안녕하세요?
도면내에 사각형(pline)을 선택하여 그 내부를 자동으로 트림하려고합니다.
걸쳐있는 글자나 블록은 제외하고 트림하는 lisp을 구합니다.
이것은 기존에 외부 트림이라고 나온것인데
저는 내부를 좀 없애고 싶은데 영 이런 리습방면에 무지라… 좀 수정해주실분 있을까여?
기존 내부 자동트림
기존 내부 자동트림
(defun c:mp ( / Os_Md Et_pLo Lt_vtx Min_rX Min_rY Max_rX Max_rY
_tmp01 _tmp02 _tmp03 _tmp04 _tmL01 _tmAdd _tmRpt)
(setq olderr *error* *error* errchck)
(setq Os_md (getvar “Osmode”))
(setvar “cmdecho” 0)
(setvar “Osmode” 0)
(setq Et_pLo (car (entseL “n 테두리 요소를 선택하세요 “)) ) ;
(redraw Et_pLo 3)
(setq Lt_vtx niL)
(foreach f_e (entget Et_pLo)
(if (= (car f_e) 10) (setq Lt_vtx (append Lt_vtx (List (cdr f_e))) ) ) ; i
) ; r
(setq Min_rX (min (car (car Lt_vtx)) (car (cadr Lt_vtx)) (car (caddr Lt_vtx)) (car (cadddr Lt_vtx)))
Max_rX (max (car (car Lt_vtx)) (car (cadr Lt_vtx)) (car (caddr Lt_vtx)) (car (cadddr Lt_vtx)))
Min_rY (min (cadr (car Lt_vtx)) (cadr (cadr Lt_vtx)) (cadr (caddr Lt_vtx)) (cadr (cadddr Lt_vtx)))
Max_rY (max (cadr (car Lt_vtx)) (cadr (cadr Lt_vtx)) (cadr (caddr Lt_vtx)) (cadr (cadddr Lt_vtx))) )
(setq _tmp01 (list Min_rX Min_rY)
_tmp02 (list Max_rX Min_rY)
_tmp03 (list Max_rX Max_rY)
_tmp04 (list Min_rX Max_rY) ) ;
(setq _tmL01 1 ; … 최초 이격거리
_tmAdd 1 ; … 거리 증분
_tmRpt 150) ; … 반복 횟수
(Command “Erase” “ALL” “R” “C” _tmp01 _tmp03 “”)
(Command “Trim” Et_pLo “”)
(repeat _tmRpt
(Command “F” (polar _tmp01 (dtr 225) _tmL01) (polar _tmp02 (dtr 315) _tmL01) “”)
(Command “F” (polar _tmp02 (dtr 315) _tmL01) (polar _tmp03 (dtr 45) _tmL01) “”)
(Command “F” (polar _tmp03 (dtr 45) _tmL01) (polar _tmp04 (dtr 135) _tmL01) “”)
(Command “F” (polar _tmp04 (dtr 135) _tmL01) (polar _tmp01 (dtr 225) _tmL01) “”)
(setq _tmL01 (+ _tmL01 _tmAdd))
) ; r
(Command)
(setq Min_tX (car (getvar “ExtMin”))
Min_tY (cadr (getvar “ExtMin”))
Max_tX (car (getvar “ExtMax”))
Max_tY (cadr (getvar “ExtMax”)) ) ;
(Command “ERASE” “W” (list Min_tX Min_tY) (list Min_rX Max_tY) “”)
(Command “ERASE” “W” (list Min_tX Min_tY) (list Max_tX Min_rY) “”)
(Command “ERASE” “W” (list Min_tX Max_rY) (list Max_tX Max_tY) “”)
(Command “ERASE” “W” (list Max_rX Min_tY) (list Max_tX Max_tY) “”)
(setq Et_List (list (ssget “C” _tmp01 _tmp02 ‘((0 . “TEXT,INSERT”)))
(ssget “C” _tmp02 _tmp03 ‘((0 . “TEXT,INSERT”)))
(ssget “C” _tmp03 _tmp04 ‘((0 . “TEXT,INSERT”)))
(ssget “C” _tmp04 _tmp01 ‘((0 . “TEXT,INSERT”)))) ) ;
(foreach f_e Et_List
(if f_e
(progn
(setq _ij1 0)
(repeat (sslength f_e)
(entdel (ssname f_e _ij1))
(setq _ij1 (1+ _ij1))
) ; r
) ; p
) ; i
) ; f
(setVar “Osmode” Os_Md)
) ; de_fun
(defun dtr (_a / ) (/ (* _a pi) 180.) )
(setvar “Osmode” 0)
(redraw Et_pLo 3)
(setq Lt_vtx niL)
) ; r
_tmAdd 1 ; … 거리 증분
(repeat _tmRpt
) ; r
(Command)
(if f_e
(progn
(setq _ij1 0)
) ; r
) ; p
) ; i
) ; f
) ; de_fun
별다른 댓글이 달리지 않는 것을 보니, LISP으로 구현하는게 쉽지않은가 봅니다.
그냥 보이지않게 하는 것이 목적이라면 wipeout을 이용해보세여!
참고로, ArchiOffice(Xpress)의 잘라내기 기능입니다.
