홈/ 질문/Q 99014
등록일: 2013-08-042013-08-04T20:23:12+09:00 2013-08-04T20:23:12+09:00카테고리: AutoCAD & CADian
ATTRIBUTE에서 벨류값 질문이요.
아래처럼 .net코드를 짜보았는데요..
문제가 있습니다….ㅠ
                                t1.Text = acAtt.Tag
                                t2.Text = acAtt.Prompt
                                t3.Text = acAtt.TextString
이 부분에서
Tag와 Prompt는 아주 잘 불러오는데
TextString는 불러오지 못합니다…
어디가 잘못되어서 벨류값을 가져오지 못하는건가요??ㅠ
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class Form1
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            Dim sLayerName As String = “GG”
            If acBlkTbl.Has(sLayerName) = True Then
                Dim blkRecId As ObjectId = ObjectId.Null
                blkRecId = acBlkTbl(“GG”)
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = acTrans.GetObject(blkRecId, OpenMode.ForRead)
                If acBlkTblRec.HasAttributeDefinitions Then
                    For Each objID As ObjectId In acBlkTblRec
                        Dim dbObj As DBObject = acTrans.GetObject(objID, OpenMode.ForRead)
                        If TypeOf dbObj Is AttributeDefinition Then
                            Dim acAtt As AttributeDefinition = dbObj
                            If acAtt.Tag = “CEIL” Then
                                t1.Text = acAtt.Tag
                            End If
                        End If
                    Next
                End If
            End If
        End Using
    End Sub
End Class
  • 24 조회
