홈/ 질문/Q 109988
깨드해
깨드해Lv.0
등록일: 2018-06-262018-06-26T17:35:30+09:00 2018-06-26T17:35:30+09:00카테고리: AutoCAD & CADian
블럭을 가져다 쓰는 리습인데 질문 있습니다.
;——– ERROR PART START ————-
(defun jerr (jj)
    (if (/= jj “nFunction cancelled”)
        (princ (strcat “nError : ” jj))
    (setvar “cmdecho” jod-cm)
    (setq *error* oderr oderr nil jodcm nil)
;——– ERROR PART END —————
;——– MAIN PART START ————–
(defun c:scr()
(graphscr)
(setq oderr *error* *error* jerr
      jod-cm     (getvar “cmdecho”)
(setq sna1(getvar “snapmode”))
(setvar “snapmode” 0)
(princ “n”)(command “cmdecho” 1)
;;;;;;(command “zoom” “w” “0,0” “30,20” “vslide” “pipi_ico”)
(command “vslide” “pipi_ico”)
(setq cp (getvar “viewctr”))
(setq h (/ (getvar “viewsize”) 2))
(setq base1x (car cp))
(setq base1y (cadr cp))
(setq basex (- base1x (* h (/ 15 9.0))))
(setq basey (- base1y h))
;(setq ghky1 (- y h))
(setq scale1(/ 18.2 (* h 2)))
;(setq scale1(- ghky h))
(setq jhg 7)
(while jhg
  (initget 1)
  (setq pt  (getpoint “nSelect Working BOX : “)
        ghkptx (car pt)
        ghkpty (cadr pt)
  (setq tagetx (- ghkptx basex))
  (setq tagety (- ghkpty basey))
  (setq ptx (* tagetx scale1))
  (setq pty (* tagety scale1))
  (if (and (and (>= ptx 1.0) (<= ptx 29.0)) (and (>= pty 1.0)(<= pty 17.0)))
      (progn
         (if (and (and (>= ptx 1.0)  (<= ptx 3.0))  (and (>= pty 15.0) (<= pty 17.0)))  (setq work 1))
         (if (and (and (>= ptx 3.0)  (<= ptx 5.0))  (and (>= pty 15.0) (<= pty 17.0)))  (setq work 2))
         (if (and (and (>= ptx 5.0)  (<= ptx 7.0))  (and (>= pty 15.0) (<= pty 17.0)))  (setq work 3))
         (if (and (and (>= ptx 7.0)  (<= ptx 9.0))  (and (>= pty 15.0) (<= pty 17.0)))  (setq work 4))
         (if (and (and (>= ptx 9.0)  (<= ptx 11.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 5))
         (if (and (and (>= ptx 11.0) (<= ptx 13.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 6))
         (if (and (and (>= ptx 13.0) (<= ptx 15.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 7))
         (if (and (and (>= ptx 15.0) (<= ptx 17.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 8))
         (if (and (and (>= ptx 17.0) (<= ptx 19.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 9))
         (if (and (and (>= ptx 19.0) (<= ptx 21.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 10))
         (if (and (and (>= ptx 21.0) (<= ptx 23.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 11))
         (if (and (and (>= ptx 23.0) (<= ptx 25.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 12))
         (if (and (and (>= ptx 25.0) (<= ptx 27.0)) (and (>= pty 15.0) (<= pty 17.0)))  (setq work 13))
         (if (and (and (>= ptx 27.0)  (<= ptx 29.0))  (and (>= pty 15.0) (<= pty 17.0)))  (setq work 14))
         (if (and (and (>= ptx 1.0)  (<= ptx 3.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 15))
         (if (and (and (>= ptx 3.0)  (<= ptx 5.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 16))
         (if (and (and (>= ptx 5.0)  (<= ptx 7.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 17))
         (if (and (and (>= ptx 7.0)  (<= ptx 9.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 18))
         (if (and (and (>= ptx 9.0)  (<= ptx 11.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 19))
         (if (and (and (>= ptx 11.0)  (<= ptx 13.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 20))
         (if (and (and (>= ptx 13.0)  (<= ptx 15.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 21))
         (if (and (and (>= ptx 15.0)  (<= ptx 17.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 22))
         (if (and (and (>= ptx 17.0)  (<= ptx 19.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 23))
