCK
      -B,        *-BLOCK
      BC,        *BCLOSE
      BE,        *BEDIT
      BH,        *HATCH
      BLENDSRF,  *SURFBLEND
      BO,        *BOUNDARY
      -BO,       *-BOUNDARY
      BR,        *BREAK
      BS,        *BSAVE
      BVS,       *BVSTATE
      C,         *CIRCLE
      CAM,       *CAMERA
      CBAR,      *CONSTRAINTBAR
      CH,        *PROPERTIES
      -CH,       *CHANGE
      CHA,       *CHAMFER
      CHK,       *CHECKSTANDARDS
      CLI,       *COMMANDLINE
      COL,       *COLOR
      COLOUR,    *COLOR
      CO,        *COPY
      CONVTOMESH, *MESHSMOOTH
      CP,        *COPY
      CPARAM,    *BCPARAMETER
      CREASE,    *MESHCREASE
      CREATESOLID, *SURFSCULPT
      CSETTINGS, *CONSTRAINTSETTINGS
      CT,        *CTABLESTYLE
      CUBE,      *NAVVCUBE
      CURVATUREANALYSIS, *ANALYSISCURVATURE
      CYL,       *CYLINDER
      D,         *DIMSTYLE
      DAL,       *DIMALIGNED
      DAN,       *DIMANGULAR
      DAR,       *DIMARC
      DELETE,    *ERASE
      JOG,       *DIMJOGGED
      DBA,       *DIMBASELINE
      DBC,       *DBCONNECT
      DC,        *ADCENTER
      DCE,       *DIMCENTER
      DCENTER,   *ADCENTER
      DCO,       *DIMCONTINUE
      DCON,      *DIMCONSTRAINT
      DDA,       *DIMDISASSOCIATE
      DDI,       *DIMDIAMETER
      DED,       *DIMEDIT
      DELCON,    *DELCONSTRAINT
      DI,        *DIST
      DIV,       *DIVIDE
      DJL,       *DIMJOGLINE
      DJO,       *DIMJOGGED
      DL,        *DATALINK
      DLI,       *DIMLINEAR
      DLU,       *DATALINKUPDATE
      DO,        *DONUT
      DOR,       *DIMORDINATE
      DOV,       *DIMOVERRIDE
      DR,        *DRAWORDER
      DRA,       *DIMRADIUS
      DRAFTANGLEANALYSIS, *ANALYSISDRAFTANGLE
      DRE,       *DIMREASSOCIATE
      DRM,       *DRAWINGRECOVERY
      DS,        *DSETTINGS
      DST,       *DIMSTYLE
      DT,        *TEXT
      DV,        *DVIEW
      DX,        *DATAEXTRACTION
      E,         *ERASE
      ED,        *DDEDIT
      EL,        *ELLIPSE
      ER,        *EXTERNALREFERENCES
      ESHOT,     *EDITSHOT
      EX,        *EXTEND
      EXIT,      *QUIT
      EXP,       *EXPORT
      EXT,       *EXTRUDE
      EXTENDSRF, *SURFEXTEND
      F,         *FILLET
      FI,        *FILTER
      FILLETSRF, *SURFFILLET
      FREEPOINT, *POINTLIGHT
      FSHOT,     *FLATSHOT
      G,         *GROUP
      -G,        *-GROUP
      GCON,      *GEOMCONSTRAINT
      GD,        *GRADIENT
      GENERATESECTION,  *SECTIONPLANETOBLOCK
      GEO,       *GEOGRAPHICLOCATION
      GR,        *DDGRIPS
      H,         *HATCH
      -H,        *-HATCH
      HE,        *HATCHEDIT
      HB,        *HATCHTOBACK
      HI,        *HIDE
      I,         *INSERT
      -I,        *-INSERT
      IAD,       *IMAGEADJUST
      IAT,       *IMAGEATTACH
      ICL,       *IMAGECLIP
      IM,        *IMAGE
      -IM,       *-IMAGE
      IMP,       *IMPORT
      IN,        *INTERSECT
      INSERTCONTROLPOINT, *CVADD
      INF,       *INTERFERE
      IO,        *INSERTOBJ
      ISOLATE,   *ISOLATEOBJECTS
      QVD,       *QVDRAWING
      QVDC,      *QVDRAWINGCLOSE
      QVL,       *QVLAYOUT
      QVLC,      *QVLAYOUTCLOSE
      J,         *JOIN
      JOGSECTION,  *SECTIONPLANEJOG
      L,         *LINE
      LA,        *LAYER
      -LA,       *-LAYER
      LAS,       *LAYERSTATE
      LE,        *QLEADER
      LEN,       *LENGTHEN
      LESS,      *MESHSMOOTHLESS
      LI,        *LIST
      LINEWEIGHT, *LWEIGHT
      LMAN,      *LAYERSTATE
      LO,        *-LAYOUT
      LS,        *LIST
      LT,        *LINETYPE
      -LT,       *-LINETYPE
      LTYPE,     *LINETYPE
      -LTYPE,    *-LINETYPE
      LTS,       *LTSCALE
      LW,        *LWEIGHT
      M,         *MOVE
      MA,        *MATCHPROP
      MAT,       *MATBROWSEROPEN
      ME,        *MEASURE
      MEA,       *MEASUREGEOM
      MI,        *MIRROR
      ML,        *MLINE
