홈/ 질문/Q 113153
등록일: 2021-06-152021-06-15T14:36:52+09:00 2021-06-15T14:36:52+09:00카테고리: AutoCAD & CADian
속성블럭의 속성을 export하는 리습인데 수정 부탁드립니다
(defun c:demo ( /  ss i vl_e ins_point valid_tag All_data filetowrite xlCells Excel_exist col row)
;; pBe May 2018
 (if
     (and
   (setq All_data nil
         ss (ssget “_X” ‘((0 . “INSERT”)(66 . 1)(410 . “Model”))))
   (repeat (setq i (sslength ss))
    (setq vl_e (vlax-ename->vla-object (ssname ss (Setq i (1- i)))))
    (setq ins_point (vlax-get vl_e ‘Insertionpoint))
    (if (setq valid_tag
        (Cdr (assoc “TYPE”
            (mapcar ‘(lambda (at)
         (list (vla-get-tagstring at) (vla-get-textstring at))
             (vlax-invoke vl_e ‘GetAttributes)
       (setq All_data (cons (list (vla-get-EffectiveName vl_e)
             (Car valid_tag) (rtos (car ins_point) 2) (rtos (cadr ins_point) 2) (rtos (caddr ins_point) 2)  (Cadr valid_tag)
             All_data))
     All_data
 (cond
    ( (null All_data)  )
  ( (setq Excel_exist (vlax-get-or-create-object “Excel.Application”))
    (setq col 1 row 1)
    (setq  xlCells  (vlax-get-property
                                     (vlax-get-property
                                       (vlax-get-property
                                         (vlax-invoke-method
                                           (vlax-get-property Excel_exist “Workbooks”)
                                             “Add”
                                         “Sheets”
                                       “Item” 1
                                     “Cells”
   ((lambda (n)
    (foreach val ‘(“Block Name” “Value” “X” “Y” “Z” “Level” )
      (vlax-put-property xlCells ‘Item row (setq n (1+ n)) val)
      0
    (vlax-put-property xlCells ‘ColumnWidth 15.00)
   (foreach itm (vl-sort All_data ‘(lambda (a b)(< (Car a)(car b))))
     (setq row (1+ row))
      ((lambda (n)
     (foreach val itm
       0
    (vla-put-visible Excel_exist :vlax-true)
   (mapcar (function (lambda (obj)
     (and obj (eq ‘VLA-OBJECT (type obj)) (not (vlax-object-released-p obj))
           (not
             (vl-catch-all-error-p
               (vl-catch-all-apply
                 (function vlax-release-object) (list obj)
   (list Excel_exist xlCells))
    (setq Excel_exist nil
         xlCells nil)
  ( (setq csvfile (getfiled “Enter CSV file name”
    (strcat (getvar ‘dwgprefix) (vl-filename-base (getvar ‘dwgname)))   “CSV” 1))
   (setq filetowrite (open csvfile “w”))
   (write-line (strcat (Car itm) “,” (Cadr itm)) filetowrite))
   (close filetowrite)
    (startapp “notepad”)
이건데 태그가 TYPE인 속성만 export가 되고 있는데 태그가 LEVEL인 속성도 함께 출력되도롭하고싶은데 수정하다가 막혔네요 ㅠㅠ
  • 27 조회
    • 새파일 및 다른이름으로 저장 누르면 스샷처럼 뜹니다
    • 오토캐드 치수선관련 질문 ㅠㅠㅠ..
    • 캐드 2021 객체가 외부참조임.
    • 캐드2007에서 다중지시선 메뉴가 없나요?
    2. 트리플렌지 Lv.0
      2021-06-15T15:21:31+09:00답변 등록 답변 등록 일시 2021-06-15 3:21 pm
      제가 전에 어디선가 얻은 리습인데, 저는 이걸로 씁니다.
      태그속성이니 LEVEL이니 하는 것들은 잘 몰라서 님이 원하는대로 될지는 모르겠어요.
      저는 아직까지는 이걸로 쓰면서 안되는 도면은 없었어요.
      (defun C:BTA ( / *error* doc blocks undo ss )  ;;속성 블록의 문자를 유지하면서 분해하기
       (vl-load-com)
       (defun *error* ( msg ) (and Undo (vla-EndUndoMark doc))
         (or (wcmatch (strcase msg) “*BREAK,*CANCEL*,*EXIT*”)
             (princ (strcat “n** Error: ” msg ” **”)))
       (princ “nSelect Block To Explode (Hold Text Attribut) : “)
       (setq doc    (vla-get-ActiveDocument (vlax-get-acad-object))
             blocks (vla-get-Blocks doc))
       (if (ssget “_:L” ‘((0 . “INSERT”)))
         (progn
           (setq Undo (not (vla-StartUndoMark doc)))
           (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
             (if (eq :vlax-true (vla-get-Explodable (Itemp blocks (BlockName obj))))
        (progn
                       ;(alert “Apply”)
                       (princ “”)
        );p end
        (progn
           ;(alert “Deny”)
                       (setq BlockN (BlockName obj) )
                       (BlkSetExplodability BlockN 1)
        );p end
             );if end
               (progn
                 (if (eq :vlax-true (vla-get-HasAttributes obj))
                   (foreach att (vlax-invoke obj ‘GetAttributes)
                     (if (eq :vlax-false (vla-get-Invisible att))
                         (if (eq :vlax-false (vla-get-MTextAttribute att))
                           Att2Text MAtt2MText
                         (entget (vlax-vla-object->ename att))
                 (foreach eobj (vlax-invoke obj ‘Explode)
                   (if (eq “AcDbAttributeDefinition” (vla-get-ObjectName eobj))
                     (vla-delete eobj)
                 (vla-delete obj)
           (vla-Delete ss)
           (setq Undo (vla-EndUndomark doc))
      (defun BlockName ( obj )
       (vlax-get-property obj
         (if (vlax-property-available-p obj ‘EffectiveName)
           ‘EffectiveName ‘Name
      (defun Itemp ( coll item )
       (if
         (not
             (setq item
               (vl-catch-all-apply
                 (function vla-item) (list coll item)
               )))) item ))
      (defun RemovePairs ( pairs lst )
       (vl-remove-if
         (function (lambda ( pair )(vl-position (car pair) pairs) )) lst ))
      (defun RemoveFirstPairs ( pairs lst )
       (defun foo ( pair lst )
         (if lst (if (eq pair (caar lst))
             (cdr lst)
             (cons (car lst) (foo pair (cdr lst))))))
       (foreach pair pairs (setq lst (foo pair lst)))  lst )
      (defun Att2Text ( eLst / dx74 )
       (setq dx74 (cdr (assoc 74 eLst)))
       (entmake
         (append ‘( (0 . “TEXT”) )
           (RemovePairs ‘(0 100 2 74 70 280)
             (subst
               (cons 73 dx74) (assoc 74 eLst) eLst
      (defun MAtt2MText ( eLst )
       (entmake
         (append ‘( (0 . “MTEXT”) (100 . “AcDbEntity”) (100 . “AcDbMText”) )
           (RemoveFirstPairs ‘(40 1 50 41 7 71 72 71 72 73 10 11 11 210)
             (RemovePairs ‘(-1 330 5 0 100 101 2 42 43 51 74 70 280) eLst)
    3. 트리플렌지 Lv.0
      2021-06-16T08:17:48+09:00답변 등록 답변 등록 일시 2021-06-16 8:17 am
      explode로 봤었는데, 다시 보니까 export네요.
      혼선을 드려 죄송합니다.^^
