홈/ 질문/Q 111447
등록일: 2019-06-202019-06-20T13:46:43+09:00 2019-06-20T13:46:43+09:00카테고리: AutoCAD & CADian
뷰포이트 관련 리습 문의드립니다.
안녕하세요
뷰포트를 저장하는 리습이 되었다 안되었다 합니다.
경로도 바꿔봤는데 안되고요
고수님들 도와주세요 ㅠㅅㅠ
;;;;;;;;원하는 지점으로 이동(ver.2019);;;;;;;;;;;;;;;
(defun c:q (/ Program FilesAutodeskAutoCAD 2019);;윈도우 중심점과 연계하기
  (vl-load-com)
  (setq fn (getvar “DWGPREFIX”))
  (setq tit (open “C:Program FilesAutodeskAutoCAD 2019” “acad”))
  (setq cwxy (getvar “VIEWCTR”))  ;;뷰중심포인트
  (setq cwsz (getvar “VIEWSIZE”)) ;;뷰크기
  (setq cwszy (/ cwsz 2.0))(setq cwszx (* cwszy 1.5))
  ;;뷰중심 계산
  (setq ux (- (car cwxy) cwszx)) (setq uy (+ (cadr cwxy) cwszy))
  (setq lx (+ (car cwxy) cwszx)) (setq ly (- (cadr cwxy) cwszy))
  ;(command “zoom” “w” (list ux uy) (list lx ly))
  (write-line (strcat (rtos ux) “,” (rtos uy)) tit) ;;좌상
  (write-line (strcat (rtos lx) “,” (rtos ly)) tit) ;;우하
  (write-line (strcat (rtos (car cwxy)) “,” (rtos (cadr cwxy))) tit) ;;중심점
  (write-line (rtos cwsz) tit) ;;뷰크기
  (close tit)
  (print “중심점 저장됨..>뷰이동가능”)
(defun c:qq (/ Program FilesAutodeskAutoCAD 2019);;윈도우 중심점과 연계하기
  (vl-load-com)
  (setq uxy (read-line tit))
  (setq lxy (read-line tit))
  (setq cxy (read-line tit))
  (setq siz (read-line tit))
  (command “zoom” “w” uxy lxy)
  (command “zoom” “c” cxy siz)
  (close tit)
(defun c:gen14 ()
   (setvar “cmdecho” 0)
      (setq xx1 (ssget)) ;; “x” ‘((0 . “LWPOLYLINE”))))
      (setq num (sslength xx1))
      (setq nun nun)
      (setq index 0)
 (repeat num
   (setq entl (entget (ssname xx1 index)))
   (setq index (1+ index))
   (setq inddd (+ index 5))
   (if (= (rem inddd 4) 1)
       (setq zz ” / “)
       (if (= (rem inddd 4) 2)
    (setq zz ” - “)
    (if (= (rem inddd 4) 3)
         (setq zz ” | “)
       (setq zz ” \ “)
   (setq ass (assoc 0 entl))
   (setq cha (cdr (assoc 8 entl)))
  (if (= “LWPOLYLINE” (cdr ass))
     (progn
     (setq se1 (car entl))
     (setq se2 (cdr se1))
     (command “pedit” se2 “L” “on” “”)
(prompt “r”) (prompt zz) (prompt ” Full Pline type ON..”) (princ index) (prompt “/”) (princ num)
  • 60 조회