         (if (and (and (>= ptx 19.0)  (<= ptx 21.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 24))
         (if (and (and (>= ptx 21.0)  (<= ptx 23.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 25))
         (if (and (and (>= ptx 23.0)  (<= ptx 25.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 26))
         (if (and (and (>= ptx 25.0)  (<= ptx 27.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 27))
         (if (and (and (>= ptx 27.0)  (<= ptx 29.0))  (and (>= pty 13.0) (<= pty 15.0)))  (setq work 28))
         (if (and (and (>= ptx 1.0)  (<= ptx 3.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 29))
         (if (and (and (>= ptx 3.0)  (<= ptx 5.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 30))
         (if (and (and (>= ptx 5.0)  (<= ptx 7.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 31))
         (if (and (and (>= ptx 7.0)  (<= ptx 9.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 32))
         (if (and (and (>= ptx 9.0)  (<= ptx 11.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 33))
         (if (and (and (>= ptx 11.0)  (<= ptx 13.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 34))
         (if (and (and (>= ptx 13.0)  (<= ptx 15.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 35))
         (if (and (and (>= ptx 15.0)  (<= ptx 17.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 36))
         (if (and (and (>= ptx 17.0)  (<= ptx 19.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 37))
         (if (and (and (>= ptx 19.0)  (<= ptx 21.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 38))
         (if (and (and (>= ptx 21.0)  (<= ptx 23.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 39))
         (if (and (and (>= ptx 23.0)  (<= ptx 25.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 40))
         (if (and (and (>= ptx 25.0)  (<= ptx 27.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 41))
         (if (and (and (>= ptx 27.0)  (<= ptx 29.0))  (and (>= pty 11.0) (<= pty 13.0)))  (setq work 42))
         (if (and (and (>= ptx 1.0)  (<= ptx 3.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 43))
         (if (and (and (>= ptx 3.0)  (<= ptx 5.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 44))
         (if (and (and (>= ptx 5.0)  (<= ptx 7.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 45))
         (if (and (and (>= ptx 7.0)  (<= ptx 9.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 46))
         (if (and (and (>= ptx 9.0)  (<= ptx 11.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 47))
         (if (and (and (>= ptx 11.0)  (<= ptx 13.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 48))
         (if (and (and (>= ptx 13.0)  (<= ptx 15.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 49))
         (if (and (and (>= ptx 15.0)  (<= ptx 17.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 50))
         (if (and (and (>= ptx 17.0)  (<= ptx 19.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 51))
         (if (and (and (>= ptx 19.0)  (<= ptx 21.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 52))
         (if (and (and (>= ptx 21.0)  (<= ptx 23.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 53))
         (if (and (and (>= ptx 23.0)  (<= ptx 25.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 54))
         (if (and (and (>= ptx 25.0)  (<= ptx 27.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 55))
         (if (and (and (>= ptx 27.0)  (<= ptx 29.0))  (and (>= pty 9.0) (<= pty 11.0)))  (setq work 56))
         (if (and (and (>= ptx 1.0)  (<= ptx 3.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 57))
         (if (and (and (>= ptx 3.0)  (<= ptx 5.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 58))