      MLA,       *MLEADERALIGN
      MLC,       *MLEADERCOLLECT
      MLD,       *MLEADER
      MLE,       *MLEADEREDIT
      MLS,       *MLEADERSTYLE
      MO,        *PROPERTIES
      MORE,      *MESHSMOOTHMORE
      MOTION,    *NAVSMOTION
      MOTIONCLS, *NAVSMOTIONCLOSE
      MS,        *MSPACE
      MSM,       *MARKUP
      MT,        *MTEXT
      MV,        *MVIEW
      NETWORKSRF,*SURFNETWORK
      NORTH,     *GEOGRAPHICLOCATION
      NORTHDIR,  *GEOGRAPHICLOCATION
      NSHOT,     *NEWSHOT
      NVIEW,     *NEWVIEW
      O,         *OFFSET
      OFFSETSRF, *SURFOFFSET
      OP,        *OPTIONS
      ORBIT,     *3DORBIT
      OS,        *OSNAP
      -OS,       *-OSNAP
      P,         *PAN
      -P,        *-PAN
      PA,        *PASTESPEC
      RAPIDPROTOTYPE, *3DPRINT
      PAR,       *PARAMETERS
      -PAR,      *-PARAMETERS
      PARAM,     *BPARAMETER
      PARTIALOPEN, *-PARTIALOPEN
      PATCH,     *SURFPATCH
      PC,        *POINTCLOUD
      PCATTACH,  *POINTCLOUDATTACH
      PCINDEX,   *POINTCLOUDINDEX
      PE,        *PEDIT
      PL,        *PLINE
      PO,        *POINT
      POFF,      *HIDEPALETTES
      POINTON,   *CVSHOW
      POINTOFF,  *CVHIDE
      POL,       *POLYGON
      PON,       *SHOWPALETTES
      PR,        *PROPERTIES
      PRCLOSE,   *PROPERTIESCLOSE
      PROPS,     *PROPERTIES
      PRE,       *PREVIEW
      PRINT,     *PLOT
      PS,        *PSPACE
      PSOLID,    *POLYSOLID
      PTW,       *PUBLISHTOWEB
      PU,        *PURGE
      -PU,       *-PURGE
      PYR,       *PYRAMID
      QC,        *QUICKCALC
      QCUI,      *QUICKCUI
      QP,        *QUICKPROPERTIES
      R,         *REDRAW
      RA,        *REDRAWALL
      RC,        *RENDERCROP
      RE,        *REGEN
      REA,       *REGENALL
      REBUILD,   *CVREBUILD
      REC,       *RECTANG
      REFINE,    *MESHREFINE
      REG,       *REGION
      REMOVECONTROLPOINT, *CVREMOVE
      REN,       *RENAME
      -REN,      *-RENAME
      REV,       *REVOLVE
      RO,        *ROTATE
      RP,        *RENDERPRESETS
      RPR,       *RPREF
      RR,        *RENDER
      RW,        *RENDERWIN
      S,         *STRETCH
      SC,        *SCALE
      SCR,       *SCRIPT
      SE,        *DSETTINGS
      SEC,       *SECTION
      SET,       *SETVAR
      SHA,       *SHADEMODE
      SL,        *SLICE
      SMOOTH,    *MESHSMOOTH
      SN,        *SNAP
      SO,        *SOLID
      SP,        *SPELL
      SPL,       *SPLINE
      SPLANE,    *SECTIONPLANE
      SPLAY,     *SEQUENCEPLAY
      SPLIT,     *MESHSPLIT
      SPE,       *SPLINEDIT
      SSM,       *SHEETSET
      ST,        *STYLE
      STA,       *STANDARDS
      SU,        *SUBTRACT
      T,         *MTEXT
      -T,        *-MTEXT
      TA,        *TABLET
      TB,        *TABLE
      TEDIT,     *TEXTEDIT
      TH,        *THICKNESS
      TI,        *TILEMODE
      TO,        *TOOLBAR
      TOL,       *TOLERANCE
      TOR,       *TORUS
      TP,        *TOOLPALETTES
      TR,        *TRIM
      TS,        *TABLESTYLE
      UC,        *UCSMAN
      UN,        *UNITS
      -UN,       *-UNITS
      UNCREASE,  *MESHUNCREASE
      UNHIDE,    *UNISOLATEOBJECTS
      UNI,       *UNION
      UNISOLATE, *UNISOLATEOBJECTS
      V,         *VIEW
      VGO,       *VIEWGO
      VPLAY,     *VIEWPLAY
      -V,        *-VIEW
      VP,        *DDVPOINT
      -VP,       *VPOINT
      VS,    *VSCURRENT
      VSM,       *VISUALSTYLES
      -VSM,      *-VISUALSTYLES
      W,         *WBLOCK
      -W,        *-WBLOCK
      WE,        *WEDGE
      WHEEL,     *NAVSWHEEL
      X,         *EXPLODE
      XA,        *XATTACH
      XB,        *XBIND
      -XB,       *-XBIND
      XC,        *XCLIP
      XL,        *XLINE
      XR,        *XREF
      -XR,       *-XREF
      Z,         *ZOOM
      ZEBRA,     *ANALYSISZEBRA
      ; The following are alternative aliases and aliases as supplied
      ;  in AutoCAD Release 13.
