홈/ 질문/Q 106520
등록일: 2016-04-282016-04-28T10:54:19+09:00 2016-04-28T10:54:19+09:00카테고리: AutoCAD & CADian
치수기입 리습입니다. 오류가 있는데 어디가 문제인지…
(defun c:DD()
(defun rtd (a) (/ (* a 180.0) pi)) ;radian to degree
;->*error* start
 (defun *error* (msg)
   ;;;추가
   (if DimOriginPoint
     (progn
       (setvar “osmode” 0)
       (command “ucs” “n” (list (* (car DimOriginPoint) -1.0) (* (cadr DimOriginPoint) -1.0) 0.0))
   );;;if
   ;;;추가
 (princ “error: “)(princ msg)
 (setvar “osmode” os)(setvar “dimtad” dt)
 (setvar “orthomode” ot) (setvar “cecolor” cl)
 (princ))
;-<*error* end
   (setq os (getvar “osmode”) ot (getvar “orthomode”) )
   (setq dt (getvar “dimtad”)) (setq ditx (getvar “dimtxt”))
   (setq cl (getvar “cecolor”))
   (setvar “clayer” “0”) (setvar “cecolor” “Bylayer”)
   (setvar “DIMtad” 1) (setvar “DIMTVP” 0);dimtad를 0으로 하면 소수점 두 자리는 안나온다
   (setvar “osmode” 1063) (setvar “orthomode” 1)
   (setvar “cmdecho” 0)
  ;;;추가
  (setq DimOriginPoint nil)
  (setq DimOriginPoint (getpoint “n 원점을 선택하세요 < 원점 선택을 다시 안 할 때는 Enter > : “))
  (if DimOriginPoint
    (progn
      (setq DimOriginBackupPoint (trans DimOriginPoint 1 0))
      (command “ucs” “n” DimOriginPoint)
    (if DimOriginBackupPoint
      (progn
 (setq DimOriginPoint (trans DimOriginBackupPoint 0 1))
    );;;if
  );;;if
  ;;;추가
   (setq daso (getvar “dimaso”)) (setq dsca (getvar “dimscale”))
   (if (= btdis1 nil)(setq btdis1 0.8))
   (setq btdis (* btdis1 dsca))
   (setq ditx (* ditx dsca)) (setq ditx (+ ditx btdis))
   (setq ppa2 nil)
   (setq rp 0)
   (setq p1 (getpoint “n 방향을 지정하세요 : “))(terpri)
   (setq p2 (getpoint p1 “n Leader endpoint<XYdatum>: “))(terpri)
   (setq ag (rtd (angle p1 p2)) ag (rtos ag 2 0))
   (cond
     ( (or (= ag “0”) (= ag “180”))
         (setq rp (+ 1 rp)) (@dim_Odinatey) )
     ( (or (= ag “90”) (= ag “270”))
         (setq rp (+ 1 rp)) (@dim_Odinatex) )
   ;;;추가
   (if DimOriginPoint
     (progn
       (setvar “osmode” 0)
   );;;if
   ;;;추가
   (setvar “dimtad” dt) (setvar “cecolor” cl)
   (setvar “osmode” os) (setvar “orthomode” ot)
(command “dimdli” “7”)
(command “ucs” “w”)
(princ))
;sub routine-1
(defun @dim_Odinatey() (while rp
   (if (= p1 nil) (progn
       (setq ppa2 nil)(setq rp 0)
       (princ “Again…”)(terpri)
       (princ “n Dim:Odinate-Y”)(terpri)
       (setq p1 (getpoint “n Select Feature: “))(terpri)
   (setq ppa1 (cadr p1))
   (if (= rp 0) (setq p2 (getpoint p1 “n Leader endpoint<Ydatum>: “)) ) (terpri)
   (if (= p2 nil)(error))
   (if (= ppa2 nil)
       (setq p2 (list (car p2) (cadr p2)))
       (progn
          (setq ppa (abs (- ppa1 ppa2)) ddss (abs (- yy ppa1)))
          (setq dds (- ditx ppa) dds1 (+ ditx ppa))
          (if (< ditx ppa) (progn
              (setq p2 (list (car p2) (cadr p1)))
              (if (and (> yy ppa1) (< ppa2 ppa1)) (setq p2 (list (car p2) (- (cadr p1) dds1) )) )
              (if (and (< yy ppa1) (> ppa2 ppa1)) (setq p2 (list (car p2) (+ (cadr p1) dds1) )) )
          (if (> ditx ppa) (progn
              (if (and (> yy ppa1) (< ppa1 ppa2))
                  (setq p2 (list (car p2) (- (cadr p1) dds) )) )
              (if (and (> yy ppa1) (> ppa1 ppa2))
              (if (and (< yy ppa1) (> ppa1 ppa2))
                  (setq p2 (list (car p2) (+ (cadr p1) dds) )) )
              (if (and (< yy ppa1) (< ppa1 ppa2))
   (setvar “osmode” 0) (setvar “dimtad” 0)
   (command “dim1” “ord” p1 “y” p2 “”)
   (setvar “osmode” 1061)
   (setq yy (cadr p1))
   (setq ppa2 (cadr p2))
   (setq rp (+ 1 rp))
   (setq p1 (getpoint “n Select Feature (X): “))(terpri)
;sub routine-2
(defun @dim_Odinatex() (while rp
       (princ “n Dim:Odinate-X”)(terpri)
   (setq ppa1 (car p1))
   (if (= rp 0) (setq p2 (getpoint p1 “n Leader endpoint<Xdatum>: “)) ) (terpri)
   (if (= ppa2 nil)
       (progn
          (setq ppa (abs (- ppa1 ppa2)) ddss (abs (- xx ppa1)))
              (setq p2 (list (car p1) (cadr p2)))
              (if (and (> xx ppa1) (< ppa2 ppa1)) (setq p2 (list (- (car p1) dds1) (cadr p2))) )
              (if (and (< xx ppa1) (> ppa2 ppa1)) (setq p2 (list (+ (car p1) dds1) (cadr p2))) )
              (if (and (> xx ppa1) (< ppa1 ppa2))
                  (setq p2 (list (- (car p1) dds) (cadr p2))) )
              (if (and (> xx ppa1) (> ppa1 ppa2))
              (if (and (< xx ppa1) (> ppa1 ppa2))
                  (setq p2 (list (+ (car p1) dds) (cadr p2))) )
              (if (and (< xx ppa1) (< ppa1 ppa2))
   (command “dim1” “ord” p1 “x” p2 “”)
   (setq xx (car p1))
   (setq ppa2 (car p2))
   (setq rp (+ 1 rp))
   (setq p1 (getpoint “n Select Feature (Y): “))(terpri)
치수기입 리습인데 이게 사용하면 온스냅이 전부 해제됩니다.
어디가 문제인지 수정 좀 부탁 드립니다.
  • 48 조회