         (if (and (and (>= ptx 5.0)  (<= ptx 7.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 59))
         (if (and (and (>= ptx 7.0)  (<= ptx 9.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 60))
         (if (and (and (>= ptx 9.0)  (<= ptx 11.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 61))
         (if (and (and (>= ptx 11.0)  (<= ptx 13.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 62))
         (if (and (and (>= ptx 13.0)  (<= ptx 15.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 63))
         (if (and (and (>= ptx 15.0)  (<= ptx 17.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 64))
         (if (and (and (>= ptx 17.0)  (<= ptx 19.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 65))
         (if (and (and (>= ptx 19.0)  (<= ptx 21.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 66))
         (if (and (and (>= ptx 21.0)  (<= ptx 23.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 67))
         (if (and (and (>= ptx 23.0)  (<= ptx 25.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 68))
         (if (and (and (>= ptx 25.0)  (<= ptx 27.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 69))
         (if (and (and (>= ptx 27.0)  (<= ptx 29.0))  (and (>= pty 7.0) (<= pty 9.0)))  (setq work 70))
         (if (and (and (>= ptx 1.0)  (<= ptx 3.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 71))
         (if (and (and (>= ptx 3.0)  (<= ptx 5.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 72))
         (if (and (and (>= ptx 5.0)  (<= ptx 7.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 73))
         (if (and (and (>= ptx 7.0)  (<= ptx 9.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 74))
         (if (and (and (>= ptx 9.0)  (<= ptx 11.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 75))
         (if (and (and (>= ptx 11.0)  (<= ptx 13.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 76))
         (if (and (and (>= ptx 13.0)  (<= ptx 15.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 77))
         (if (and (and (>= ptx 15.0)  (<= ptx 17.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 78))
         (if (and (and (>= ptx 17.0)  (<= ptx 19.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 79))
         (if (and (and (>= ptx 19.0)  (<= ptx 21.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 80))
         (if (and (and (>= ptx 21.0)  (<= ptx 23.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 81))
         (if (and (and (>= ptx 23.0)  (<= ptx 25.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 82))
         (if (and (and (>= ptx 25.0)  (<= ptx 27.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 83))
         (if (and (and (>= ptx 27.0)  (<= ptx 29.0))  (and (>= pty 5.0) (<= pty 7.0)))  (setq work 84))
         (if (and (and (>= ptx 1.0)  (<= ptx 3.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 85))
         (if (and (and (>= ptx 3.0)  (<= ptx 5.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 86))
         (if (and (and (>= ptx 5.0)  (<= ptx 7.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 87))
         (if (and (and (>= ptx 7.0)  (<= ptx 9.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 88))
         (if (and (and (>= ptx 9.0)  (<= ptx 11.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 89))
         (if (and (and (>= ptx 11.0)  (<= ptx 13.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 90))
         (if (and (and (>= ptx 13.0)  (<= ptx 15.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 91))
         (if (and (and (>= ptx 15.0)  (<= ptx 17.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 92))
         (if (and (and (>= ptx 17.0)  (<= ptx 19.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 93))