      AV,        *DSVIEWER
      CP,        *COPY
      DIMALI,    *DIMALIGNED
      DIMANG,    *DIMANGULAR
      DIMBASE,   *DIMBASELINE
      DIMCONT,   *DIMCONTINUE
      DIMDIA,    *DIMDIAMETER
      DIMED,     *DIMEDIT
      DIMTED,    *DIMTEDIT
      DIMLIN,    *DIMLINEAR
      DIMORD,    *DIMORDINATE
      DIMRAD,    *DIMRADIUS
      DIMSTY,    *DIMSTYLE
      DIMOVER,   *DIMOVERRIDE
      LEAD,      *LEADER
      TM,        *TILEMODE
      ; Aliases for Hyperlink/URL Release 14 compatibility
      SAVEURL, *SAVE
      OPENURL,   *OPEN
      INSERTURL, *INSERT
      ; Aliases for commands discontinued in AutoCAD 2000:
      AAD,        *DBCONNECT
      AEX,        *DBCONNECT
      ALI,        *DBCONNECT
      ASQ,        *DBCONNECT
      ARO,        *DBCONNECT
      ASE,        *DBCONNECT
      DDATTDEF,   *ATTDEF
      DDATTEXT,   *ATTEXT
      DDCHPROP,   *PROPERTIES
      DDCOLOR,    *COLOR
      DDLMODES,   *LAYER
      DDLTYPE,    *LINETYPE
      DDMODIFY,   *PROPERTIES
      DDOSNAP,    *OSNAP
      DDUCS,      *UCS
      ; Aliases for commands discontinued in AutoCAD 2004:
      ACADBLOCKDIALOG,  *BLOCK
      ACADWBLOCKDIALOG, *WBLOCK
      ADCENTER,         *ADCENTER
      BMAKE,            *BLOCK
      BMOD,             *BLOCK
      BPOLY,            *BOUNDARY
      CONTENT,          *ADCENTER
      DDATTE,           *ATTEDIT
      DDIM,             *DIMSTYLE
      DDINSERT,         *INSERT
      DDPLOTSTAMP,      *PLOTSTAMP
      DDRMODES,         *DSETTINGS
      DDSTYLE,          *STYLE
      DDUCS,            *UCSMAN
      DDUCSP,           *UCSMAN
      DDUNITS,          *UNITS
      DDVIEW,           *VIEW
      DIMHORIZONTAL,    *DIMLINEAR
      DIMROTATED,       *DIMLINEAR
      DIMVERTICAL,      *DIMLINEAR
      DOUGHNUT,         *DONUT
      DTEXT,            *TEXT
      DWFOUT,           *PLOT
      DXFIN,            *OPEN
      DXFOUT,           *SAVEAS
      PAINTER,          *MATCHPROP
      PREFERENCES,      *OPTIONS
      RECTANGLE,        *RECTANG
      SHADE,            *SHADEMODE
      VIEWPORTS,        *VPORTS
      EDWFX,            *EXPORTDWFX
      EDWF,             *EXPORTDWF
      EPDF,             *EXPORTPDF
      -QPUB,            *-EXPORT
      ; Aliases for commands discontinued in AutoCAD 2007:
      RMAT,      *MATBROWSEROPEN
      FOG,       *RENDERENVIRONMENT
      FINISH,    *MATERIALS
      SETUV,     *MATERIALMAP
      SHOWMAT,   *LIST
      RFILEOPT,  *RENDERPRESETS
      RENDSCR,   *RENDERWIN
      ; Aliases for commands discontinued in AutoCAD 2009:
      DASHBOARD,          *RIBBON
      DASHBOARDCLOSE,     *RIBBONCLOSE
      ; Aliases for sysvars discontinued in AutoCAD 2013:
      RASTERPREVIEW,      *THUMBSAVE
      AUTOCOMPLETE,       *-INPUTSEARCHOPTIONS
      AUTOCOMPLETEMODE,   *-INPUTSEARCHOPTIONS
      AUTOCOMPLETEDELAY,  *INPUTSEARCHDELAY
      ;  Make any changes or additions to the default AutoCAD command aliases in
      ;  this section to ensure successful migration of these settings when you
      ;  upgrade to the next version of AutoCAD.  If a command alias appears more
      ;  than once in this file, items in the User Defined Command Alias take
      ;  precedence over duplicates that appear earlier in the file.
      ;  **********———-**********  ; No xlate ; DO NOT REMOVE
