홈/ 질문/Q 113112
등록일: 2021-05-272021-05-27T16:02:42+09:00 2021-05-27T16:02:42+09:00카테고리: AutoCAD & CADian
ucs 이동(기준점이동) 문의입니다
Sub Ch8_NewUCS()
    ‘ Define the variables we will need
    Dim ucsObj As AcadUCS
    Dim xAxisPnt(0 To 2) As Double
    Dim yAxisPnt(0 To 2) As Double
    ‘ Define the UCS points
    Dim origin As Variant
    ‘ Return a point using a prompt
    origin = ThisDrawing.Utility.GetPoint(, “Enter a point: “)
    xAxisPnt(0) = origin(0) + 1: xAxisPnt(1) = origin(1): xAxisPnt(2) = 0
    yAxisPnt(0) = origin(0): yAxisPnt(1) = origin(1) + 1: yAxisPnt(2) = 0
    Set ucsObj = ThisDrawing.UserCoordinateSystems. _
         Add(origin, xAxisPnt, yAxisPnt, “New_UCS”)
    ThisDrawing.ActiveViewport.UCSIconAtOrigin = True
    ThisDrawing.ActiveViewport.UCSIconOn = True
    ‘ Make the new UCS the active UCS
    ThisDrawing.ActiveUCS = ucsObj
 End Sub
위와같이 하여 UCS를 임의로 옮겼습니다
명령창에서는  옮긴 UCS기준점이 0,0,0 으로 작동합니다
그러나  아래 명령을 옮긴 UCS기준으로 할수있는 방법을
어떻게 합니까
고수분 부탁 합니다
Sub poly()
 Dim plineObj As AcadPolyline
    Dim points(0 To 11) As Double
     points(0) = 0: points(1) = 0: points(2) = 0
    points(3) = 10: points(4) = 0: points(5) = 0
    points(6) = 10: points(7) = 10: points(8) = 0
    points(9) = 0: points(10) = 10: points(11) = 0
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    plineObj.Closed = True
end sub
  • 40 조회
