홈/ 질문/Q 97191
등록일: 2013-01-282013-01-28T14:25:52+09:00 2013-01-28T14:25:52+09:00카테고리: AutoCAD & CADian
수정입니다
(defun cupartno (/ olderr ocmd oblp )
  (setq olderr  *error*
        *error* myerror)
  (setq ocmd (getvar “cmdecho”))
  (setq oblp (getvar “blipmode”))
  (setvar “cmdecho” 0)
  (setvar “blipmode” 0)
   (SETQ A (GETVAR “CLAYER”))
   (SETQ OSM (GETVAR “OSMODE”))
   (SETVAR “OSMODE” 0)
   (SETQ P1 (GETPOINT “nFirst point :”))
   (SETQ P2 (GETPOINT “nSecond point :” P1))
   (SETQ NUM (GETSTRING “nParts No. :”))
   (COMMAND “LAYER” “M” “3”  “”)
   (COMMAND “DIM” “STYLE” “ROMANS” “EXIT”)
   (SETQ D0 (GETVAR “DIMSCALE”))
   (SETQ D1 (* D0 12.0))
   (SETQ P3 (ANGLE P1 P2))
   (SETQ P5 (POLAR P2 (+ P3 PI) (/ D1 2.0)))
   (SETQ HI (* D0 5))
   (COMMAND “DONUT” 0 D0 P1 “”)
   (COMMAND “CIRCLE” P2 “D” D1)
   (COMMAND “LINE” P1 P5 “”)
   (COMMAND “LAYER” “M” “4” “”)
   (COMMAND “TEXT” “M” P2 HI “0” NUM)
   (COMMAND “LAYER” “S” A “”)
   (SETVAR “OSMODE” OSM)
  (setq *error* olderr)               ; Restore old *error* handler
(defun c:pn ()
       (cupartno)
(defun c:partno ()
       (cupartno)
도면  품번 넣은 리습인데요.
가르키는 끝점이랑 품번을 이어주는 선이랑 따로 분리가 되어있어서
하나의 객체로 하고 싶은데 고수님들 수정좀 부탁드립니다…
  • 14 조회
