홈/ 질문/Q 106654
등록일: 2016-05-252016-05-25T11:44:25+09:00 2016-05-25T11:44:25+09:00카테고리: AutoCAD & CADian
캐드 볼트 탭 작도 리습질문 입니다~ 고수님들 도와주세요
아래 리습에서 탭 측면 작도시 문자가 나왔으면 합니다.
예를 들어 M8탭 길이 15.0 을 작도 한다고 하면
볼트에  M8X15L 이렇게 나오게 하고 싶습니다.
고수님들의 도움 부탁드립니다.
그리고 측면 탭 작도시 중심선이 삐져 나오는데 바깥으로 안나오게도 알려주시면
감사하겠습니다. 좋은하루 보내세요
;;;             2D TAP(평면,관통,막힘) 을 작도한다
;;;             2010,4,8, 김규환(gw1425@hanmail.net)
;;;             http://cafe.daum.net/archimore/by 쇠쟁이
(setq tap_draw_layer_1 “0”
;;;외형선
      tap_draw_layer_2
         “3”
;;;실선
      tap_draw_layer_3
         “2”
;;;은선
      tap_draw_layer_4
         “1”
;;;중심선
(defun c:BH (/ old_bl old_cm old_lay ok ok1)
  (setq old_bl (getvar “BLIPMODE”)
 old_cm (getvar “cmdecho”)
 old_lay (getvar “clayer”)
  (defun *error* (msg)
    (SETVAR “BLIPMODE” old_bl)
    (SETVAR “cmdecho” old_cm)
    (setvar “clayer” old_lay)
  (SETVAR “BLIPMODE” 0)
  (SETVAR “cmdecho” 0)
  (tap_draw_dcl)
  (if (or (= ok 1) (= ok1 1))
    (progn
      (cond
 ((= tap_draw_dia 2.5) (setq tap_draw_p 0.45)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 2) 2 2)))
 ((= tap_draw_dia 3) (setq tap_draw_p 0.6)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 2) 2 2)))
 ((= tap_draw_dia 4) (setq tap_draw_p 0.75)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 2) 2 2)))
 ((= tap_draw_dia 5) (setq tap_draw_p 0.8)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 3) 2 2)))
 ((= tap_draw_dia 6) (setq tap_draw_p 1)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 3) 2 2)))
 ((= tap_draw_dia 8) (setq tap_draw_p 1.25)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 3) 2 2)))
 ((= tap_draw_dia 10) (setq tap_draw_p 1.5)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 5) 2 2)))
 ((= tap_draw_dia 12) (setq tap_draw_p 1.75)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 5) 2 2)))
 ((= tap_draw_dia 14) (setq tap_draw_p 2)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 5) 2 2)))
 ((= tap_draw_dia 16) (setq tap_draw_p 2)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 7) 2 2)))
 ((= tap_draw_dia 18) (setq tap_draw_p 2.5)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 7) 2 2)))
 ((= tap_draw_dia 20) (setq tap_draw_p 2.5)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 7) 2 2)))
 ((= tap_draw_dia 22) (setq tap_draw_p 2.5)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 10) 2 2)))
 ((= tap_draw_dia 24) (setq tap_draw_p 3)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 10) 2 2)))
 ((= tap_draw_dia 30) (setq tap_draw_p 3.5)(setq tap_draw_type_2 (rtos  (+ (atof tap_draw_type_4) 10) 2 2)))
      (tap_draw_layer_1_make)
      (tap_draw_layer_2_make)
      (tap_draw_layer_3_make)
      (tap_draw_layer_4_make)
      (cond
 ((= tap_draw_type_1 “0”) (tap_draw_top))
 ((= tap_draw_type_1 “1”) (tap_draw_through))
 ((= tap_draw_type_1 “2”) (tap_draw_blind))
  (PRINC)
;;; 은선/중심선의 레이어 축척을 설정
