홈/ 질문/Q 96166
AHN GISEOG
AHN GISEOGLv.0
등록일: 2012-09-162012-09-16T14:39:08+09:00 2012-09-16T14:39:08+09:00카테고리: AutoCAD & CADian
LFD 리습 수정 하려면
어떻게 하나요? 부탁드립니다.
화일의 용량 줄이는 리습이라 해서 구해서 사용중인데,
이 리습이 되는지 안되는지 확인 은 못해봤어요. 실행후 <엔터>치면 별다른 메시지 없이
바로 명령행으로 나가는데요. 아무튼 <엔터> 없이 ALL DELETE 실행완료 하려면
어떻게 수정해야 하나요? 복 받으실거예요~
(defun rrbI:LayerFiltersDelete  (strKeepWC / objXDict)
 ;; This function insures that an Extension Dictionary exists, and works on both locations for layer filters
 (vl-load-com)        ; load ActiveX if needed
 (vl-catch-all-apply                                                            ; trap error if no extension dictionary
  (function
   (lambda ()
    (setq objXDict (vla-GetExtensionDictionary                                  ; bind dictionary to variable
                    (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))))))
 (cond (objXDict        ; if the extension dictionary exists
        (or        ; use OR to return T for success
         (rrbI:DeleteAllXRecs objXDict “ACAD_LAYERFILTERS” strKeepWC)           ; pre-2005 layer filters
         (rrbI:DeleteAllXRecs objXDict “AcLyDictionary” strKeepWC)))))          ; 2005 layer filters
(defun rrbI:DeleteAllXRecs  (objXDict dictName strKeepWC / objDict i)
 ;; This function performs the chore of deleting each filer that doesn”t match the wildcard
 (vl-catch-all-apply                                                            ; trap errors
  (function
   (lambda ()
    (setq objDict (vla-Item objXDict dictName))                                 ; get layer filters dictionary
    (vlax-for objXRec  objDict                                                  ; loop thru all XRecords in the dictionary
     (cond ((not (and strKeepWC (wcmatch (vla-Get-Name objXRec) strKeepWC)))    ; if deleting all filters, or current doesn”t match wildcard
            (setq i (1+ (cond (i)                                               ; increment counter
                              (0))))                                            ; initialize counter
            (vla-Delete objXRec)))))))                                          ; delete filter
 (cond (i (princ (strcat “n” (itoa i) ” filters deleted.”)))))                 ; if counter is bound, report number of filters deleted
(defun C:LFD  (/ inpKeep)
 ;; Main command-line function
 (setq inpKeep (getstring
                “nWildcard mask for filters to keep, or <Enter> to delete all: “))
 (rrbI:LayerFiltersDelete (cond ((/= inpKeep “”) inpKeep)))                     ; pass nil to subr if user hit <Enter>
 (princ))        ; clean exit
  • 39 조회
    • 도구막대 이동시 미리보기가 안됩니다.