         (if (and (and (>= ptx 19.0)  (<= ptx 21.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 94))
         (if (and (and (>= ptx 21.0)  (<= ptx 23.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 95))
         (if (and (and (>= ptx 23.0)  (<= ptx 25.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 96))
         (if (and (and (>= ptx 25.0)  (<= ptx 27.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 97))
         (if (and (and (>= ptx 27.0)  (<= ptx 29.0))  (and (>= pty 3.0) (<= pty 5.0)))  (setq work 98))
         (if (and (and (>= ptx 1.0)  (<= ptx 3.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 99))
         (if (and (and (>= ptx 3.0)  (<= ptx 5.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 100))
         (if (and (and (>= ptx 5.0)  (<= ptx 7.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 101))
         (if (and (and (>= ptx 7.0)  (<= ptx 9.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 102))
         (if (and (and (>= ptx 9.0)  (<= ptx 11.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 103))
         (if (and (and (>= ptx 11.0)  (<= ptx 13.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 104))
         (if (and (and (>= ptx 13.0)  (<= ptx 15.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 105))
         (if (and (and (>= ptx 15.0)  (<= ptx 17.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 106))
         (if (and (and (>= ptx 17.0)  (<= ptx 19.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 107))
         (if (and (and (>= ptx 19.0)  (<= ptx 21.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 108))
         (if (and (and (>= ptx 21.0)  (<= ptx 23.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 109))
         (if (and (and (>= ptx 23.0)  (<= ptx 25.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 110))
         (if (and (and (>= ptx 25.0)  (<= ptx 27.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 111))
         (if (and (and (>= ptx 27.0)  (<= ptx 29.0))  (and (>= pty 1.0) (<= pty 3.0)))  (setq work 112))
         (setq jhg nil)
      (progn
         (prompt “Select again in BOX”)
(command “‘redraw”)
(cond
      ((= work 1)   (load “e-01”)   (c:e-01))
      ((= work 2)   (load “e-02”)   (c:e-02))
      ((= work 3)   (load “e-03”)   (c:e-03))
      ((= work 4)   (load “e-04”)   (c:e-04))
      ((= work 5)   (load “e-05”)   (c:e-05))
      ((= work 6)   (load “e-06”)   (c:e-06))
      ((= work 7)   (load “e-07”)   (c:e-07))
      ((= work 8)   (load “e-08”)   (c:e-08))
      ((= work 9)   (load “e-09”)   (c:e-09))
      ((= work 10)   (load “e-57”)   (c:e-57))
      ((= work 11)   (load “01”)   (c:01))
      ((= work 12)   (load “02”)   (c:02))
      ((= work 13)   (load “03”)   (c:03))
      ((= work 14)   (load “04”)   (c:04))
      ((= work 15)   (load “e-10”)   (c:e-10))
      ((= work 16)   (load “e-11”)   (c:e-11))
      ((= work 17)   (load “e-12”)   (c:e-12))
      ((= work 18)   (load “e-12-1”)   (c:e-12-1))
      ((= work 19)   (load “e-13”)   (c:e-13))
      ((= work 20)   (load “e-13-1”)   (c:e-13-1))
      ((= work 21)   (load “e-14”)   (c:e-14))
      ((= work 22)   (load “e-15”)   (c:e-15))
      ((= work 23)   (load “e-16”)   (c:e-16))
      ((= work 24)   (load “e-58”)   (c:e-58))
      ((= work 25)   (load “05”)   (c:05))
      ((= work 26)   (load “06”)   (c:06))
      ((= work 27)   (load “07”)   (c:07))
      ((= work 28)   (load “08”)   (c:08))
      ((= work 29)   (load “e-17”)   (c:e-17))
      ((= work 30)   (load “e-17-1”)   (c:e-17-1))
      ((= work 31)   (load “e-18”)   (c:e-18))
      ((= work 32)   (load “e-19”)   (c:e-19))
      ((= work 33)   (load “e-19-1”)   (c:e-19-1))
      ((= work 34)   (load “e-20”)   (c:e-20))
