(DEFUN C:EJ()
(defun SETERR(s)
(if (/= s “Function cancelled”)
(princ (strcat “nError: ” s))
); of If
(setq *error* oer seterr nil)
); of SETERR
(setq oer *error* *error* seterr)
(setq lp (getvar “LUPREC”))
(setvar “cmdecho” 0)
(setq sn (getint “Start Number
(if (= sn nil) (setq sn 1))
(setq txts (getvar “textsize”))
(princ “Text hight <")
(princ txts)
(setq txth (getdist “>: “))
(terpri)
(if (= nil txth) (setq txth txts))
(setq sf (getreal “Scale factor <1.0>: “)) ;scale factor럼력
(if (= sf nil) (setq sf 1.0))
(setq lc (getpoint “Pick location of Coordinate list: “))
(terpri)
(setq num sn)
;*** Question file writing
(initget “Yes No”)
(setq ans (getkword “Make file?(Yes/No): “))
(if (= ans “Yes”)
(progn
; get file name
; (setq fn (getstring “Enter file name :”))
(setq fn (getfiled “Open data file” “” “dat” 1))
;*** check exist file
(if (findfile fn)
(progn
(princ “nFile allready exist, “)
(initget 1 “OverWrite Append”)
(setq ansOA (getkword “OverWrite / Append: “))
(cond
((= ansOA “OverWrite”) (setq opf (open fn “w”)))
((= ansOA “Append”) (setq opf (open fn “a”)))
); of cond
); of progn
;*** open write file (if file isn’t exist)
); of if
) ; End prog
nil
) ; End if
(setq count 1)
(princ “nPoint# “)
(princ num)
(while
;*** get node point
(setq pnt (getpoint ” Pick point: “))
(setq pntx (car pnt))
(setq pnty (cadr pnt))
;*** integer to number
(setq txt (itoa num))
;*** get number text position
(setq pnt1x (+ pntx txth))
(setq pnt1y (+ pnty txth))
(setq pnt1 (list pnt1x pnt1y))
;*** draw number text
(command “text” “j” “m” pnt1 txth “” TXT)
(terpri)
;*** get coord text
(setq pxy (strcat txt “(” (rtos (* pntx sf) 2 lp)
“,” (rtos (* pnty sf) 2 lp) “)”))
;(princ pxyf opf)
(if (= ans “Yes”)
(progn
; Write File (ans = “Yes”)
;*** get coord text to write file
(setq pxyf (strcat txt “,” (rtos (* pntx sf) 2 lp)
“,” (rtos (* pnty sf) 2 lp)))
(write-line pxyf opf)
;(princ “coord= “)
;(princ pxyf)
) ; End then
) ; End if
;*** get coord text position
(setq cpy (- (cadr lc) (* count (* 1.5 txth))))
(setq cpx (car lc))
(setq cpxy (list cpx cpy))
;*** draw coord text
(command “text” cpxy txth “” pxy)
(terpri)
(setq num (+ num 1))
(setq count (+ count 1))
(princ “Point# “)
(princ num)
) ; of while
(if (= ans “Yes”)
(close opf)
) ;End if
);;; End of Program
리습이란게 이런건줄 알았다면 좀 배워둘껄 그랬습니다..
일단 저 리습을 잘 쓰고 있슴니다만 조금 변경할려고 하는데요..
캐드상에서 이렇게 출력될수 있도록 좀 해주세요..
현재는
1(0,0)
2(1,0)
제가 원하는것은여..
E1 0 0
E2 1 0
이렇게여..왜냐면 저기에서
제가 칸과 테두리를 만들어
표로 쓸려고 그러거덩요..
부탁드릴께여..