(defun dxf_48_setting (dxf_48 /)
  (if (> dxf_48 1)
    (setq dxf_48 1)
  dxf_48
;;;                블럭 체인지
(defun block_change (block_change_ss    block_change_name
       /      block_change_ss
       block_change_name    block_change_p
  (setq block_change_p 0)
  (while (ssname block_change_ss block_change_p)
    (setq block_change_1 (subst
      (cons 2 block_change_name)
      (assoc
        2
        (entget (ssname block_change_ss block_change_p)
      (entget (ssname block_change_ss block_change_p))
   block_change_p (+ block_change_p 1)
    (entmod block_change_1)
(defun tap_draw_top (/ pt ss)
  (defun tap_draw_top_1 (draw_pt / draw_pt)
    (if (= tap_draw_type_7 “1”)
      (progn
 (if (< (/ tap_draw_dia 5.0) 1)
   (entmake(list ‘(0 . “CIRCLE”)
(cons 8 tap_draw_layer_3)
(CONS 48 (dxf_48_setting (/ tap_draw_dia 5.0)))
(cons 10 draw_pt)
(cons 40 (/ (- tap_draw_dia tap_draw_p) 2.0))))
   (entmake (list ‘(0 . “CIRCLE”)
 (cons 10 draw_pt)
 (cons 40 (/ (- tap_draw_dia tap_draw_p) 2.0))))))
      (progn
      (cons 8 tap_draw_layer_1)
      (cons 10 draw_pt)
    (COND ((= tap_draw_type_7 “1”)
  (entmake (list (cons 0 “ARC”)
 (cons 10 draw_pt)
 (cons 40 (/ tap_draw_dia 2.0))
 (Cons 50 (* pi 1.45))
 (cons 51 (* pi 1.05))
 ((/= tap_draw_type_7 “1”)
 (cons 8 tap_draw_layer_2)
 (cons 10 draw_pt)
    (if (= tap_draw_type_8 “1”)
      (progn
 (entmake
   (LIST
     (CONS 0 “LINE”)
     (CONS 8 tap_draw_layer_4)
     ;(CONS 48 (dxf_48_setting (/ tap_draw_dia 50.0)))
     (CONS 10
    (polar draw_pt pi (+ (/ tap_draw_dia 2.0) 0))
     (CONS 11
    (polar draw_pt 0 (+ (/ tap_draw_dia 2.0) 0))
 (entmake
   (LIST (CONS 0 “LINE”)
  (CONS 10
        (polar draw_pt
        (* pi 1.5)
  (CONS 11
        (polar draw_pt
        (* pi 0.5)
  (if (= tap_draw_type_5 “0”)
    (progn
      (while (/= (setq pt (getpoint “n삽입점:”)) nil)
 (tap_draw_top_1 (trans pt 1 0))
    (progn
      (setq block_name (STRCAT “M” (RTOS tap_draw_dia) ” TAP”))
 (setq block_name (strcat block_name “(H)”))
      (if
 (= (tblsearch “block” block_name)
    nil
  (progn
    (entmake
      (list ‘(0 . “BLOCK”)
     (cons 2 block_name)
     ‘(70 . 0)
     ‘(10 0.0 0.0 0.0)
    (tap_draw_top_1 (list 0 0 0))
    (entmake ‘((0 . “ENDBLK”)))
      (if (= tap_draw_type_6 “0”)
 (progn
   (prompt “n삽입점/취소=Esc/:”)
   (while (/= (vl-cmdf “_insert” block_name pause “” “” 0)
       nil
 (progn
   (prompt “n교체할 부분 선택:”)
   (setq ss (ssget ‘((0 . “INSERT”))))
   (if ss
     (block_change ss block_name)
(defun tap_draw_through (/
    tap_draw_through_pt1
    tap_draw_through_pt2
    tap_draw_through_dist
    tap_draw_layer
    block_name
    tap_draw_through_angle
  (defun tap_draw_through1 (pt1    pt_dist  pt_angle      /
       pt1    pt2   pt4  pt5 pt6    pt7
       pt8    pt9   pt10  pt11 pt12   pt13
       pt14   pt15   pt_angle
    (setq pt2 (polar pt1 pt_angle pt_dist))