      ((= work 35)   (load “e-21”)   (c:e-21))
      ((= work 36)   (load “e-22”)   (c:e-22))
      ((= work 37)   (load “e-22-1”)   (c:e-22-1))
      ((= work 38)   (load “e-59”)   (c:e-59))
      ((= work 39)   (load “09”)   (c:09))
      ((= work 40)   (load “10”)   (c:10))
      ((= work 41)   (load “11”)   (c:11))
      ((= work 42)   (load “12”)   (c:12))
      ((= work 43)   (load “e-23”)   (c:e-23))
      ((= work 44)   (load “e-23-1”)   (c:e-23-1))
      ((= work 45)   (load “e-24”)   (c:e-24))
      ((= work 46)   (load “e-25”)   (c:e-25))
      ((= work 47)   (load “e-25-1”)   (c:e-25-1))
      ((= work 48)   (load “e-26”)   (c:e-26))
      ((= work 49)   (load “e-27”)   (c:e-27))
      ((= work 50)   (load “e-27-1”)   (c:e-27-1))
      ((= work 51)   (load “e-28”)   (c:e-28))
      ((= work 52)   (load “e-60”)   (c:e-60))
      ((= work 53)   (load “13”)   (c:13))
      ((= work 54)   (load “14”)   (c:14))
      ((= work 55)   (load “15”)   (c:15))
      ((= work 56)   (load “16”)   (c:16))
      ((= work 57)   (load “e-29”)   (c:e-29))
      ((= work 58)   (load “e-29-1”)   (c:e-29-1))
      ((= work 59)   (load “e-30”)   (c:e-30))
      ((= work 60)   (load “e-31”)   (c:e-31))
      ((= work 61)   (load “e-31-1”)   (c:e-31-1))
      ((= work 62)   (load “e-32”)   (c:e-32))
      ((= work 63)   (load “e-33”)   (c:e-33))
      ((= work 64)   (load “e-34”)   (c:e-34))
      ((= work 65)   (load “e-34-1”)   (c:e-34-1))
      ((= work 66)   (load “000”)   (c:000))
      ((= work 67)   (load “17”)   (c:17))
      ((= work 68)   (load “18”)   (c:18))
      ((= work 69)   (load “19”)   (c:19))
      ((= work 70)   (load “20”)   (c:20))
      ((= work 71)   (load “e-35”)   (c:e-35))
      ((= work 72)   (load “e-35-1”)   (c:e-35-1))
      ((= work 73)   (load “e-35-2”)   (c:e-35-2))
      ((= work 74)   (load “e-35-3”)   (c:e-35-3))
      ((= work 75)   (load “e-35-4”)   (c:e-35-4))
      ((= work 76)   (load “e-35-5”)   (c:e-35-5))
      ((= work 77)   (load “e-36”)   (c:e-36))
      ((= work 78)   (load “e-37”)   (c:e-37))
      ((= work 79)   (load “e-38”)   (c:e-38))
      ((= work 80)   (load “000”)   (c:000))
      ((= work 81)   (load “21”)   (c:21))
      ((= work 82)   (load “22”)   (c:22))
      ((= work 83)   (load “23”)   (c:23))
      ((= work 84)   (load “24”)   (c:24))
      ((= work 85)   (load “e-39”)   (c:e-39))
      ((= work 86)   (load “e-40”)   (c:e-40))
      ((= work 87)   (load “e-41”)   (c:e-41))
      ((= work 88)   (load “e-42”)   (c:e-42))
      ((= work 89)   (load “e-43”)   (c:e-43))
      ((= work 90)   (load “e-44”)   (c:e-44))
      ((= work 91)   (load “e-45”)   (c:e-45))
      ((= work 92)   (load “e-46”)   (c:e-46))
      ((= work 93)   (load “e-47”)   (c:e-47))
      ((= work 94)   (load “000”)   (c:000))
      ((= work 95)   (load “25”)   (c:25))
      ((= work 96)   (load “26”)   (c:26))
      ((= work 97)   (load “27”)   (c:27))
      ((= work 98)   (load “28”)   (c:28))
      ((= work 99)   (load “e-48”)   (c:e-48))
      ((= work 100)   (load “e-49”)   (c:e-49))
      ((= work 101)   (load “e-50”)   (c:e-50))
      ((= work 102)   (load “e-51”)   (c:e-51))
      ((= work 103)   (load “e-52”)   (c:e-52))
      ((= work 104)   (load “e-53”)   (c:e-53))
      ((= work 105)   (load “e-54”)   (c:e-54))
      ((= work 106)   (load “e-55”)   (c:e-55))
      ((= work 107)   (load “e-56”)   (c:e-56))
      ((= work 108)   (load “000”)   (c:000))
      ((= work 109)   (load “29”)   (c:29))
      ((= work 110)   (load “30”)   (c:30))
      ((= work 111)   (load “31”)   (c:31))
      ((= work 112)   (load “32”)   (c:32))
(setvar “snapmode” sna1)
(setq *error* oderr oderr nil jod-cm nil)
;———– MAIN PART END ————
표내에있는 블럭을 찍어서 가져오는 리습입니다.
