홈/ 질문/Q 111454
등록일: 2019-06-232019-06-23T21:47:21+09:00 2019-06-23T21:47:21+09:00카테고리: AutoCAD & CADian
오프셋 리습
 선, 폴리선 등을 오프셋 후 끝 점을 결합하는 리습입니다.
옹벽 등을 표기할 때 오프셋 후에 양 끝 점에 선을 그려 결합하는 과정을 한번에 해 준다고 해서 사용하려합니다만. 실행이 되지 않습니다
확인 부탁드립니다.
(defun c:OC (/ AT:Offset ent pnt lst)
  ;; Offset selected curve and connect each end (also option to convert to LWPolyline).
  ;; Copyright Alan J. Thompson, 04.29.10
  ;; http://www.theswamp.org/
  (vl-load-com)
  (defun AT:Offset (O D P / _pt p1 p2 c D g)
    ;; Offset selected object
    ;; O – Object to offset
    ;; D – Distance to offset object
    ;; P – Point on side of object to offset
    ;; Alan J. Thompson, 09.12.09 / 03.25.10
    (setq _pt (lambda (s)
                (vlax-curve-getPointAtDist O (s (vlax-curve-getDistAtPoint O p1) 0.00001))
    (if (and (setq p1 (vlax-curve-getclosestpointtoprojection O (trans P 1 0) ‘(0 0 1)))
             (or (setq p2 (setq c (_pt +))) (setq p2 (_pt -)))
             (if (minusp (- (* (- (car p2) (car p1)) (- (cadr (trans P 1 0)) (cadr p1)))
                            (* (- (cadr p2) (cadr p1)) (- (car (trans P 1 0)) (car p1)))
               (if (vl-position (vla-get-objectname O) ‘(“AcDbLine” “AcDbXline”))
                 (setq D (- (abs D)))
                 (setq D (abs D))
                 (setq D (abs D))
             (or c (setq D (- D)))
             (not (vl-catch-all-error-p (setq g (vl-catch-all-apply ‘vla-offset (list O D)))))
      (car (vlax-safearray->list (vlax-variant-value g)))
  (and (minusp (getvar ‘offsetdist)) (setvar ‘offsetdist 1.))
  (cond
    ((and
       (if AT:Entsel
         (setq ent (car (AT:Entsel nil “n선, 폴리선, 호 선택: ” ‘(“L” (0 . “ARC,LINE,LWPOLYLINE”)) nil)))
         (and (setq ent (car (entsel “n선, 폴리선, 호 선택: “)))
              (or (vl-position (cdr (assoc 0 (entget ent))) ‘(“ARC” “LINE” “LWPOLYLINE”))
                  (alert “지원하지 않는 객체!”)
       (not (initget 6))
       (setvar
         ‘offsetdist
         (cond
           ((getdist (strcat “nOffset 거리 지정 또는 <” (rtos (getvar ‘offsetdist)) “>: “)))
           ((getvar ‘offsetdist))
       (setq pnt (getpoint “nOffset 방향 지정: “))
       ((lambda (off)
  • 51 조회
