홈/ 질문/Q 88545
등록일: 2010-08-192010-08-19T07:53:26+09:00 2010-08-19T07:53:26+09:00카테고리: AutoCAD & CADian
상수제원쓰는리습인데 ERR가 나서 고수님들 한번 봐주세요(문제가무엇인지)
(defun c:xx(/ ent en8 vlist year kind ki dia dis simdo simlen i a sum simsn simen sim10 sim1 simdolist aver text yn
       tep te tee te10 b wi np spt d1 d2 pt1 pt2 lte ltee ang new_ro old_ro newent)
  (setvar “cmdecho” 0)
  (setq ent (entsel))
  (setq en8 (cdr (assoc 8 (entget (car ent)))))
  (setq vlist (list))
  (vlist_com ent)
  (setq year (getint “n 부설년도 :::”))
  (setq kind (getstring “n 관종 (1:CIP,  2:DCIP, 3:SSP, 4:SP, 5:HI-3P, 6:HIVP, 7:PVC,  8:PE,  9:PFP):::: “))
  (cond
      ((= kind “1”)(setq ki “CIP”))
      ((= kind “2”)(setq ki “DCIP”))
      ((= kind “3”)(setq ki “SSP”))
      ((= kind “4”)(setq ki “SP”))
      ((= kind “5”)(setq ki “HI-3P”))
      ((= kind “6”)(setq ki “HIVP”))
      ((= kind “7”)(setq ki “PVC”))
      ((= kind “8”)(setq ki “PE”))
      ((= kind “9”)(setq ki “PFP”)))
  (setq dia (getint “n 관경 :::::”))
  (command “area” “e” ent)
  (setq dis (getvar “perimeter”))
  (setq dis (/ dis 1.0))
  (if (/= en8 “SAA910”)(progn
    (setq simdo (ssget “x” ‘((8 . “SA9122”) (0 . “TEXT”))))
    (setq simlen (sslength simdo))
    (setq i 0 a 0 sum 0)
    (setq simdolist (list))
    (repeat simlen
      (setq simsn (ssname simdo i))(setq i (1+ i))
      (setq simen (entget simsn))
      (setq sim10 (cdr (assoc 10 simen)))
      (setq sim1 (cdr (assoc 1 simen)))
      (if (member sim10 vlist)
        (progn
          (if (not (member sim10 simdolist))
     (progn
       (setq simdolist (append simdolist (list sim10)))
       (setq a (1+ a))
       (setq sum (+ sum (atof sim1))))
     (progn
       (alert “심도 텍스트가 중복이다.”)
       (exit))))))
                         (if (/= a 0)(progn
      (setq aver (/ sum a)))
      (progn (setq aver 0.0)))
    (setq text (strcat (itoa year)”/”ki”/%%c”(itoa dia)”/L”(rtos dis 2 1)”/D”(rtos aver 2 1))))
                       (progn
    (setq text (strcat (itoa year)”/”ki”/%%c”(itoa dia)”/L”(rtos dis 2 1)”/D_”))))
  (setq yn (getstring “n인출선 사용여부(Y/N)::::”))
                        (cond
         ((= en8 “SAA001”)(command “layer” “s” “SAA0012” “”))
         ((= en8 “SAA002”)(command “layer” “s” “SAA0022” “”))
        ((= en8 “SAA003”)(command “layer” “s” “SAA0032” “”))
         ((= en8 “SAA004”)(command “layer” “s” “SAA0042” “”))
         ((= en8 “SAA0050”)(command “layer” “s” “SAA00502” “”))
         ((= en8 “SAA005”)(command “layer” “s” “SAA0052” “”))
         ((= en8 “SAA010”)(command “layer” “s” “SAA0102” “”))
         ((= en8 “SAA020”)(command “layer” “s” “SAA0202” “”))
         ((= en8 “SAA910”)(command “layer” “s” “SAA9102” “”)))
  (if (or (= yn “Y”) (= yn “y”)) (progn
    (setvar “osmode” 0)
    (setq tep (getpoint “n Pick a text point===>>>”))
    (command “text” tep “1.5” “0” text)
    (setq te (entlast))
    (setq tee (entget te))
    (setq te10 (cdr (assoc 10 tee)))
    (setq te10 (polar te10 (* 1.25 pi) 0.42))
    (setq b (textbox tee))
    (setq wi (- (caadr b) (caar b)))
    (setq np (polar te10 0 (+ wi 1.0)))
    (setvar “osmode” 512)
    (setq spt (getpoint “n Pick a neapoint ===>>>”))
    (setq d1 (distance te10 spt))
    (setq d2 (distance np spt))
    (setvar “osmode” 0)
    (if (< d1 d2)
      (progn
        (command “pline” spt te10 np “”))
      (progn
        (command “pline” spt np te10 “”)))))
  (if (or (= yn “n”)(= yn “N”))(progn
     (setq pt_1 (getpoint “n Pick a text point===>>>”))
     (setq pt_2 (getpoint pt_1 “n Pick a next point===>>>”))
     (setvar “osmode” 0)
     (command “text” pt_1 “1.5” “0” text)
     (setq lte (entlast))
     (setq ltee (entget lte))
     (setq ang (angle pt_1 pt_2))
                                 (setq new_ro (cons 50 ang))
                                 (setq old_ro (assoc 50 ltee))
                                 (setq newent (subst new_ro old_ro ltee))
                                 (entmod newent))))
(princ “n =======상수 Seed 는 엎었는지요???? 잘만들었지요??????==============”)
(defun vlist_com (ent / se ca ca1 ca11)
  (setq se (entget (car ent)))
  (setq ca (car se) se (cdr se))
  (while (/= ca nil)
    (if (= (car ca) 10)(progn
        (setq ca11 (cdr ca))
 (setq ca11 (append ca11 (list 0.0)))
 (setq vlist (append vlist (list ca11)))))
    (setq ca (car se))
    (setq se (cdr se)))vlist)
…error: bad argument type: lselsetp nil 자꾸 이런 메시지만 뜹니다.
  • 61 조회
