홈/ 질문/Q 108092
등록일: 2017-03-092017-03-09T15:55:18+09:00 2017-03-09T15:55:18+09:00카테고리: AutoCAD & CADian
문자나누기 리습입니다….질문있어 올립니다..한번봐주세요^^
(defun c:tdv(/ kw)
  (prompt ” Text Cutting & Merge…”)
  (initget “Cutting Merge”)
  (setq kw (getkword “n문자편집선택 [자르기(Cutting) / 합치기(Merge)] <자르기>: “))
  (if (= kw nil) (setq kw “Cutting”))
  (cond ((= kw “Cutting”) (@txtcut) )
          ((= kw “Merge”) (@txtmerge) )
          ((= kw “”  )  (princ)  )
  (prin1)
;text cut
(defun @txtcut (/ ss en1 oldtxt sn st txt osl nsl tno ox condi txt1 txt2 h ang en2 t_sub_txt len)
   (setvar “cmdecho” 0)  (setq ss nil)
   (while (= ss nil) (setq ss (ssget “:s” (list (cons 0 “text”))))  )
      (setq en1 (ssname ss 0))
      (setq oldtxt (cdr (assoc 1 (entget en1))))
      (setq sn (cdr (assoc 7 (entget en1))))
      (setq st t)
      (while st
         (setq txt (getstring “n분리될 첫단어: “))
         (if txt   (setq st nil) )
      (setq osl (strlen oldtxt))
      (setq nsl (strlen txt))
      (setq tno 1) (setq st t)
      (while (and st (< tno osl))
             (setq ox (substr oldtxt tno nsl))
             (if (= ox txt)
                 (setq st nil condi t)
                 (setq tno (1+ tno))
      (if condi
          (progn
             (setq txt1 (substr oldtxt 1 (- tno 1)))
             (setq txt2 (substr oldtxt tno (- osl (- tno 1))))
             (setq h (cdr (assoc 40 (entget en1))))
             (setq ang (cdr (assoc 50 (entget en1))))
             (command “copy” en1 “” (list 0.0 0.0 0.0)
                      (polar (list 0.0 0.0 0.0) (- ang (/ pi 2.0)) (* h 2.0))
             (setq en2 (ssname (ssget “l”) 0))
             (setq t_sub_txt (strcase (substr txt1 1 3)))
             (if (= (strcase t_sub_txt) “%%U”) (setq txt1 (strcat txt1 “%%u”)) )
             (entmod (subst (cons 1 txt1) (assoc 1 (entget en1)) (entget en1) )  )
             (setq len (strlen txt2))
             (setq t_sub_txt (strcase (substr txt2 (- len 2) 3)))
             (if (= (strcase t_sub_txt) “%%U”) (setq txt2 (strcat “%%u” txt2))  )
             (entmod (subst (cons 1 txt2) (assoc 1 (entget en2)) (entget en2) )  )
;text merge
(defun @txtmerge (/ en1 en2 elist1 elist2 plist1 tx1 tx2 tx3)
    (setq elist1 (entget (car (entsel “n첫번째 문자: “))))
    (setq  en2 (car (entsel “n두번째 문자: “)))
    (setq en1 (cdr (assoc -1 elist1)))
    (setq  elist2 (entget en2))
    (if (not (equal en1 en2)) (progn
        (setq plist1 (assoc 1 elist1))
        (setq tx1 (cdr plist1))
        (setq tx2 (cdr (assoc 1 elist2)))
        (setq tx3 (strcat tx1 tx2))
        (entmod (subst (cons 1 tx3) plist1 elist1))
        (command “erase” en2 “”)   )
문자 나누어 주는 리습입니다…혹시  이게 한번에 여러문자를 선택할수있는지요??? 그리고…
구분기호를 매번넣어야 하는데 한번들어간게 기억될수있게 할수없는지요??ㅠㅠ
추가적으로 이리습은 일반텍스트만가능한가요? 엠텍스는 불가능할까요?
  • 238 조회
    • 캐드2007에서 다중지시선 메뉴가 없나요?
    • 이벤트 공유