      (setq tap_draw_layer tap_draw_layer_3)
      (setq tap_draw_layer tap_draw_layer_1)
    (setq pt3  (polar (polar pt1
        (+ pt_angle (* pi 0.5))
        pt_angle
        (/ tap_draw_p 2.0)
   pt4  (polar pt3 pt_angle (- pt_dist tap_draw_p))
   pt5  (polar pt3
        (- pt_angle (* pi 0.5))
   pt6  (polar pt4
   pt7  (polar pt1 (+ pt_angle (* pi 0.5)) (/ tap_draw_dia 2.0))
   pt8  (polar pt7 pt_angle pt_dist)
   pt9  (polar pt1 (- pt_angle (* pi 0.5)) (/ tap_draw_dia 2.0))
   pt10 (polar pt9 pt_angle pt_dist)
    (entmake (LIST (cons 0 “LINE”)
     (cons 8 tap_draw_layer)
     (cons 10 pt3)
     (cons 11 pt4)
     (cons 10 pt5)
     (cons 11 pt6)
     (cons 10 pt7)
     (cons 11 pt3)
     (cons 10 pt3)
     (cons 11 pt5)
     (cons 10 pt5)
     (cons 11 pt9)
     (cons 10 pt8)
     (cons 11 pt4)
     (cons 10 pt4)
     (cons 11 pt6)
     (cons 10 pt6)
     (cons 11 pt10)
    (if
      (or (= tap_draw_type_3 “1”)
   (and (= tap_draw_type_3 “0”)
        (<= (- pt_dist (/ tap_draw_p 2.0)) (atof tap_draw_type_4))
       (progn
   (cons 10 pt7)
   (cons 11 pt8)
   (cons 10 pt9)
   (cons 11 pt10)
       (progn
  (setq pt11 (polar pt1
        pt12 (polar pt11 pt_angle (atof tap_draw_type_4))
        pt13 (polar pt1
        pt14 (polar pt13 pt_angle (atof tap_draw_type_4))
        pt15 (polar (polar pt12 pt_angle (/ tap_draw_p 2.0))
      (/ tap_draw_p 2.0)
        pt16 (polar pt15
   (cons 10 pt11)
   (cons 11 pt12)
   (cons 10 pt13)
   (cons 11 pt14)
   (cons 10 pt12)
   (cons 11 pt15)
   (cons 10 pt14)
   (cons 11 pt16)
   (cons 10 pt12)
   (cons 11 pt14)
   (cons 10 pt15)
   (cons 11 pt16)
      (progn
 (entmake
  ;(CONS 48 (dxf_48_setting (/ pt_dist 50.0)))
  (CONS 10 (polar pt1 (+ pt_angle pi) 2.0))
  (CONS 11 (polar pt2 pt_angle 2.0))
  (if (and (/= (setq tap_draw_through_pt1 (getpoint “n삽입점:”)) nil)
    (/= (setq tap_draw_through_pt2
        (getpoint tap_draw_through_pt1
    “n거리/방향:”
        nil
    (progn
      (setq tap_draw_through_angle
      (angle tap_draw_through_pt1
      (DISTANCE tap_draw_through_pt1
 (progn
   (tap_draw_through1
     (trans tap_draw_through_pt1 1 0)
   (while
      (tap_draw_through1
 (progn
   (if (or (= tap_draw_type_3 “1”)
         (<= (- tap_draw_through_dist (/ tap_draw_p 2.0))
     (setq block_name
     (strcat “M”
      (rtos tap_draw_dia)
      ” TAP “
      (RTOS tap_draw_through_dist)
      “t관통”
     (setq block_name
     (strcat “%%C”
      (rtos (- tap_draw_dia tap_draw_p))
      “t관통후 M”
      (rtos tap_draw_dia)
      ” TAP X “
      tap_draw_type_4
      ” depth”
   (if (= (tblsearch “block” block_name) nil)
     (progn
       (entmake (list (cons 0 “BLOCK”)
        (cons 2 block_name)
        (cons 70 0)
        (cons 10 (list 0.0 0.0 0.0))
       (tap_draw_through1
  (list 0 0 0)
  (* pi 1.5)
     (progn
       (vl-cmdf
  “_insert”
  block_name
  (/ 360
