홈/ 질문/Q 25306
등록일: 2008-04-192008-04-19T09:21:20+09:00 2008-04-19T09:21:20+09:00카테고리: AutoCAD & CADian
어떤 리습인지 가르쳐주세욤~~
1. 첫번재 리습
defun C:cf(/ ss sno cno no x)
(setvar “cmdecho” 1)
(princ ” = LinetypeChange”)
(setq ss (ssget))
(setq sno (sslength ss))
(setq cno (getstring “nLINETYPE : “))
(setq no 0)
(repeat sno
(setq x (ssname ss no))
(command “change” x “” “p” “LT” cno “”)
(setq no (1+ no))
)(prin1)
2. 두번째 리습
(defun rrbI:LayerFiltersDelete (strKeepWC / objXDict)
;; This function insures that an Extension Dictionary exists, and works on both locations for layer filters
(vl-load-com) ; load ActiveX if needed
(vl-catch-all-apply ; trap error if no extension dictionary
(function
(lambda ()
(setq objXDict (vla-GetExtensionDictionary ; bind dictionary to variable
(vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))))))
(cond (objXDict ; if the extension dictionary exists
(or ; use OR to return T for success
(rrbI:DeleteAllXRecs objXDict “ACAD_LAYERFILTERS” strKeepWC) ; pre-2005 layer filters
(rrbI:DeleteAllXRecs objXDict “AcLyDictionary” strKeepWC))))) ; 2005 layer filters
(defun rrbI:DeleteAllXRecs (objXDict dictName strKeepWC / objDict i)
;; This function performs the chore of deleting each filer that doesn”t match the wildcard
(vl-catch-all-apply ; trap errors
(function
(lambda ()
(setq objDict (vla-Item objXDict dictName)) ; get layer filters dictionary
(vlax-for objXRec objDict ; loop thru all XRecords in the dictionary
(cond ((not (and strKeepWC (wcmatch (vla-Get-Name objXRec) strKeepWC))) ; if deleting all filters, or current doesn”t match wildcard
(setq i (1+ (cond (i) ; increment counter
(0)))) ; initialize counter
(vla-Delete objXRec))))))) ; delete filter
(cond (i (princ (strcat “n” (itoa i) ” filters deleted.”))))) ; if counter is bound, report number of filters deleted
(defun C:LFD (/ inpKeep)
;; Main command-line function
(setq inpKeep (getstring
“nWildcard mask for filters to keep, or to delete all: “))
(rrbI:LayerFiltersDelete (cond ((/= inpKeep “”) inpKeep))) ; pass nil to subr if user hit
(princ)) ; clean exit
이상 두가지 입니다.
  • 29 조회
