홈/ 질문/Q 112058
등록일: 2019-12-282019-12-28T17:49:08+09:00 2019-12-28T17:49:08+09:00카테고리: AutoCAD & CADian
세점 포물선 그리기 VBA
2차 포물선 그리기 VBA입니다.
(이미지 추가가 여의치 않아 블로그 링크합니다.)
https://blog.naver.com/kimdhj77/221752345973
코드입니다.
Sub para()
    Dim Pnt1, Pnt2, Pnt3 As Variant ‘3points for parabola
    Pnt1 = ThisDrawing.Utility.GetPoint(, “1st Point”)
    Pnt2 = ThisDrawing.Utility.GetPoint(, “2nd Point”)
    Pnt3 = ThisDrawing.Utility.GetPoint(, “3rd Point”)
    Dim a, b, c As Double
    Dim M11, M12, M13, M21, M22, M23, M31, M32, M33 As Double
    Dim x1, x2, x3, y1, y2, y3, plusx, plusy As Double
    plusx = Pnt1(0) + Pnt3(0)
    plusy = Pnt1(1) + Pnt3(1)
    x1 = Pnt1(0) + plusx: x2 = Pnt2(0) + plusx: x3 = Pnt3(0) + plusx
    y1 = Pnt1(1) + plusy: y2 = Pnt2(1) + plusy: y3 = Pnt3(1) + plusy
    M11 = 1 / (x1 ^ 2 – x1 * x2 – x1 * x3 + x2 * x3)
    M12 = 1 / (x2 ^ 2 – x1 * x2 + x1 * x3 – x2 * x3)
    M13 = 1 / (x3 ^ 2 + x1 * x2 – x1 * x3 – x2 * x3)
    M21 = -(x2 + x3) / (x1 ^ 2 – x1 * x2 – x1 * x3 + x2 * x3)
    M22 = -(x1 + x3) / (x2 ^ 2 – x1 * x2 + x1 * x3 – x2 * x3)
    M23 = -(x1 + x2) / (x3 ^ 2 + x1 * x2 – x1 * x3 – x2 * x3)
    M31 = -(x1 * x3) * (x2 ^ 2 – x2 * x3) / (x1 ^ 2 – x1 * x3) / (x2 ^ 2 – x1 * x2 + x1 * x3 – x2 * x3)
    M32 = (x1 * x3) / (x2 ^ 2 – x1 * x2 + x1 * x3 – x2 * x3)
    M33 = -(x1 * x3) * (x2 ^ 2 – x1 * x2) / (x3 ^ 2 – x1 * x3) / (x2 ^ 2 – x1 * x2 + x1 * x3 – x2 * x3)
    a = M11 * y1 + M12 * y2 + M13 * y3
    b = M21 * y1 + M22 * y2 + M23 * y3
    c = M31 * y1 + M32 * y2 + M33 * y3
    Dim n As Integer ‘등분’
        n = InputBox(“What is the number of divided parabola?”)
    Dim interval As Double
        interval = (x3 – x1) / n
    Dim polyPnt() As Double
    ReDim polyPnt(2 * n + 1) As Double
    Dim i As Integer
    For i = 0 To n
        polyPnt(i * 2) = x1 + interval * i
        polyPnt(i * 2 + 1) = a * polyPnt(i * 2) ^ 2 + b * polyPnt(i * 2) + c
    Next i
    Dim Opnt1(2) As Double
    Dim Opnt2(2) As Double
        Opnt1(0) = 0: Opnt1(1) = 0: Opnt1(2) = 0
        Opnt2(0) = -plusx: Opnt2(1) = -plusy: Opnt2(2) = 0
    Dim polyObj As AcadLWPolyline
    Set polyObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(polyPnt)
        polyObj.Move Opnt1, Opnt2
End Sub
  • 115 조회
    • 캐드 좌표값을 위경도값으로 산출 가능할까요?
    • 오토캐드 호그리기 질문