     (/ (* 2.0 pi) (+ tap_draw_through_angle (* pi 0.5)))
       (while
  (/= (vl-cmdf
        “_insert”
        block_name
        pause
        (/ 360
    (/ (* 2.0 pi)
      nil
     (progn
       (if ss
(defun tap_draw_blind (/
         tap_draw_blind_pt
         tap_draw_blind_angle
         tap_draw_blind_angle_1
         tap_draw_blind_angle_2
         block_name
  (defun tap_draw_blind1 (pt    pt_angle /      tap_draw_layer
     pt    pt_angle pt1      pt2      pt3
     pt4    pt5     pt6      pt7      pt8
     pt9    pt10     pt11
      (progn
      (progn
    (setq pt1 (polar (polar pt
       pt_angle
       (/ tap_draw_p 2.0)
   pt2 (polar pt1
       pt_angle
       (- (atof tap_draw_type_2) (/ tap_draw_p 2.0))
   pt3 (polar pt1
   pt4 (polar pt2
   pt5 (polar
  (polar pt2
         pt_angle
         (sqrt (- (expt (/ (/ (- tap_draw_dia tap_draw_p) 2.0)
      (cos (* (/ pi 180) 31))
          2
    (expt (/ (- tap_draw_dia tap_draw_p) 2.0) 2)
     (cons 10 pt1)
     (cons 11 pt2)
     (cons 10 pt3)
     (cons 11 pt4)
     (cons 10 pt2)
     (cons 11 pt5)
     (cons 10 pt4)
     (cons 11 pt5)
     (cons 10 pt2)
     (cons 11 pt4)
    (if (= tap_draw_tyep_1 “2”)
;(or (= tap_draw_type_3 “1”)
    ; (and (= tap_draw_type_3 “0”)
  ; (<= (- (atof tap_draw_type_2) (/ tap_draw_p 2.0))
       ;(atof tap_draw_type_4)
      (progn
 (setq pt6 (polar pt
       pt7 (polar pt6 pt_angle (atof tap_draw_type_2))
       pt8 (polar pt
       pt9 (polar pt8 pt_angle (atof tap_draw_type_2))
         (cons 10 pt6)
         (cons 11 pt7)
         (cons 10 pt8)
         (cons 11 pt9)
         (cons 10 pt7)
         (cons 11 pt2)
         (cons 10 pt9)
         (cons 11 pt4)
      (progn
 (setq pt6  (polar pt
       pt7  (polar pt6 pt_angle (atof tap_draw_type_4))
       pt8  (polar pt
       pt9  (polar pt8 pt_angle (atof tap_draw_type_4))
       pt10 (polar (polar pt7 pt_angle (/ tap_draw_p 2.0 (/ (sin (* pi (/ 30 180.))) (cos (* pi (/ 30 180.))))));각도조절1
     (/ tap_draw_p 2.0)
       pt11 (polar (polar pt9 pt_angle (/ tap_draw_p 2.0 (/ (sin (* pi (/ 30 180.))) (cos (* pi (/ 30 180.))))));각도조절2
     (/ tap_draw_p 2.0)
         (cons 10 pt6)
         (cons 11 pt7)
         (cons 10 pt8)
         (cons 11 pt9)
         (cons 10 pt7)
         (cons 11 pt10)
 (entmake (LIST (cons 0 “LINE”);1
         (cons 10 pt7)
         (cons 11 pt10);<-각도점1
 (entmake (LIST (cons 0 “LINE”);2
         (cons 10 pt9)
         (cons 11 pt11);<-각도점2
 ;(vl-cmdf “circle” pt7 0.1)
 ;(vl-cmdf “circle” pt9 0.1)
 (entmake (LIST (cons 0 “LINE”);red2white
         (cons 10 pt7)
         (cons 11 pt9)
     (cons 10 pt1)
     (cons 11 pt6)
     (cons 10 pt1)
     (cons 11 pt3)
     (cons 10 pt3)
     (cons 11 pt8)
      (progn
 (entmake
 ; (CONS 48 (dxf_48_setting (/ tap_draw_dia 50.0)))
  (CONS 10 (polar pt (+ pt_angle pi) 2.0))
  (CONS 11 (polar pt5 pt_angle 2.0))
