r14에서 사용된 파이프 끝단 처리 리습인데
2004에서는 에러가 납니다…
2004버젼으로 수정부탁드립니다…
(defun c:AC( / sp ep dist ang p1 p2 p3 p4)
;input
(setq os (getvar “osmode”))
(setvar “osmode” os)
(setq sp (getpoint “pick start point : “))
(setq ep (getpoint sp “pick int point : “))
;set work point
(setq dist (distance sp ep))
(setq ang (angle sp ep))
(setq p1 (polar sp ang (/ dist 2)))
(setq p2 (polar sp ang (/ dist 4)))
(setq p3 (polar p2 (+ ang 1.5708) (/ dist 10)))
(setq p4 (polar p2 (+ ang 4.71239) (/ dist 10)))
;command
(setvar “cmdecho” 0)
(setvar “osmode” 0)
(command “ARC” sp p3 p1)
(command “chprop” “l” “” “la” “D” “”)
(command “copy” “p” “” sp p1)
(command “mirror” “p” “” sp p1 “”)
(setvar “cmdecho” 1)
