홈/ 질문/Q 98004
등록일: 2013-04-202013-04-20T21:57:03+09:00 2013-04-20T21:57:03+09:00카테고리: AutoCAD & CADian
좌표리습 글씨크기를 직접조절할수 있도록 수정부탁드립니다.
; BLOCK ANNOTATION PROGRAM
(defun C:x()
        (setvar “cmdecho” 0)
        (setvar “osmode” 1)
        (setq pt1 (getpoint “nPick xy Point: “))
        (setvar “osmode” 0)
        (setq pt2 (getpoint “nPick 1st flag point: “))
        (command “line” pt1 pt2 “”)
        (setq pt3 (getpoint “nPick left or right point: “))
        (setq x1 (car pt1))
        (setq y1 (cadr pt1))
        (setq ax (rtos x1 2 4))
        (setq ay (rtos y1 2 4))
        (setq x2 (car pt2))
        (setq y2 (cadr pt2))
        (setq x3 (car pt3))
        (setq y3 (cadr pt3))
        (if (< x3 x2) (setq x4 (- x2 15)))
        (if (> x3 x2) (setq x4 (+ x2 15)))
        (setq y4 y2)
        (setq pt4 ( list x4 y4 ))
        (command “line” pt2 pt4 “”)
        (setq x1 (/ (+ x2 x4) 2))
        (setq y1 (+ y2 0.5))
        (setq pt1 (list x1 y1))
        (command “text” “c” pt1 1.2 0 ay)
        (setq y1 (- y2 2.0))
        (command “text” “c” pt1 1.2 0 ax)
;block calculation
(defun C:b()
        (setvar “osmode” 1)
        (setq pi 3.1415926)
        (setq p1 (getpoint “nPick Left Point:  “))
        (setq p2 (getpoint “nPick Right Point: “))
        (setvar “osmode” 0)
        (setq rot (angle p1 p2))
        (setq ang (angtos rot 1 0))
        (setq l1 (strlen ang))
        (setq dd (substr ang 1 (- l1 1)))
        (setq ang (angtos rot 1 2))
        (setq l2 (strlen ang))
        (setq mm (substr ang (+ l1 1) (- l2 l1 1)))
        (if (= 1 (strlen mm)) (setq mm (strcat “0” mm)))
        (setq ang (angtos rot 1 4))
        (setq l3 (strlen ang))
        (setq ss (substr ang (+ l2 1) (- l3 l2 1)))
        (if (= 1 (strlen ss)) (setq ss (strcat “0” ss)))
        (setq br (strcat dd “-” mm “-” ss))
        (setq rot (+ rot (/ pi 2)))
        (if (> rot (* pi 2)) (setq rot (- rot (* pi 2))))
        (if (> rot pi) (setq rot (- rot pi)))
        (setq b1 (getpoint “nPick Bearing Location: “))
        (command “text” b1 ts ang br)
(defun c:ts()
        (setq ts (getreal “nEnter Text Size: “))
(defun C:d()
        (setvar “osmode” 1)
        (setq pi 3.1415926)
        (setvar “osmode” 0)
        (setq b2 (getpoint “nPick Distance Location: “))
        (setq dis (rtos (distance p1 p2) 2 3))
        (command “text” b2 ts ang dis)
  • 79 조회