  (setq tap_draw_blind_pt (getpoint “n삽입점:”))
  (if (= tap_draw_blind_angle nil)
    (setq tap_draw_blind_angle_1 (* pi 1.5))
    (setq tap_draw_blind_angle_1 tap_draw_blind_angle)
  (if (EQUAL tap_draw_blind_angle_1 0 0.000001)
    (setq tap_draw_blind_angle_2 0)
    (/ 360 (/ (* pi 2) tap_draw_blind_angle_1))
  (GETANGLE tap_draw_blind_pt
     (strcat “n방향=>삽입각도/<<“
      (rtos tap_draw_blind_angle_2)
    (setq tap_draw_blind_angle tap_draw_blind_angle_1)
    (progn
      (while (/= tap_draw_blind_pt nil)
 (tap_draw_blind1
   (trans tap_draw_blind_pt 1 0)
    (progn
 (setq block_name
        (strcat “%%C”
         ” X “
         tap_draw_type_2
         ” depth후 M”
         (rtos tap_draw_dia)
         ” TAP”
 (setq block_name
        (strcat “%%C”
         ” X “
         tap_draw_type_2
         ” depth후 M”
         (rtos tap_draw_dia)
         ” TAP X “
         tap_draw_type_4
         ” depth”
 (progn
    (cons 2 block_name)
    (cons 70 0)
   (tap_draw_blind1 (list 0 0 0) (* pi 1.5))
 (progn
   (vl-cmdf
     “_insert”
     block_name
     tap_draw_blind_pt
     (/ 360 (/ (* 2.0 pi) (+ tap_draw_blind_angle (* pi 0.5))))
   (while
     (/= (vl-cmdf
    “_insert”
    block_name
    pause
    (/ 360
  nil
 (progn
   (if ss
(defun tap_draw_layer_1_make (/)
  (if (= (TBLSEARCH “LAYER” tap_draw_layer_1) nil)
    (COMMAND “-LAYER”   “MAKE”       tap_draw_layer_1
      “COLOR”   “7”        “”     “ltype”
      “Continuous” “”        “”
(defun tap_draw_layer_2_make (/)
  (if (= (TBLSEARCH “LAYER” tap_draw_layer_2) nil)
    (COMMAND “-LAYER”   “MAKE”       tap_draw_layer_2
      “COLOR”   “1”        “”     “ltype”
      “Continuous” “”        “”
(defun tap_draw_layer_3_make (/)
  (if (= (TBLSEARCH “LAYER” tap_draw_layer_3) nil)
    (COMMAND “-LAYER”  “MAKE”      tap_draw_layer_3
      “COLOR”  “2”      “”   “ltype”
      “hidden”  “”      “”
(defun tap_draw_layer_4_make (/)
  (if (= (TBLSEARCH “LAYER” tap_draw_layer_4) nil)
    (COMMAND “-LAYER”  “MAKE”      tap_draw_layer_4
      “center”  “”      “”
(defun tap_draw_dcl (/      tap_draw_dcl_name
       tap_draw_dcl_name_1   tap_draw_dcl_name_2
       dcl_id
  (vl-load-com)
  (setq tap_draw_dcl_name
  (vl-filename-mktemp “tap_draw.dcl”)
 tap_draw_dcl_name_1
  (open tap_draw_dcl_name “w”)
 tap_draw_dcl_name_2
  (strcat
    “tap_draw : dialog {
label = ”2D 탭”;
: row {
: boxed_column {
    label = ”탭 유형”;
    width = 15;
    fixed_width = true;
      :row {
     :boxed_radio_column { label = ”도면 상태”;
                                        key = ”tap_draw_type_1”;
         : radio_button { label = ”평면도”; key = ”0”;}
         : radio_button { label = ”정면 관통”; key = ”1”;}
         : radio_button { label = ”정면 깊이”; key = ”2”;}
         spacer_1;
     : text { label = ”    탭 깊이”; }
: edit_box{ key = ”tap_draw_type_4”;    width = 1;}
         spacer_1;
: row {
