홈/ 질문/Q 79196
등록일: 2008-12-042008-12-04T10:03:43+09:00 2008-12-04T10:03:43+09:00카테고리: AutoCAD & CADian
캐드 초기화 프로그램 에러
수고많으십니다.
예전부터 사용하던 리습입니다.
도면 설정을 초기화시키는 리습입니다.
아직 캐드2002 버전을 사용중인데.
갑자기 사용이 안되는 군요…
혹 뭐가 문제인지 봐주시면 고맙겠습니다.
확인바랍니다.
그럼
(defun c:ini()
 (if (= dwgsc nil)
  (progn
   (setq dwgsc (getreal “n** Enter scale of current drawing <default=1> ?”))
    (if (= dwgsc nil) (setq dwgsc 1))
  ) ;; paren of progn
  (setq dwgsc dwgsc)
 ) ;; paren of progn
(SETVAR “CMDECHO” 0)
(command “layer” “m” “0” “c” “white”    “” “lt” “continuous” “” “”)
(command “layer” “m” “1” “c” “red”      “” “lt” “center” “” “”)
(command “layer” “m” “2” “c” “yellow”   “” “lt” “hidden” “” “”)
(command “layer” “m” “3” “c” “green”    “” “lt” “continuous” “” “”)
(command “layer” “m” “4” “c” “cyan”     “” “lt” “continuous” “” “”)
(command “layer” “m” “5” “c” “blue”     “” “lt” “phantom” “” “”)
(command “layer” “m” “6” “c” “magenta”  “” “lt” “phantom” “” “”)
(command “layer” “m” “7” “c” “yellow”  “” “lt” “continuous” “” “”)
 (setvar “cmdecho” 0)
 (setvar “angdir” 0)
 (setvar “aunits” 0)
 (setvar “auprec” 3)
 (setvar “blipmode” 0)
 (setvar “coords” 2)
 (setvar “dimasz” 2)
 (setvar “DIMclrd” 4)
 (setvar “DIMclre” 4)
 (setvar “DIMclrt” 4)
 (setvar “DIMcEN” 2.5)
 (setvar “dimdle” 6)
 (setvar “DIMDLI” 7)
 (setvar “dimexe” 1)
 (setvar “dimexo” 1)
 (setvar “dimgap” 1)
 (setvar “dimse1” 0)
 (setvar “dimse2” 0)
 (setvar “dimsho” 1)
 (setvar “dimsoxd” 0)
 (setvar “dimtad” 1)
 (setvar “dimtih” 0)
 (setvar “dimtix” 1)
 (setvar “dimtofl” 1)
 (setvar “dimtoh” 0)
 (setvar “dimtol” 0)
 (setvar “dimtxt” 3)
 (setvar “dimzin” 8)
 (setvar “dragmode” 2)
 (setvar “filedia” 1)
 (setvar “limcheck” 1)
 (setvar “lunits” 2)
 (setvar “luprec” 3)
 (setvar “orthomode” 1)
 (setvar “osmode” 0)
 (setvar “aperture” 5)
 (setvar “pickbox” 5)
 (setvar “regenmode” 1)
 (setvar “ucsicon” 0)
 (command “aperture” “5”)
 (command “base” “0,0”)
 (command “linetype” “s” “bylayer” “”)
 (command “ltscale” (* dwgsc 8))
 (command “donut” (/ dwgsc 2) dwgsc “”)
 (command “grid” (* dwgsc 8) “grid” “off”)
 (command “filletrad” “0”)
 (command “pdmode” “0” “pdsize” “0”)
 (command “chamfera” “1” “chamferb” “1”)
 (setvar “highlight” 0)
 (command “viewres” “y” “2000”)
 (COMMAND “MIRRTEXT” “0”)
 (command “limits” “off”)
 (command “style” “STANDARD” “isocp.shx” “0” “1.0” “” “” “” “”)
 (command “dim” “dimscale” dwgsc “e”)
 (COMMAND “OSNAP” “INT,END”)
 (COMMAND “FILEDIA” “1”)
 (setvar “highlight” 1)
 (setvar “cmdecho” 1)
  • 26 조회