근데 가져올때 x 1~3 y 1~3 쪽을 찍어서 가져왔는데 엉뚱한 그림이 튀어나옵니다.
어떤게 문제인지 알려주시면 감사하겠습니다.
아 그리고 위에 색칠부분에 9.0하고 18.2가 어떻게 나온 값인지도 알고싶습니다..
  • 40 조회
    2. 수야12 Lv.22
      2018-06-26T19:25:33+09:00답변 등록 답변 등록 일시 2018-06-26 7:25 pm
      emoticon ca초보님 아이디 바꾸고 다시 올리셨네 하하하…
      그냥 제가 초보라서 잘 몰라서 그댔다구 피드백 없던거 죄송 합니다  이 한마디하시면 될것을
      게시글 지우고 아이디 바꾸시고 다시 올리시다니 참 대단하십니다….
      어차피 고캐드에서 답글 달아주시는 분들은 뻔해요 몇분 안되십니다 그분들은 최소한의
      매너를 요구하는것인데 그게 그렇게 힘드시나요???
      2018-06-26T19:25:59+09:00답변 등록 답변 등록 일시 2018-06-26 7:25 pm
      닉까지 바꿔가면서 계속 올리시는걸 보니, 정말 수정하고 싶어하시는 것 같긴 한데요,
      이걸 직접 원하는데로 수정하시려면 공부를 많이 하셔야 할꺼예요.
      9.0과 18.2는 좌표 때문에 들어간겁니다.
      vslide로 슬라이드 이미지를 띄운 다음, 화면을 원하는 곳으로 움직이는 거예요.
      슬라이드는 일종의 이미지라서, 오토캐드에 띄워 놓으면 이미지 아래쪽은 어차피 안보이거든요.
      이미지를 띄워놓은 다음, 마우스로 클릭해서 클릭한 지점의 좌표를 가져오고,
      그 좌표에 설정되어 있는 파일을 로드해서 집어 넣게 만들어둔 겁니다.
      그러니, 특정 파일에 특정 좌표가 항상 매칭이 되야겠죠.
      내 눈에 보인다고, 컴퓨터가 자동으로 인식하진 않거든요.
      정확한 값을 입력해줘야하는데, 직관적으로 형태가 보이면 편하니까,
      이런 과정이 필요한겁니다.
      화면을 조절하는 데에는 몇 가지 방법이 있는데,
      viewctr은 뷰의 중심점 좌표. viewsize는 뷰의 높이 값이예요.
      둘 다 특성창에 표시됩니다.
      뷰의 중심 좌표와 높이를 고정해서,
      이미지의 좌표값과 진짜 0,0을 맞추면…클릭한 좌표가 리습에 있는 숫자와 같아지니까,
      항상 정확하게 입력되도록 만든겁니다.
      근데 이미지랑 좌표랑 정확하게 맞진 않아서, 살짝 틀어져있네요. 경계선 근처를 클릭하면 옆에있는게 들어갈 수도 있어요.
      일단…얘기하신 부분을 클릭하면 파일을 로드하게 되어 있는데…
      로드할 파일이 없어서 슬라이드에 표시된 것과 같은지 다른지는 모르겠네요.
      그리고…앞으론 댓글이 있으면, 고맙다고 인사정도 하는 습관을 들이시는게 좋겠네요.
      글 삭제하지 마시구요.
      필요한 것만 딱 얻어서 가려면, 차라리 돈 쓰세요.
      여긴 묻고 답하면서 정보와 지식을 공유하는 곳이니까요.
      질문 올리신게 다 리습 관련된거던데,
      그렇게 필요하면, 공부 좀 하세요.
      기초부터.
      필요한거만 만들어달라고 올리지 말고.
    4. 깨드해 Lv.0
      2018-06-27T09:13:20+09:00답변 등록 답변 등록 일시 2018-06-27 9:13 am
      앞으로 주의하겠습니다. 답변 감사합니다.