  : toggle { label = ”블럭으로 그리기” ; key = ”tap_draw_type_5”;}
: toggle { label = ”블럭 교체” ; key = ”tap_draw_type_6”;}
spacer_1;
: column{
: toggle { label = ”은선으로 그리기” ; key = ”tap_draw_type_7”;}
: toggle { label = ”중심선으로 그리기” ; key = ”tap_draw_type_8”;}
spacer_1;
: row {
: text {label = ”설정 탭규격”; is_bold = true;}
: text {key = ”tap_draw_type_9”; is_bold = true; width = 5;}
: boxed_column {
    label = ”탭 사이즈”;
    width = 15;
    fixed_width = true;
: row {
: button {
label = ”M2.5”;
key = ”tap_draw_3”;
width = 5;
height = 1.5;
: button {
label = ”M3”;
key = ”tap_draw_4”;
width = 5;
height = 1.5;
: button {
label = ”M4”;
key = ”tap_draw_6”;
width = 5;
height = 1.5;
: row {
: button {
label = ”M5”;
key = ”tap_draw_7”;
width = 5;
height = 1.5;
: button {
label = ”M6”;
key = ”tap_draw_8”;
width = 5;
height = 1.5;
: button {
label = ”M8”;
key = ”tap_draw_10”;
width = 5;
height = 1.5;
: row {
: button {
label = ”M10”;
key = ”tap_draw_11”;
width = 5;
height = 1.5;
: button {
label = ”M12”;
key = ”tap_draw_12”;
width = 5;
height = 1.5;
: button {
label = ”M14”;
key = ”tap_draw_13”;
width = 5;
height = 1.5;
: row {
: button {
label = ”M16”;
key = ”tap_draw_14”;
width = 5;
height = 1.5;
: button {
label = ”M18”;
key = ”tap_draw_15”;
width = 5;
height = 1.5;
: button {
label = ”M20”;
key = ”tap_draw_16”;
width = 5;
height = 1.5;
: row {
: button {
label = ”M22”;
key = ”tap_draw_17”;
width = 5;
height = 1.5;
: button {
label = ”M24”;
key = ”tap_draw_18”;
width = 5;
height = 1.5;
: button {
label = ”M30”;
key = ”tap_draw_20”;
width = 5;
height = 1.5;
spacer_1;
ok_cancel;
  (write-line tap_draw_dcl_name_2 tap_draw_dcl_name_1)
  (close tap_draw_dcl_name_1)
  (setq dcl_id (load_dialog tap_draw_dcl_name))
  (if (not (new_dialog “tap_draw” dcl_id))
    (exit)
  (setq ok1 0)
  (if (= tap_draw_type_1 nil)
    (setq tap_draw_type_1 “0”)
  ;(if (= tap_draw_type_2 nil)
    ;(setq tap_draw_type_2 “20”)
  (if (= tap_draw_type_3 nil)
    (setq tap_draw_type_3 “1”)
  (if (= tap_draw_type_4 nil)
    ;(setq tap_draw_type_4 tap_draw_type_2)
(setq tap_draw_type_4  “4”  tap_draw_type_2 (rtos (+ (atof tap_draw_type_4) 2)2 2))
  (if (= tap_draw_type_5 nil)
    (setq tap_draw_type_5 “0”)
  (if (= tap_draw_type_1 “0”)
    (if (= tap_draw_type_7 nil)
      (setq tap_draw_type_7 “0”)
      (setq tap_draw_type_7 “1”)
  (if (= tap_draw_type_8 nil)
    (setq tap_draw_type_8 “1”)
  (if (= tap_draw_dia nil)
    (setq tap_draw_dia 8)
  (SET_TILE “tap_draw_type_1” tap_draw_type_1)
  ;(SET_TILE “tap_draw_type_2” tap_draw_type_2)
  ;(SET_TILE “tap_draw_type_3” tap_draw_type_3)
  (SET_TILE “tap_draw_type_4” tap_draw_type_4)
  (SET_TILE “tap_draw_type_5” tap_draw_type_5)
  (SET_TILE “tap_draw_type_7” tap_draw_type_7)
  (SET_TILE “tap_draw_type_8” tap_draw_type_8)
  (SET_TILE “tap_draw_type_9”
     (strcat “M” (rtos tap_draw_dia))
  (tap_draw_dcl_start)
  (action_tile
