홈/ 질문/Q 112061
등록일: 2019-12-302019-12-30T10:46:33+09:00 2019-12-30T10:46:33+09:00카테고리: AutoCAD & CADian
변곡 강연선 그리기 VBA
변곡 강연선 그리기 VBA 입니다.
(이미지 추가가 여의치 않아 블로그 링크합니다.)
https://blog.naver.com/kimdhj77/221753925772
Sub te2()
    Dim Pnt1, Pnt2 As Variant ‘2points
    Pnt1 = ThisDrawing.Utility.GetPoint(, “1st Point”)
    Pnt2 = ThisDrawing.Utility.GetPoint(, “2nd Point”)
    Dim l, h As Double
    l = Pnt2(0) – Pnt1(0)
    h = Pnt2(1) – Pnt1(1)
    Dim a As Double ‘circle R
    a = (h * h + l * l) / (4 * h)
    Dim circlePnt1(2) As Double
    Dim circlePnt2(2) As Double
    circlePnt1(0) = Pnt1(0)
    circlePnt1(1) = Pnt1(1) + a
    circlePnt2(0) = Pnt2(0)
    circlePnt2(1) = Pnt2(1) – a
    Dim m As Double ‘inclined
    m = (h / 2 – a) / (l / 2)
    Dim strA, endA As Double
    strA = 3.14159265358979 * 1.5
    endA = Atn(m) + 2 * 3.14159265358979
    Dim strA2, endA2 As Double
    strA2 = 3.14159265358979 * 0.5
    endA2 = Atn(m) – 3.14159265358979
    Dim arcObj As AcadArc
    If l > 0 And h > 0 Then
        Set arcObj = ThisDrawing.ModelSpace.AddArc(circlePnt1, a, strA, endA)
        Set arcObj = ThisDrawing.ModelSpace.AddArc(circlePnt2, a, strA2, endA2)
    Else
        MsgBox “Only from left & bottom to right & Up!!!”
    End If
    ‘  (defun c:te2()(command “-vbarun” “te2”)(princ))
End Sub
  • 19 조회
