홈/ 질문/Q 96666
등록일: 2012-11-182012-11-18T01:42:27+09:00 2012-11-18T01:42:27+09:00카테고리: AutoCAD & CADian
연결된 라인들 선택이 되는 리습 수정 도움 부탁 드립니다..
연결이 된 라인들을 선택해주는 리습입니다..
지금 이 리습은 선만 선택이 되는데요..
고수님들중에서 선하고 도형이 연결 된것도 같이 선택 해주실수 있게 수정 도움 부탁드립니다.. (”)(..)(”)
(defun c:lc( / sl-scr foo ss scr ens sel)
 (vl-load-com)
 (defun sl-scr ( / vwctr vwsz scsz)
  (setq vwctr (getvar “viewctr”) vwsz (getvar “viewsize”) scsz (getvar “screensize”))
  (list
   (list (- (car vwctr) (* (/ vwsz (cadr scsz)) (car scsz) 0.5)) (- (cadr vwctr) (/ vwsz 2.0)))
   (list (+ (car vwctr) (* (/ vwsz (cadr scsz)) (car scsz) 0.5)) (+ (cadr vwctr) (/ vwsz 2.0)))
 (defun foo (sel / temp sp ep p1 p2 tol dis1 ob)
  (setq sp (vlax-curve-getstartpoint sel) ep (vlax-curve-getendpoint sel))
  (setq ob (vlax-ename->vla-object sel) dis1 (distance sp ep) tol 0.1)
  (and
   (setq temp
    (vl-remove-if-not
     ‘(lambda (en)
      (setq p1 (vlax-curve-getstartpoint en) p2 (vlax-curve-getendpoint en))
      (setq dis2 (distance p1 p2))
      (and
       (not (ssmemb en ss))
       (or
        (vlax-invoke (vlax-ename->vla-object en) ‘intersectwith ob 0)
        (equal sp p1 tol) (equal sp p2 tol) (equal ep p1 tol) (equal ep p2 tol)
     ens
   (mapcar ‘(lambda (en) (ssadd en ss)) temp)
   (mapcar ‘foo temp)
 (sssetfirst)
 (setq ss (ssadd) acad (vlax-get-acad-object))
 (and
  (setq sel (ssget ‘((0 . “ARC,LINE”))))
  (progn
   (vla-ZoomExtents acad)
   (setq scr (sl-scr) ens (vl-remove-if ‘listp (mapcar ‘cadr (ssnamex (ssget “c” (car scr) (cadr scr) ‘((0 . “ARC,LINE”)))))))
   (vla-ZoomPrevious acad)
   ens
  (mapcar ‘foo (vl-remove-if ‘listp (mapcar ‘cadr (ssnamex sel))))
  (sssetfirst nil ss)
  • 38 조회