    “tap_draw_type_1”
    “(setq tap_draw_type_1 $value tap_draw_type_3 $value)(tap_draw_dcl_start)”
  ;(action_tile
   ; “tap_draw_type_2”
   ; “(setq tap_draw_type_2 $value)(tap_draw_dcl_start)”
 ; (action_tile
   ;  “tap_draw_type_3”
   ; “(setq tap_draw_type_3 $value)(tap_draw_dcl_start)”
  (action_tile
    “tap_draw_type_4”
    “(setq tap_draw_type_4 $value)(tap_draw_dcl_start)”
  (action_tile
    “tap_draw_type_5”
    “(setq tap_draw_type_5 $value)(tap_draw_dcl_start)”
  (action_tile
    “tap_draw_type_6”
    “(setq tap_draw_type_6 $value)”
  (action_tile
    “tap_draw_type_7”
    “(setq tap_draw_type_7 $value)”
  (action_tile
    “tap_draw_type_8”
    “(setq tap_draw_type_8 $value)”
  (action_tile
    “tap_draw_3”
    “(setq tap_draw_dia 2.5 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_4”
    “(setq tap_draw_dia 3 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_5”
    “(setq tap_draw_dia 3.5 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_6”
    “(setq tap_draw_dia 4 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_7”
    “(setq tap_draw_dia 5 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_8”
    “(setq tap_draw_dia 6 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_10”
    “(setq tap_draw_dia 8 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_11”
    “(setq tap_draw_dia 10 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_12”
    “(setq tap_draw_dia 12 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_13”
    “(setq tap_draw_dia 14 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_14”
    “(setq tap_draw_dia 16 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_15”
    “(setq tap_draw_dia 18 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_16”
    “(setq tap_draw_dia 20 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_17”
    “(setq tap_draw_dia 22 ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_18”
    “(setq tap_draw_dia 24(tap_chk 24) ok1 1)(done_dialog)”
  (action_tile
    “tap_draw_20”
    “(setq tap_draw_dia 30 ok1 1)(done_dialog)”
  (setq ok (start_dialog))
  (done_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete tap_draw_dcl_name)
(defun tap_draw_dcl_start (/)
    (progn
      (MODE_TILE “tap_draw_type_2” 1)
      (MODE_TILE “tap_draw_type_3” 1)
      (MODE_TILE “tap_draw_type_4” 1)
    (progn
      (if (= tap_draw_type_1 “1”)
 (MODE_TILE “tap_draw_type_2” 0)
     ; (MODE_TILE “tap_draw_type_3” 0)
      (if (= tap_draw_type_3 “2”)
 (progn
   (MODE_TILE “tap_draw_type_4” 0)
   (if  (= tap_draw_type_1 “2”)
     (progn
       (setq tap_draw_type_4 tap_draw_type_4 )
  (if (= tap_draw_type_5 “1”)
    (progn
      (MODE_TILE “tap_draw_type_6” 0)
      (if (= tap_draw_type_6 nil)
 (setq tap_draw_type_6 “0”)
      )a
      (SET_TILE “tap_draw_type_6” tap_draw_type_6)
    (progn
      (MODE_TILE “tap_draw_type_6” 1)
  • 138 조회
