홈/ 질문/Q 92316
등록일: 2011-07-142011-07-14T18:27:15+09:00 2011-07-14T18:27:15+09:00카테고리: AutoCAD & CADian
중심선 리습 수정좀 부탁드려요
dline 라는 중심선 리습을 사용중인데요
폴리는 되는데 호 나 스플라인으로 된 선들 중심이 안잡히는데
잡히게 할수있나요
;;;      center-line program Ver 0.1
;;;      Auto – Lisp Programming by Hong, Goo
;;;      2000,8,15
;; ############## subroutine ############################
;; dtr
;; rtd
;; dxf
;; vtxs12
;; vtxs14
;; pl_length
;; nearpt
;; polyline
;; orthopt
;; ##############  contents  ############################
;; draw center line ———————>   dline
;; make road               ————–>   road
(defun dtr (a)
    (* pi (/ a 180.0)))
(defun rtd (a)
    (/ (* a 180.0) pi))
(defun dxf(code elist)
  (cdr (assoc code elist)))
(defun vtxs12(ent / ptlist)
   (setq ent (entnext ent))
   (while (= “VERTEX” (cdr (assoc  0 (entget ent))))
      (setq ptlist (cons  (cdr (assoc 10 (entget  ent))) ptlist)
            ent    (entnext ent)
      );if
   );while
   ptlist
(defun vtxs14(ent / ptlist s1 count)
   (setq count 0)
   (repeat (length ent)
      (setq s1 (nth count ent))
      (if (= 10 (car s1))
        (setq ptlist (cons (cdr s1) ptlist)))
      (setq count (1+ count))
   ptlist
(defun pl_length(ent / count pt1 pt2 ll)
    (setq count 0 ll 0.0)
    (repeat (1- (length ent))
 (setq pt1 (nth count ent))
 (setq pt2 (nth (1+ count) ent))
 (setq ll (+ ll (distance pt1 pt2)))
    ll
(defun nearpt(pt1 ent / count pt2 l_short l_long mx my)
    (setq count 0 l_short 32000.0)
 (setq l_long (distance pt1 (nth count ent)))
 (if (> l_short l_long)
     (progn
  (setq l_short l_long)
  (setq pt2 (nth count ent))
    (princ “n Original Road # : “)
    (princ pt1)(terpri)
    (princ “n Center Road   # : “)
    (princ pt2)(terpri)
    (setq mx (/ (+ (car pt1) (car pt2)) 2))
    (setq my (/ (+ (cadr pt1) (cadr pt2)) 2))
    (setq pt2 (list mx my 0.0))
    pt2
(defun polyline(ent / osm pt n)
    (setq osm (getvar “osmode”))
    (setvar “osmode” 0)
    (setvar “cmdecho” 0)
    (setq n 0)
    (command “pline”)
    (while (nth n ent)
 (setq pt (nth n ent))
 (command pt)
 (setq n (1+ n))
    (command)
    (setvar “cmdecho” 1)
    (setvar “osmode” osm)
(defun orthopt(pt1 pt2 / osm len rads opt1 opt2 pt_list)
    (setvar “osmode” 0)
    (setq pt_list ())
    (setq len (distance pt1 pt2))
    (setq rads (angle pt1 pt2))
    (setq opt1 (polar pt1 (+ rads 1.59) len))
    (setq opt2 (polar pt1 (- rads 1.59) len))
    (setq pt_list (cons opt1 pt_list))
    (setq pt_list (cons opt2 pt_list))
    pt_list
(defun c:dline( / fob sob fo_list so_list fob_lst sob_lst pt_lst ll sob_new_list)
    (setq fob (entsel “n first pline : “))
    (if fob (command “chprop” fob “” “c” “yellow” “”))
    (setq sob (entsel “n second pline : “))
    (if sob (command “chprop” sob “” “c” “yellow” “”))
    (setq fo_list (entget (car fob)))
    (setq so_list (entget (car sob)))
    (setq sl (dxf 8 fo_list))
    (command “-layer” “s” sl “”)
    (if (= “LWPOLYLINE” (dxf 0 fo_list))
 (setq fob_lst (vtxs14 fo_list))
 (setq fob_lst (vtxs12 (dxf -1 fo_list)))
    (if (= “LWPOLYLINE” (dxf 0 so_list))
 (setq sob_lst (vtxs14 so_list))
 (setq sob_lst (vtxs12 (dxf -1 so_list)))
    (setq fob_ll (pl_length fob_lst))
    (princ “n First Length  : “)
    (princ fob_ll)(terpri)
    (setq sob_ll (pl_length sob_lst))
    (princ “n Second Length : “)
    (princ sob_ll)(terpri)
    (if (> (length sob_lst) (length fob_lst))
 (progn
     (setq pt_lst fob_lst)
     (setq fob_lst sob_lst)
     (setq sob_lst pt_lst)
    (setq count 0)
    (setq sob_new_list ())
    (repeat (length fob_lst)
 (setq pt1 (nth count fob_lst))
 (setq pt_new (nearpt pt1 sob_lst))
 (setq sob_new_list (cons pt_new sob_new_list))
    (polyline sob_new_list)
    (setq sob_new_list nil)
(command “layer” “s” 0 “”)
(defun c:road(/ val fob sob fo_list fob_lst pt1 pt2 pt_list)
    (setvar “osmode” 0)
    (setq val (getreal “n Road Width : “))
    (setq fob (entsel “n Select polyline to double: “))
    (setq pt1 (nth 0 fob_lst))
    (setq pt2 (nth 1 fob_lst))
    (setq pt_list (orthopt pt1 pt2))
    (setq pt1 (nth 0 pt_list))
    (setq pt2 (nth 1 pt_list))
    (command “offset” (/ val 2.0) (car fob) pt1 “”)
    (command “offset” (/ val 2.0) (car fob) pt2 “”)
    (command “erase” (car fob) “”)
  • 59 조회
