홈/ 질문/Q 24900
등록일: 2007-08-172007-08-17T08:12:04+09:00 2007-08-17T08:12:04+09:00카테고리: AutoCAD & CADian
LAYER ON/OFF LISP 인데요.어디가 문제일까요?
(defun C:LEO (/ cmd ename elist lyr) LAYER OFF
(setq cmd (getvar “cmdecho”))
(setvar “cmdecho” 0)
(setq ename (car (entsel “n Select an entity :”)))
(while (null ename)
(setq ename (car (entsel “n Select again :”)))
(setq elist (entget ename))
(setq lyr (assoc 8 elist))
(command “layer” “set” (cdr lyr) “”)
(command “layer” “off” “*” “” “”)
(prompt (strcat “n Now the current layer is ” (cdr lyr) “.”))
(setvar “cmdecho” cmd)
(prin1)
(defun C:ALO (/ cmd lyr ss test) LAYER ON
(command “layer” “on” “*” “”)
  • 33 조회
