홈/ 질문/Q 180315
아슈람태제
아슈람태제Lv.0
등록일: 2023-01-202023-01-20T17:52:55+09:00 2023-01-20T17:52:55+09:00카테고리: AutoCAD & CADian
CAD 리습문의 입니다
숫자 번호로 레이어변경 하는 리습인데 작동을 안해서 고수님들 자문은 구하고자 올립니다.
(command “-LAYER” “S” “0” “”)
(princ));
(defun c:1()
(prompt “nCommand: CENTER Draw…”)(terpri)
(command “-layer” “M” “CENTER” “cen” “14” “CEN” “L” “CEN” “” “”)
(command “-LAYER” “S” “CEN” “”)
(princ));
(defun c:2()
(prompt “nCommand: col LAYER Draw…”)(terpri)
(command “-layer” “M” “col” “C” “2” “col” “”)
(command “-LAYER” “S” “col” “”)
(princ));
(defun c:3()
(prompt “nCommand: wal LAYER Draw…”)(terpri)
(command “-layer” “M” “wal” “C” “3” “wal” “”)
(command “-LAYER” “S” “wal” “”)
(princ));
(defun c:4()
(prompt “nCommand: etc LAYER Draw…”)(terpri)
(command “-layer” “M” “etc” “C” “7” “etc” “”)
(command “-LAYER” “S” “etc” “”)
(princ));
(defun c:5()
(prompt “nCommand: HAT LAYER Draw…”)(terpri)
(command “-layer” “M” “HAT” “C” “5” “HAT” “”)
(command “-LAYER” “S” “HAT” “”)
(princ));
(defun c:6()
(prompt “nCommand: dim LAYER Draw…”)(terpri)
(command “-layer” “M” “dim” “C” “134” “dim” “”)
(command “-LAYER” “S” “dim” “”)
(princ));
(defun c:7()
(prompt “nCommand: tex LAYER Draw…”)(terpri)
(command “-layer” “M” “tex” “C” “3” “tex” “”)
(command “-LAYER” “S” “tex” “”)
(princ));
(defun c:8()
(prompt “nCommand: wid LAYER Draw…”)(terpri)
(command “-layer” “M” “wid” “C” “4” “wid” “”)
(command “-LAYER” “S” “wid” “”)
(princ));
(defun c:9()
(prompt “nCommand: lan LAYER Draw…”)(terpri)
(command “-layer” “M” “lan” “C” “3” “lan” “”)
(command “-LAYER” “S” “lan” “”)
(princ))
  • 124 조회
    2. C눈꽃J Lv.1
      2023-01-21T09:35:08+09:00답변 등록 답변 등록 일시 2023-01-21 9:35 am
      (defun c:0()
      (command “.layer” “S” “0” “”)
      (defun c:1()
      (command “.layer” “M” “CENTER” “L” “CENTER” “CENTER” “C” “14” “” “”)
      (command “.layer” “S” “CENTER” “”)
      (defun c:2()
      (command “.layer” “M” “col” “C” “2” “” “”)
      (command “.layer” “S” “col” “”)
      (defun c:3()
      (command “.layer” “M” “wal” “C” “3” “” “”)
      (command “.layer” “S” “wal” “”)
      (defun c:4()
      (command “.layer” “M” “etc” “C” “7” “” “”)
      (command “.layer” “S” “etc” “”)
      (defun c:5()
      (command “.layer” “M” “HAT” “C” “5” “” “”)
      (command “.layer” “S” “HAT” “”)
      (defun c:6()
      (command “.layer” “M” “dim” “C” “134” “” “”)
      (command “.layer” “S” “dim” “”)
      (defun c:7()
      (command “.layer” “M” “tex” “C” “3” “” “”)
      (command “.layer” “S” “tex” “”)
      (defun c:8()
      (command “.layer” “M” “wid” “C” “4” “” “”)
      (command “.layer” “S” “wid” “”)
      (defun c:9()
      (command “.layer” “M” “lan” “C” “3” “” “”)
      (command “.layer” “S” “lan” “”)
