홈/ 질문/Q 191007
김상동
김상동Lv.0
등록일: 2024-09-052024-09-05T08:06:46+09:00 2024-09-05T08:06:46+09:00카테고리: AutoCAD & CADian
appload를 매번해야하는것인가요
appload를 매번해야하는것인가요
autocad 2024사용중인데 appload로 불러들였는데 매번 안불러집니다.
첨부와같이 설정했는데 안되네요
다시 appload로 불러들이면 됩니다.
loadlisp파일내용은 아래와같습니다.
아래
(Load “c:dawooLISP22.lsp”)
(Load “c:dawooLISP2PM.lsp”)
(Load “c:dawooLISP3.lsp”)
(Load “c:dawooLISP3LE.lsp”)
(Load “c:dawooLISP4.lsp”)
(Load “c:dawooLISP5.lsp”)
(Load “c:dawooLISP6.lsp”)
(Load “c:dawooLISP7.lsp”)
(Load “c:dawooLISPA1.lsp”)
(Load “c:dawooLISPa3.lsp”)
(Load “c:dawooLISPAA.lsp”)
(Load “c:dawooLISPAB.lsp”)
(Load “c:dawooLISPALE.lsp”)
(Load “c:dawooLISPAR.lsp”)
(Load “c:dawooLISPARY.lsp”)
(Load “c:dawooLISPB.lsp”)
(Load “c:dawooLISPBLE.lsp”)
(Load “c:dawooLISPCCH.lsp”)
(Load “c:dawooLISPDIMSETUP.lsp”)
(Load “c:dawooLISPJJ.lsp”)
(Load “c:dawooLISPLE.lsp”)
(Load “c:dawooLISPLF.lsp”)
(Load “c:dawooLISPLFF.lsp”)
(Load “c:dawooLISPLT.lsp”)
(Load “c:dawooLISPOFD.lsp”)
(Load “c:dawooLISPOFW.lsp”)
(Load “c:dawooLISPPJC.lsp”)
(Load “c:dawooLISPQQ.lsp”)
(Load “c:dawooLISPSLAB.lsp”)
(Load “c:dawooLISPOld-one.lsp”)
(Load “c:dawooLISPDTL.lsp”)
(Load “c:dawooLISPMO.lsp”)
(Load “c:dawooLISPSUM.lsp”)
(Load “c:dawooLISPOF.lsp”)
(Load “c:dawooLISPOFF.lsp”)
(Load “c:dawooLISP2L.lsp”)
(Load “c:dawooLISPPBOX.lsp”)
;(Load “c:dawooLISPSTS.lsp”)
(Load “c:dawooLISPIp.lsp”)
(Load “c:dawooLISPabox.lsp”)
(Load “c:dawooLISPPW.LSP”)
(Load “c:dawooLISPcl.lsp”)
(Load “c:dawooLISPaf.lsp”)
(Load “c:dawooLISPw2.lsp”)
(Load “c:dawooLISPpj.lsp”)
(Load “c:dawooLISPXCX.VLX”)
(Load “c:dawooLISPatg.lsp”)
(Load “c:dawooLISParea-ar1.lsp”)
(Load “c:dawooLISPhatchOutLine.lsp”)
(load “c:dawooonekey.lsp”)
(command “ucsicon” “off”)
(command “-scalelistedit” “r” “y” “e”)
(COMMAND “viewres” “Y” “2000”)
;;(command “LAYERFILTERALERT” “2”)
(defun c:ZA() (command “_zoom””_a”)(princ));zoom all
(defun c:ZC() (command “_zoom””_c”)(princ));zoom center
(defun c:ZD() (command “_zoom””_d”)(princ));zoom dynamic
(defun c:ZE() (command “_zoom””_e”)(princ));zoom expand
(defun c:ZP() (command “_zoom””_p”)(princ));zoom prvious
(defun c:ZW() (command “_zoom””_w”)(princ));zoom Window
(defun c:ZZ() (command “_zoom””_p”)(princ));zoom prvious
캐드옵션은 dawoo제일위에 걸어놨습니다.
autocad2024 #appload #autoload
  • 6 6 답변
  • 312 조회
    6 답변
      주왕 Lv.26
      2024-09-05T08:21:23+09:00답변 등록 답변 등록 일시 2024-09-05 8:21 am
      옵션/파일/지원파일검색경로에 해당리습 폴더 추가하시구
      가방모양 목차에서 한번더 로드 하시면 됩니다.
      • 김상동 Lv.0
        2024-09-05T08:34:54+09:00에게 댓글을 달았습니다. 답변 등록 일시 2024-09-05 8:34 am
        네 답 감사합니다.
        다시 시도해보는데 이번엔 가방모양이 안보이네요 ;;
        언로드 해봐야할것같아요…
        계속 시도해봐야겠습니다
    3. 캐드플러스 Lv.18
      2024-09-05T11:04:27+09:00답변 등록 답변 등록 일시 2024-09-05 11:04 am
      경로설정이 잘못 되었습니다.
      (Load “c:dawooLISP22.lsp”) ;;; X
      (Load “c:\dawooLISP22.lsp”)
      Ex) (Load “c:\폴드명\파일명.lsp”) 꼭 역슬레쉬를 폴더뒤에 2개씩 해야합니다.
      • 캐드플러스 Lv.18
        2024-09-05T11:07:48+09:00에게 댓글을 달았습니다. 답변 등록 일시 2024-09-05 11:07 am
        헐 ~~~~~~~
        여기에 역슬레쉬 2개를 해서 올렸는데 하나가 없어 집니다.
      • 김상동 Lv.0
        2024-09-05T11:10:39+09:00에게 댓글을 달았습니다. 답변 등록 일시 2024-09-05 11:10 am
        네 답 감사합니다.
        시도해보겠습니다.
        • 김상동 Lv.0
          2024-09-05T13:39:21+09:00에게 댓글을 달았습니다. 답변 등록 일시 2024-09-05 1:39 pm
          메모장으로 일괗변경을 통해서 모두 바꿨는데 역시 안되네요
          시간내셔서 답주셨는데 아쉽습니다
