리습을 제가 원하는 방식으로 변경해보고 싶은데 봐도봐도 모르겠어요
리습내용은 이러합니다.
;;——————–=={ Text Count }==———————-;;
;; Counts the number of occurrences of each string in a ;;
;; selection and produces a report in an ACAD Table object ;;
;; Author: Lee Mac, Copyright ?2011 – http://www.lee-mac.com ;;
;; Version 1.0 – 07.11.2010 ;;
;; First Release. ;;
;; Version 1.1 – 05.08.2011 ;;
;; Added Dimensions Override Text & MLeaders ;;
;; Updated ‘AddTable’ to account for Annotative Text Styles. ;;
(defun c:tct
*error*
_StartUndo
_EndUndo
_Assoc++
_SumAttributes
_GetTextString
_ApplyFooToSelSet
acdoc
acspc
alist
data
pt
(vl-load-com)
(defun *error* ( msg )
(if acdoc (_EndUndo acdoc))
(if (not (wcmatch (strcase msg) “*BREAK,*CANCEL*,*EXIT*”))
(princ (strcat “n** Error: ” msg ” **”))
(defun _StartUndo ( doc ) (_EndUndo doc)
(vla-StartUndoMark doc)
(defun _EndUndo ( doc )
(if (= 8 (logand 8 (getvar ‘UNDOCTL)))
(vla-EndUndoMark doc)
(defun _Assoc++ ( key alist )
(lambda ( pair )
(if pair
(subst (list key (1+ (cadr pair))) pair alist)
(cons (list key 1) alist)
(assoc key alist)
(defun _SumAttributes ( entity alist )
(while
(not
(eq “SEQEND”
(cdr
(assoc 0
(entget
(setq entity (entnext entity))
(setq alist (_Assoc++ (_GetTextString entity) alist))
(defun _GetTextString ( entity )
(lambda ( string )
(mapcar
(function
(lambda ( pair )
(if (member (car pair) ‘(1 3))
(setq string (strcat string (cdr pair)))
(entget entity)
string
(defun _ApplyFooToSelSet ( foo ss / i )
(if ss (repeat (setq i (sslength ss)) (foo (ssname ss (setq i (1- i))))))
(setq acdoc (vla-get-activedocument (vlax-get-acad-object))
acspc (vlax-get-property acdoc (if (= 1 (getvar ‘CVPORT)) ‘Paperspace ‘Modelspace))
(cond
( (= 4 (logand 4 (cdr (assoc 70 (tblsearch “LAYER” (getvar ‘CLAYER))))))
(princ “nCurrent Layer Locked.”)
( (not (vlax-method-applicable-p acspc ‘AddTable))
(princ “nTable Object not Available in this version.”)
( (and
(setq data
(_ApplyFooToSelSet
(lambda ( entity / typ )
(setq alist
(cond
( (eq “INSERT” (setq typ (cdr (assoc 0 (entget entity)))))
(_SumAttributes entity alist)
( (eq “MULTILEADER” typ)
(_Assoc++ (cdr (assoc 304 (entget entity))) alist)
( (wcmatch typ “*DIMENSION”)
(_Assoc++ (cdr (assoc 1 (entget entity))) alist)
( (_Assoc++ (_GetTextString entity) alist) )
(ssget
(-4 . “<OR”)
(0 . “TEXT,MTEXT,MULTILEADER”)
(-4 . “<AND”)
(0 . “INSERT”)
(66 . 1)
(-4 . “AND>”)
(-4 . “<AND”)
(0 . “*DIMENSION”)
(1 . “*?*”)
(-4 . “AND>”)
(-4 . “OR>”)
(setq pt (getpoint “nSpecify Point for Table: “))
(_StartUndo acdoc)
(LM:AddTable acspc (trans pt 1 0) “String Count”
(cons (list “String” “Instances”)
(vl-sort
(mapcar
(function
(lambda ( x ) (list (car x) (itoa (cadr x))))
data
(function (lambda ( a b ) (< (car a) (car b))))
(_EndUndo acdoc)
;;———————=={ Add Table }==———————-;;
;; Creates a VLA Table Object at the specified point, ;;
;; populated with title and data ;;
;; Arguments: ;;
;; space – VLA Block Object ;;
;; pt – Insertion Point for Table ;;
;; title – Table title ;;
;; data – List of data to populate the table ;;
;; Returns: VLA Table Object ;;
(defun LM:AddTable ( space pt title data / _isAnnotative textheight style )
(defun _isAnnotative ( style / object annotx )
(and
(setq object (tblobjname “STYLE” style))
(setq annotx (cadr (assoc -3 (entget object ‘(“AcadAnnotative”)))))
(= 1 (cdr (assoc 1070 (reverse annotx))))
(lambda ( table ) (vla-put-StyleName table (getvar ‘CTABLESTYLE)) (vla-SetText table 0 0 title)
(lambda ( row )
(mapcar
(function
(lambda ( rowitem ) (setq row (1+ row))
(lambda ( column )
(mapcar
(function
(lambda ( item )
(vla-SetText table row (setq column (1+ column)) item)
rowitem
-1
data
0
table
(lambda ( textheight )
(vla-AddTable space (vlax-3D-point pt) (1+ (length data)) (length (car data)) textheight
(* 0.8 textheight
(apply ‘max
(cons (/ (strlen title) (length (car data)))
(mapcar ‘strlen (apply ‘append data))
(* 2.
(setq textheight
(vla-gettextheight
(setq style
(vla-item
(vla-item
(vla-get-dictionaries (vla-get-document space)) “ACAD_TABLESTYLE”
acdatarow
(if (_isAnnotative (vla-gettextstyle style acdatarow))
(cond ( (getvar ‘CANNOSCALEVALUE) ) ( 1.0 ))
1.0
;; End of File ;;
알겠습니다 좋은답변감사합니다
