홈/ 질문/Q 112308
초오오보
초오오보Lv.0
등록일: 2020-05-052020-05-05T16:54:33+09:00 2020-05-05T16:54:33+09:00카테고리: AutoCAD & CADian
중복된블럭 삭제하기
블록 수량세다가 블록이 겹쳐져 있어 수량이 중복계산 됩니다
겹친블록 하나는 삭제하고 싶은데 리습이 없네요
Overkill 은 라인만되고 블럭은 안되네요
  • 238 조회
    2. 일탈은떵꿈 Lv.0
      2020-05-05T18:50:54+09:00답변 등록 답변 등록 일시 2020-05-05 6:50 pm
      http://www.lee-mac.com/dynamicblockcounter.html
      블럭이름이 바뀐것이 있나 먼저 확인해 보세요
      저도 개고생 한기억이 ㅠㅠ
    3. 초오오보 Lv.0
      2020-05-06T09:03:19+09:00답변 등록 답변 등록 일시 2020-05-06 9:03 am
      네 중첩되어 있는 블록이 삭제가 안됩니다
      다른건 되는데…
    4. ♡GISKOREA♡ Lv.1
      2020-05-08T17:34:08+09:00답변 등록 답변 등록 일시 2020-05-08 5:34 pm
      ;;;;;               중복심볼 삭제하기                         ;;;;;;;;
      (defun c:XXB( / ss ssdup ct len e eb
                             pt lay bname ang sclx scly sclz obj obj_list)
         (princ “nSelect block objects.”)            ;Select objects and filter all but block insert objects.
         (setq ss (ssget (list (cons 0 “INSERT”))))
         (if ss                                       ;If any valid objects were selected.
         (progn
            (princ “nBuilding list of objects.”)
            (setq ssdup (ssadd))                      ;Initialize new selection set to hold objects to delete
            (setq len (sslength ss))                  ;Find out how many objects were selected.
            (setq ct 0)
            (while (< ct len)                         ;Loop through selected objects
               (setq e (ssname ss ct))                ;Get an object name
               (setq eb (entget e))                   ;Get the entity list from the object name
               (setq ct (+ ct 1))                     ;Increment index into selection set
               (setq pt (cdr (assoc 10 eb)))          ;Access object’s coordinate
               (setq lay (cdr (assoc 8 eb)))          ;Access object’s layer
               (setq bname (cdr (assoc 2 eb)))        ;Access object’s block name
               (setq ang (cdr (assoc 50 eb)))         ;Access object’s rotation angle
               (setq sclx (cdr (assoc 41 eb)))        ;Access object’s x scale
               (setq scly (cdr (assoc 42 eb)))        ;Access object’s y scale
               (setq sclz (cdr (assoc 43 eb)))        ;Access object’s z scale
                                                      ;Make list of object properties
               (setq obj (list pt lay bname ang sclx scly sclz))
               (if (not (member obj obj_list))        ;If these properties are not already in list
                  (setq obj_list (cons obj obj_list)) ;Add them to the list
                  (ssadd e ssdup)                     ;Else add object to selection set to delete
               )                                      ;End if
            )                                         ;End of while loop
            (if (> (sslength ssdup) 0)                ;If there are any objects in the selection set to delete
            (progn
               (princ “nDeleting duplicate objects.”)
               (setq len (sslength ssdup))            ;Find out how many many objects to delete.
               (setq ct 0)
               (while (< ct len)                      ;Loop through objects and delete.
                  (setq e (ssname ssdup ct))          ;Get object name
                  (entdel e)                          ;Delete duplicate object
               (princ                                 ;Print the number of objects deleted to command line
                  (strcat “nDeleted ”
                          (itoa len)
                          ” duplicate objects.”
            )                                         ;End progn
               (princ “nNo duplicates found.”)       ;Else no there were no duplicates to delete.
            )                                         ;End if
         )                                            ;End progn
            (princ “nNo block objects selected.”)    ;Else there were no valid objects selected
         )                                            ;End if
      ;;;;;               중복문자 삭제하기                         ;;;;;;;;
      (defun c:XXT( / ss ssdup ct len e eb
                             pt lay ang sty hgt str obj obj_list)
         (princ “nSelect text objects.”)             ;Select objects and filter all but block insert objects.
         (setq ss (ssget (list (cons 0 “TEXT”))))
         (progn
            (setq ct 0)
               (setq sty (cdr (assoc 7 eb)))          ;Access object’s text style
               (setq hgt (cdr (assoc 40 eb)))         ;Access object’s text height
               (setq str (cdr (assoc 1 eb)))          ;Access object’s text string
               (setq obj (list pt lay ang sty hgt str))
               )                                      ;End if
            (progn
               (setq ct 0)
                  (strcat “nDeleted ”
                          (itoa len)
            )                                         ;End progn
            )                                         ;End if
         )                                            ;End progn
            (princ “nNo text objects selected.”)     ;Else there were no valid objects selected
         )                                            ;End if
      ;;;;;               중복포인트 삭제하기                       ;;;;;;;;
      (defun c:XXP( / ss ssdup ct len e eb
                            pt lay obj obj_list)
         (princ “nSelect point objects.”)             ;Select objects and filter all but valid objects.
         (setq ss (ssget (list (cons 0 “POINT”))))
         (progn
            (setq ct 0)
               (setq obj (list pt lay))
               )                                      ;End if
            (progn
               (setq ct 0)
                  (strcat “nDeleted ”
                          (itoa len)
            )                                         ;End progn
            )                                         ;End if
         )                                            ;End progn
            (princ “nNo point objects selected.”)    ;Else there were no valid objects selected
         )                                            ;End if
